    Creating Attribute manager controls
    30 Posts 0 Posters 24.1k Views
      On 25/05/2011 at 07:38, xxxxxxxx wrote:
      Ok, it seems to be a tuple but when I print the first element with print but[0], instead of a number, I get:
      <c4d.DescLevel object at 0x12902c4b0>
      What I want is a number, as in... 1001
      How?!? 😉
        On 25/05/2011 at 08:24, xxxxxxxx wrote:
        Hi Rui, you can access this by calling     but[0].id
        Cheers, Sebastian
          On 25/05/2011 at 08:36, xxxxxxxx wrote:
          YES!!! Thank you soooooo much 🙂
          Rui Batista
            On 25/05/2011 at 08:54, xxxxxxxx wrote:
            Did you get the button to actually work Rui?
            I can get other things to work like check boxes..But not Buttons:
            def Message(self, tag, type, bc) :
              bc = tag.GetDataInstance();
              if bc.GetLong(c4d.XRAY)== True:  #This works
                print "CheckBox Enabled"
              if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
                print "Button Pushed"
            Maybe I need to get and check the state of the button?
              On 25/05/2011 at 09:34, xxxxxxxx wrote:
              Hm I could now look it up and i used this:
              def GetMessageID(data) :
                try:
                    return data["id"][0].id
                except:
                    return None
              cheers
                On 25/05/2011 at 14:09, xxxxxxxx wrote:
                What I have now (and fully working) is something like this:
                def Message(self, tag, type, data) :
                if not type: return True
                if type<>18: return True
                but=data.values()[0]
                if but[0].id==1001:
                    # stuff
                if but[0].id==1002:
                    # stuff
                Would this be what you need, Scott?
                Thank you all for the help 🙂
                Rui Batista
                  On 25/05/2011 at 15:14, xxxxxxxx wrote:
                  Yeah.. That helps a lot Rui.
                  But it doesn't seem to work with ID names
                  if but[0].id==1006:     print "button enabled" #<---Works
                  if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                  I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                  Where did you find this?:type<>18
                  I've never seen that before. And I'm wondering what it means.
                  Is that a C4D SDK thing. Or is that something that is built into the Python language?
                    On 25/05/2011 at 15:43, xxxxxxxx wrote:
                    Actually I found out by trial&error.;
                    I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                    if type==(numbers the I noted, one by one) :
                    print data
                    And when I compared the type with 18, it printed out:
                    (1001, 8, 100000011)
                    Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                    Rui Batista
                      On 25/05/2011 at 16:49, xxxxxxxx wrote:
                      LOL. Whatever it takes.
                      You don't want to know what goes through my head in order for me to use pointers in C++ 😉
                      The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
                      I thought that maybe the "if type<>18: " meant "if the type is a button".
                      So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
                      I guess I'll have to try them out too. And see if anything happens.
                      Thanks for the information.
                        On 25/05/2011 at 21:58, xxxxxxxx wrote:
                        Your ID is not wokring because of the missing prefix. 😉
                        c4d.CLICK_ME
                          On 26/05/2011 at 02:20, xxxxxxxx wrote:
                          With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general 😞
                          One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results 😞
                          Rui Batista
                            On 26/05/2011 at 05:30, xxxxxxxx wrote:
                            I donÄt understand what you want to do with type != 18.. ?!
                            The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
                              On 26/05/2011 at 07:21, xxxxxxxx wrote:
                              c4d.CLICK_ME
                              Son of a @#@$#@$#@#@!!!.
                              I swear to God. That frakin' c4d. prefix is out to get me. 😂
                              I thought I had finally squashed that prefix demon...Guess not.
                              Instead of going round and round. And telling us it works for you in two threads nux.
                              Why not take that plugin example I posted. And add the button code to it and show us?
                              You have my permission to do that.
                                On 26/05/2011 at 08:13, xxxxxxxx wrote:
                                And where is the GetMessageID information?
                                I typed it in the search field of the python documentation and nothing appeared 😞
                                  On 26/05/2011 at 10:52, xxxxxxxx wrote:
                                  @Rui:
                                  The function is self-made. 😉
                                    try:
                                    except:
                                        return None
                                  cheers
                                  @Scott:
                                  So it's still not working for you ? (my english is too bad -.-)
                                  I will tomorrow post you an absolutely fully working example !
                                    Yes. Using the .c4d prefix works. 👍
                                    I was just yelling at myself for making such a stupid mistake. That I thought I had stopped myself from making anymore.
                                    Please do post a working example with your button code in it.
                                    Feel free to use the plugin I posted.  Or one of your own if you prefer.
                                    Whatever is easier.
                                      On 26/05/2011 at 14:36, xxxxxxxx wrote:
                                      I changed my plug-in tag to use the GetMessageID(data) function and the id names.
                                      I guess that the type check for 18 allow the procedure to terminate sooner if no button is being pressed but I also removed that check.
                                      It is working just fine, now 🙂
                                      Thank you all, once again.
                                      Rui Batista
                                        On 27/05/2011 at 07:10, xxxxxxxx wrote:
                                        So, here it is. A fully working example of a TagData Plugin demonstrating the use of descriptions.
                                        http://www.file-upload.net/download-3462169/PyTag-Example.rar.html
                                        Niklas
