    Creating Attribute manager controls
    30 Posts 0 Posters 23.9k Views
      On 25/05/2011 at 01:15, xxxxxxxx wrote:
      Everything was going fine until the time I needed to check what was the button it was pressed.
      I assume it is done inside the Message procedure.
      The message procedure has the following parameters: Message(self, tag, type, data) :
      I placed in there:
      print type
      print data
      and only the data part seems to return something useful in the form:
      {id: (1001, 8, 100000011)}
      The problem is that it appears in the middle of a whole lot more data that I don't need.
      So, how can I extract the information of what button in being pressed?
      Thank you very much in advance for any reply.
      Rui Batista
        On 25/05/2011 at 03:26, xxxxxxxx wrote:
        Lol, same question one topic down of this one here. Tongue
        I'm not at home, so i cant test it right now.
        It was something like     _
        if not data: return True
        id = data[0]["id"][0]_
        or so.
        Cheers, Niklas
          On 25/05/2011 at 04:33, xxxxxxxx wrote:
          I tried this:
          def Message(self, tag, type, data) :
          but=data[0]['id'][0]
          print but
          But I still get errors in the console:
          File "'Origins.pyp'", line 26, in Message
          TypeError: 'NoneType' object is unsubscriptable
          KeyError: 0
          KeyError: 0
          KeyError: 0
          KeyError: 0
          KeyError: 0
          Line 26 is: but=data[0]['id'][0]
            On 25/05/2011 at 06:38, xxxxxxxx wrote:
            Did you also tried to change the Keys ? I'm no able to try it today.
            try this to check out what returns what.
            print data
            print data[0]
            print data[0]["id"]
            print data[0][0]
            print data[0]["id"][0]
            print data[0][0]["id"]
            You can then just delete what raises
            an error.
              On 25/05/2011 at 07:22, xxxxxxxx wrote:
              None of those worked out. But I'm getting somewhere by trial&error; 😉
              So, what I have now is:
              if not type: return True
              if type<>18: return True
              print data.values()[0]
              And, what I get it something like:
              So, now I just need a way to extract the first number (the 1001, in this case).
              Any help?
              Rui Batista
                On 25/05/2011 at 07:35, xxxxxxxx wrote:
                I can't even determine the type of the "but" variable 😞
                If it is in the format (1001, 8, 100000011), it is not an array, right? It is not a dict either, I believe.
                So, how can I extract the numbers from it?
                  On 25/05/2011 at 07:38, xxxxxxxx wrote:
                  Ok, it seems to be a tuple but when I print the first element with print but[0], instead of a number, I get:
                  <c4d.DescLevel object at 0x12902c4b0>
                  What I want is a number, as in... 1001
                  How?!? 😉
                    On 25/05/2011 at 08:24, xxxxxxxx wrote:
                    Hi Rui, you can access this by calling     but[0].id
                    Cheers, Sebastian
                      On 25/05/2011 at 08:36, xxxxxxxx wrote:
                      YES!!! Thank you soooooo much 🙂
                      Rui Batista
                        On 25/05/2011 at 08:54, xxxxxxxx wrote:
                        Did you get the button to actually work Rui?
                        I can get other things to work like check boxes..But not Buttons:
                        def Message(self, tag, type, bc) :
                          bc = tag.GetDataInstance();
                          if bc.GetLong(c4d.XRAY)== True:  #This works
                            print "CheckBox Enabled"
                          if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
                            print "Button Pushed"
                        Maybe I need to get and check the state of the button?
                          On 25/05/2011 at 09:34, xxxxxxxx wrote:
                          Hm I could now look it up and i used this:
                          def GetMessageID(data) :
                            try:
                                return data["id"][0].id
                            except:
                                return None
                          cheers
                            On 25/05/2011 at 14:09, xxxxxxxx wrote:
                            What I have now (and fully working) is something like this:
                            but=data.values()[0]
                            if but[0].id==1001:
                                # stuff
                            if but[0].id==1002:
                                # stuff
                            Would this be what you need, Scott?
                            Thank you all for the help 🙂
                            Rui Batista
                              On 25/05/2011 at 15:14, xxxxxxxx wrote:
                              Yeah.. That helps a lot Rui.
                              But it doesn't seem to work with ID names
                              if but[0].id==1006:     print "button enabled" #<---Works
                              if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                              I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                              Where did you find this?:type<>18
                              I've never seen that before. And I'm wondering what it means.
                              Is that a C4D SDK thing. Or is that something that is built into the Python language?
                                On 25/05/2011 at 15:43, xxxxxxxx wrote:
                                Actually I found out by trial&error.;
                                I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                                if type==(numbers the I noted, one by one) :
                                print data
                                And when I compared the type with 18, it printed out:
                                Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                                Rui Batista
                                  On 25/05/2011 at 16:49, xxxxxxxx wrote:
                                  LOL. Whatever it takes.
                                  You don't want to know what goes through my head in order for me to use pointers in C++ 😉
                                  The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
                                  I thought that maybe the "if type<>18: " meant "if the type is a button".
                                  So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
                                  I guess I'll have to try them out too. And see if anything happens.
                                  Thanks for the information.
                                    On 25/05/2011 at 21:58, xxxxxxxx wrote:
                                    Your ID is not wokring because of the missing prefix. 😉
                                    c4d.CLICK_ME
                                      On 26/05/2011 at 02:20, xxxxxxxx wrote:
                                      With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general 😞
                                      One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results 😞
                                      Rui Batista
                                        On 26/05/2011 at 05:30, xxxxxxxx wrote:
                                        I donÄt understand what you want to do with type != 18.. ?!
                                        The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
                                          On 26/05/2011 at 07:21, xxxxxxxx wrote:
                                          c4d.CLICK_ME
                                          Son of a @#@$#@$#@#@!!!.
                                          I swear to God. That frakin' c4d. prefix is out to get me. 😂
                                          I thought I had finally squashed that prefix demon...Guess not.
                                          Instead of going round and round. And telling us it works for you in two threads nux.
                                          Why not take that plugin example I posted. And add the button code to it and show us?
                                          You have my permission to do that.
                                            On 26/05/2011 at 08:13, xxxxxxxx wrote:
                                            And where is the GetMessageID information?
                                            I typed it in the search field of the python documentation and nothing appeared 😞
