    Creating Attribute manager controls
    30 Posts 0 Posters 25.1k Views
      On 24/05/2011 at 10:22, xxxxxxxx wrote:
      You need to write Ressource files. Instead of dialog, it's called a description.
      There are examples in the doc.
      Py-RoundedTube or Py-SpherifyModifier for example.
      Cheers, nux
        On 24/05/2011 at 10:47, xxxxxxxx wrote:
        "Description resource" in the C++ SDK is probably the best source of information about this.
        Here's a very simple tag with a button and some other things on it that might help:https:////sites.google.com/site/scottayersmedia/MyPythonTag.zip?attredirects=0&d=1
          On 24/05/2011 at 13:14, xxxxxxxx wrote:
          Scott, by the way:
          You can already use those Parameter-Ids in your Plugin*.
          Like: rot.x = tag[c4d.rotx]
          Do also always write those IDs Upparcase, as this is the standart of C4D.
          *: You may sometimes have to delete the coffeesymbolscache-file.
            On 24/05/2011 at 13:24, xxxxxxxx wrote:
            Thank you very much. I will dissect them all 🙂
            Rui Batista
              On 24/05/2011 at 14:01, xxxxxxxx wrote:
              Nux.
              The reason that file uses numeric ID's is because I use it to remind myself of both ways we can create gizmos. Using Both the .res names method, and the numeric ID method.
              It was just something really simple I could slap a button on to show Rui an example.
              But you're right about the Case.
              If I give it out. I should probably not use lower case names. So I changed that.
              I don't want to promote bad habits. 🙂
                On 25/05/2011 at 01:15, xxxxxxxx wrote:
                Everything was going fine until the time I needed to check what was the button it was pressed.
                I assume it is done inside the Message procedure.
                The message procedure has the following parameters: Message(self, tag, type, data) :
                I placed in there:
                print type
                print data
                and only the data part seems to return something useful in the form:
                {id: (1001, 8, 100000011)}
                The problem is that it appears in the middle of a whole lot more data that I don't need.
                So, how can I extract the information of what button in being pressed?
                Thank you very much in advance for any reply.
                Rui Batista
                  On 25/05/2011 at 03:26, xxxxxxxx wrote:
                  Lol, same question one topic down of this one here. Tongue
                  I'm not at home, so i cant test it right now.
                  It was something like     _
                  if not data: return True
                  id = data[0]["id"][0]_
                  or so.
                  Cheers, Niklas
                    On 25/05/2011 at 04:33, xxxxxxxx wrote:
                    I tried this:
                    def Message(self, tag, type, data) :
                    but=data[0]['id'][0]
                    print but
                    But I still get errors in the console:
                    File "'Origins.pyp'", line 26, in Message
                    TypeError: 'NoneType' object is unsubscriptable
                    KeyError: 0
                    KeyError: 0
                    KeyError: 0
                    KeyError: 0
                    KeyError: 0
                    Line 26 is: but=data[0]['id'][0]
                      On 25/05/2011 at 06:38, xxxxxxxx wrote:
                      Did you also tried to change the Keys ? I'm no able to try it today.
                      try this to check out what returns what.
                      print data
                      print data[0]
                      print data[0]["id"]
                      print data[0][0]
                      print data[0]["id"][0]
                      print data[0][0]["id"]
                      You can then just delete what raises
                      an error.
                        On 25/05/2011 at 07:22, xxxxxxxx wrote:
                        None of those worked out. But I'm getting somewhere by trial&error; 😉
                        So, what I have now is:
                        if not type: return True
                        if type<>18: return True
                        print data.values()[0]
                        And, what I get it something like:
                        So, now I just need a way to extract the first number (the 1001, in this case).
                        Any help?
                        Rui Batista
                          On 25/05/2011 at 07:35, xxxxxxxx wrote:
                          I can't even determine the type of the "but" variable 😞
                          If it is in the format (1001, 8, 100000011), it is not an array, right? It is not a dict either, I believe.
                          So, how can I extract the numbers from it?
                            On 25/05/2011 at 07:38, xxxxxxxx wrote:
                            Ok, it seems to be a tuple but when I print the first element with print but[0], instead of a number, I get:
                            <c4d.DescLevel object at 0x12902c4b0>
                            What I want is a number, as in... 1001
                            How?!? 😉
                              On 25/05/2011 at 08:24, xxxxxxxx wrote:
                              Hi Rui, you can access this by calling     but[0].id
                              Cheers, Sebastian
                                On 25/05/2011 at 08:36, xxxxxxxx wrote:
                                YES!!! Thank you soooooo much 🙂
                                Rui Batista
                                  On 25/05/2011 at 08:54, xxxxxxxx wrote:
                                  Did you get the button to actually work Rui?
                                  I can get other things to work like check boxes..But not Buttons:
                                  def Message(self, tag, type, bc) :
                                    bc = tag.GetDataInstance();
                                    if bc.GetLong(c4d.XRAY)== True:  #This works
                                      print "CheckBox Enabled"
                                    if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
                                      print "Button Pushed"
                                  Maybe I need to get and check the state of the button?
                                    On 25/05/2011 at 09:34, xxxxxxxx wrote:
                                    Hm I could now look it up and i used this:
                                    def GetMessageID(data) :
                                      try:
                                          return data["id"][0].id
                                      except:
                                          return None
                                    cheers
                                      On 25/05/2011 at 14:09, xxxxxxxx wrote:
                                      What I have now (and fully working) is something like this:
                                      but=data.values()[0]
                                      if but[0].id==1001:
                                          # stuff
                                      if but[0].id==1002:
                                          # stuff
                                      Would this be what you need, Scott?
                                      Thank you all for the help 🙂
                                      Rui Batista
                                        On 25/05/2011 at 15:14, xxxxxxxx wrote:
                                        Yeah.. That helps a lot Rui.
                                        But it doesn't seem to work with ID names
                                        if but[0].id==1006:     print "button enabled" #<---Works
                                        if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                                        I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                                        Where did you find this?:type<>18
                                        I've never seen that before. And I'm wondering what it means.
                                        Is that a C4D SDK thing. Or is that something that is built into the Python language?
                                          On 25/05/2011 at 15:43, xxxxxxxx wrote:
                                          Actually I found out by trial&error.;
                                          I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                                          if type==(numbers the I noted, one by one) :
                                          print data
                                          And when I compared the type with 18, it printed out:
                                          Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                                          Rui Batista
                                            On 25/05/2011 at 16:49, xxxxxxxx wrote:
                                            LOL. Whatever it takes.
                                            You don't want to know what goes through my head in order for me to use pointers in C++ 😉
                                            The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
                                            I thought that maybe the "if type<>18: " meant "if the type is a button".
                                            So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
                                            I guess I'll have to try them out too. And see if anything happens.
                                            Thanks for the information.
