    Creating Attribute manager controls
    30 Posts 0 Posters 23.0k Views
      On 25/05/2011 at 06:38, xxxxxxxx wrote:
      Did you also tried to change the Keys ? I'm no able to try it today.
      try this to check out what returns what.
      if not data: return True
      print data
      print data[0]
      print data[0]["id"]
      print data[0][0]
      print data[0]["id"][0]
      print data[0][0]["id"]
      You can then just delete what raises
      an error.
        On 25/05/2011 at 07:22, xxxxxxxx wrote:
        None of those worked out. But I'm getting somewhere by trial&error; 😉
        So, what I have now is:
        def Message(self, tag, type, data) :
        if not type: return True
        if type<>18: return True
        print data.values()[0]
        And, what I get it something like:
        (1001, 8, 100000011)
        So, now I just need a way to extract the first number (the 1001, in this case).
        Any help?
        Rui Batista
          On 25/05/2011 at 07:35, xxxxxxxx wrote:
          I can't even determine the type of the "but" variable 😞
          If it is in the format (1001, 8, 100000011), it is not an array, right? It is not a dict either, I believe.
          So, how can I extract the numbers from it?
            On 25/05/2011 at 07:38, xxxxxxxx wrote:
            Ok, it seems to be a tuple but when I print the first element with print but[0], instead of a number, I get:
            <c4d.DescLevel object at 0x12902c4b0>
            What I want is a number, as in... 1001
            How?!? 😉
              On 25/05/2011 at 08:24, xxxxxxxx wrote:
              Hi Rui, you can access this by calling     but[0].id
              Cheers, Sebastian
                On 25/05/2011 at 08:36, xxxxxxxx wrote:
                YES!!! Thank you soooooo much 🙂
                Rui Batista
                  On 25/05/2011 at 08:54, xxxxxxxx wrote:
                  Did you get the button to actually work Rui?
                  I can get other things to work like check boxes..But not Buttons:
                  def Message(self, tag, type, bc) :
                    bc = tag.GetDataInstance();
                    if bc.GetLong(c4d.XRAY)== True:  #This works
                      print "CheckBox Enabled"
                    if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
                      print "Button Pushed"
                  Maybe I need to get and check the state of the button?
                    On 25/05/2011 at 09:34, xxxxxxxx wrote:
                    Hm I could now look it up and i used this:
                    def GetMessageID(data) :
                      try:
                          return data["id"][0].id
                      except:
                          return None
                    cheers
                      On 25/05/2011 at 14:09, xxxxxxxx wrote:
                      What I have now (and fully working) is something like this:
                      but=data.values()[0]
                      if but[0].id==1001:
                          # stuff
                      if but[0].id==1002:
                          # stuff
                      Would this be what you need, Scott?
                      Thank you all for the help 🙂
                      Rui Batista
                        On 25/05/2011 at 15:14, xxxxxxxx wrote:
                        Yeah.. That helps a lot Rui.
                        But it doesn't seem to work with ID names
                        if but[0].id==1006:     print "button enabled" #<---Works
                        if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                        I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                        Where did you find this?:type<>18
                        I've never seen that before. And I'm wondering what it means.
                        Is that a C4D SDK thing. Or is that something that is built into the Python language?
                          On 25/05/2011 at 15:43, xxxxxxxx wrote:
                          Actually I found out by trial&error.;
                          I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                          if type==(numbers the I noted, one by one) :
                          print data
                          And when I compared the type with 18, it printed out:
                          Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                          Rui Batista
                            On 25/05/2011 at 16:49, xxxxxxxx wrote:
                            LOL. Whatever it takes.
                            You don't want to know what goes through my head in order for me to use pointers in C++ 😉
                            The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
                            I thought that maybe the "if type<>18: " meant "if the type is a button".
                            So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
                            I guess I'll have to try them out too. And see if anything happens.
                            Thanks for the information.
                              On 25/05/2011 at 21:58, xxxxxxxx wrote:
                              Your ID is not wokring because of the missing prefix. 😉
                              c4d.CLICK_ME
                                On 26/05/2011 at 02:20, xxxxxxxx wrote:
                                With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general 😞
                                One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results 😞
                                Rui Batista
                                  On 26/05/2011 at 05:30, xxxxxxxx wrote:
                                  I donÄt understand what you want to do with type != 18.. ?!
                                  The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
                                    On 26/05/2011 at 07:21, xxxxxxxx wrote:
                                    c4d.CLICK_ME
                                    Son of a @#@$#@$#@#@!!!.
                                    I swear to God. That frakin' c4d. prefix is out to get me. 😂
                                    I thought I had finally squashed that prefix demon...Guess not.
                                    Instead of going round and round. And telling us it works for you in two threads nux.
                                    Why not take that plugin example I posted. And add the button code to it and show us?
                                    You have my permission to do that.
                                      On 26/05/2011 at 08:13, xxxxxxxx wrote:
                                      And where is the GetMessageID information?
                                      I typed it in the search field of the python documentation and nothing appeared 😞
                                        On 26/05/2011 at 10:52, xxxxxxxx wrote:
                                        @Rui:
                                        The function is self-made. 😉
                                          try:
                                          except:
                                              return None
                                        cheers
                                        @Scott:
                                        So it's still not working for you ? (my english is too bad -.-)
                                        I will tomorrow post you an absolutely fully working example !
                                          Yes. Using the .c4d prefix works. 👍
                                          I was just yelling at myself for making such a stupid mistake. That I thought I had stopped myself from making anymore.
                                          Please do post a working example with your button code in it.
                                          Feel free to use the plugin I posted.  Or one of your own if you prefer.
                                          Whatever is easier.
                                            On 26/05/2011 at 14:36, xxxxxxxx wrote:
                                            I changed my plug-in tag to use the GetMessageID(data) function and the id names.
                                            I guess that the type check for 18 allow the procedure to terminate sooner if no button is being pressed but I also removed that check.
                                            It is working just fine, now 🙂
                                            Thank you all, once again.
                                            Rui Batista
