    Creating Attribute manager controls
    PYTHON Development
    0
    30
    21.1k
    • H
      On 24/05/2011 at 09:21, xxxxxxxx wrote:
      Is it possible to create controls in the Attribute manager with Python?
      I have a Python Tag that I would like to show four buttons in the Attribute manager when it is selected.
      But I only seem to find information about creating a GeDialog. Is there anything on creating stuff on the Attribute manager?
      • H
        On 24/05/2011 at 10:22, xxxxxxxx wrote:
        You need to write Ressource files. Instead of dialog, it's called a description.
        There are examples in the doc.
        Py-RoundedTube or Py-SpherifyModifier for example.
        Cheers, nux
        • H
          On 24/05/2011 at 10:47, xxxxxxxx wrote:
          "Description resource" in the C++ SDK is probably the best source of information about this.
          Here's a very simple tag with a button and some other things on it that might help:https:////sites.google.com/site/scottayersmedia/MyPythonTag.zip?attredirects=0&d=1
          • H
            On 24/05/2011 at 13:14, xxxxxxxx wrote:
            Scott, by the way:
            You can already use those Parameter-Ids in your Plugin*.
            Like: rot.x = tag[c4d.rotx]
            Do also always write those IDs Upparcase, as this is the standart of C4D.
            *: You may sometimes have to delete the coffeesymbolscache-file.
            • H
              On 24/05/2011 at 13:24, xxxxxxxx wrote:
              Thank you very much. I will dissect them all 🙂
              Rui Batista
              • H
                On 24/05/2011 at 14:01, xxxxxxxx wrote:
                Nux.
                The reason that file uses numeric ID's is because I use it to remind myself of both ways we can create gizmos. Using Both the .res names method, and the numeric ID method.
                It was just something really simple I could slap a button on to show Rui an example.
                But you're right about the Case.
                If I give it out. I should probably not use lower case names. So I changed that.
                I don't want to promote bad habits. 🙂
                • H
                  On 25/05/2011 at 01:15, xxxxxxxx wrote:
                  Everything was going fine until the time I needed to check what was the button it was pressed.
                  I assume it is done inside the Message procedure.
                  The message procedure has the following parameters: Message(self, tag, type, data) :
                  I placed in there:
                  print type
                  print data
                  and only the data part seems to return something useful in the form:
                  {id: (1001, 8, 100000011)}
                  The problem is that it appears in the middle of a whole lot more data that I don't need.
                  So, how can I extract the information of what button in being pressed?
                  Thank you very much in advance for any reply.
                  Rui Batista
                  • H
                    On 25/05/2011 at 03:26, xxxxxxxx wrote:
                    Lol, same question one topic down of this one here. Tongue
                    I'm not at home, so i cant test it right now.
                    It was something like     _
                    if not data: return True
                    id = data[0]["id"][0]_
                    or so.
                    Cheers, Niklas
                    • H
                      On 25/05/2011 at 04:33, xxxxxxxx wrote:
                      I tried this:
                      def Message(self, tag, type, data) :
                      but=data[0]['id'][0]
                      print but
                      But I still get errors in the console:
                      File "'Origins.pyp'", line 26, in Message
                      TypeError: 'NoneType' object is unsubscriptable
                      KeyError: 0
                      KeyError: 0
                      KeyError: 0
                      KeyError: 0
                      KeyError: 0
                      Line 26 is: but=data[0]['id'][0]
                      • H
                        On 25/05/2011 at 06:38, xxxxxxxx wrote:
                        Did you also tried to change the Keys ? I'm no able to try it today.
                        try this to check out what returns what.
                        print data
                        print data[0]
                        print data[0]["id"]
                        print data[0][0]
                        print data[0]["id"][0]
                        print data[0][0]["id"]
                        You can then just delete what raises
                        an error.
                        • H
                          On 25/05/2011 at 07:22, xxxxxxxx wrote:
                          None of those worked out. But I'm getting somewhere by trial&error; 😉
                          So, what I have now is:
                          if not type: return True
                          if type<>18: return True
                          print data.values()[0]
                          And, what I get it something like:
                          So, now I just need a way to extract the first number (the 1001, in this case).
                          Any help?
                          Rui Batista
                          • H
                            On 25/05/2011 at 07:35, xxxxxxxx wrote:
                            I can't even determine the type of the "but" variable 😞
                            If it is in the format (1001, 8, 100000011), it is not an array, right? It is not a dict either, I believe.
                            So, how can I extract the numbers from it?
                            • H
                              On 25/05/2011 at 07:38, xxxxxxxx wrote:
                              Ok, it seems to be a tuple but when I print the first element with print but[0], instead of a number, I get:
                              <c4d.DescLevel object at 0x12902c4b0>
                              What I want is a number, as in... 1001
                              How?!? 😉
                              • H
                                On 25/05/2011 at 08:24, xxxxxxxx wrote:
                                Hi Rui, you can access this by calling     but[0].id
                                Cheers, Sebastian
                                • H
                                  On 25/05/2011 at 08:36, xxxxxxxx wrote:
                                  YES!!! Thank you soooooo much 🙂
                                  Rui Batista
                                  • H
                                    On 25/05/2011 at 08:54, xxxxxxxx wrote:
                                    Did you get the button to actually work Rui?
                                    I can get other things to work like check boxes..But not Buttons:
                                    def Message(self, tag, type, bc) :
                                      bc = tag.GetDataInstance();
                                      if bc.GetLong(c4d.XRAY)== True:  #This works
                                        print "CheckBox Enabled"
                                      if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
                                        print "Button Pushed"
                                    Maybe I need to get and check the state of the button?
                                    • H
                                      On 25/05/2011 at 09:34, xxxxxxxx wrote:
                                      Hm I could now look it up and i used this:
                                      def GetMessageID(data) :
                                        try:
                                            return data["id"][0].id
                                        except:
                                            return None
                                      cheers
                                      • H
                                        On 25/05/2011 at 14:09, xxxxxxxx wrote:
                                        What I have now (and fully working) is something like this:
                                        but=data.values()[0]
                                        if but[0].id==1001:
                                            # stuff
                                        if but[0].id==1002:
                                            # stuff
                                        Would this be what you need, Scott?
                                        Thank you all for the help 🙂
                                        Rui Batista
                                        • H
                                          On 25/05/2011 at 15:14, xxxxxxxx wrote:
                                          Yeah.. That helps a lot Rui.
                                          But it doesn't seem to work with ID names
                                          if but[0].id==1006:     print "button enabled" #<---Works
                                          if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                                          I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                                          Where did you find this?:type<>18
                                          I've never seen that before. And I'm wondering what it means.
                                          Is that a C4D SDK thing. Or is that something that is built into the Python language?
                                          • H
                                            On 25/05/2011 at 15:43, xxxxxxxx wrote:
                                            Actually I found out by trial&error.;
                                            I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                                            if type==(numbers the I noted, one by one) :
                                            print data
                                            And when I compared the type with 18, it printed out:
                                            Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                                            Rui Batista
