    Creating Attribute manager controls
    30 Posts 0 Posters 25.1k Views
      On 25/05/2011 at 08:24, xxxxxxxx wrote:
      Hi Rui, you can access this by calling     but[0].id
      Cheers, Sebastian
        On 25/05/2011 at 08:36, xxxxxxxx wrote:
        YES!!! Thank you soooooo much 🙂
        Rui Batista
          On 25/05/2011 at 08:54, xxxxxxxx wrote:
          Did you get the button to actually work Rui?
          I can get other things to work like check boxes..But not Buttons:
          def Message(self, tag, type, bc) :
            bc = tag.GetDataInstance();
            if bc.GetLong(c4d.XRAY)== True:  #This works
              print "CheckBox Enabled"
            if bc.GetLong(c4d.CLICK_ME)== True:  #<-----This does not work!!
              print "Button Pushed"
          Maybe I need to get and check the state of the button?
            On 25/05/2011 at 09:34, xxxxxxxx wrote:
            Hm I could now look it up and i used this:
            def GetMessageID(data) :
              try:
                  return data["id"][0].id
              except:
                  return None
            cheers
              On 25/05/2011 at 14:09, xxxxxxxx wrote:
              What I have now (and fully working) is something like this:
              def Message(self, tag, type, data) :
              if not type: return True
              if type<>18: return True
              but=data.values()[0]
              if but[0].id==1001:
                  # stuff
              if but[0].id==1002:
                  # stuff
              Would this be what you need, Scott?
              Thank you all for the help 🙂
              Rui Batista
                On 25/05/2011 at 15:14, xxxxxxxx wrote:
                Yeah.. That helps a lot Rui.
                But it doesn't seem to work with ID names
                if but[0].id==1006:     print "button enabled" #<---Works
                if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
                I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
                Where did you find this?:type<>18
                I've never seen that before. And I'm wondering what it means.
                Is that a C4D SDK thing. Or is that something that is built into the Python language?
                  On 25/05/2011 at 15:43, xxxxxxxx wrote:
                  Actually I found out by trial&error.;
                  I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
                  if type==(numbers the I noted, one by one) :
                  print data
                  And when I compared the type with 18, it printed out:
                  (1001, 8, 100000011)
                  Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
                  Rui Batista
                    On 25/05/2011 at 16:49, xxxxxxxx wrote:
                    LOL. Whatever it takes.
                    You don't want to know what goes through my head in order for me to use pointers in C++ 😉
                    The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
                    I thought that maybe the "if type<>18: " meant "if the type is a button".
                    So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
                    I guess I'll have to try them out too. And see if anything happens.
                    Thanks for the information.
                      On 25/05/2011 at 21:58, xxxxxxxx wrote:
                      Your ID is not wokring because of the missing prefix. 😉
                      c4d.CLICK_ME
                        On 26/05/2011 at 02:20, xxxxxxxx wrote:
                        With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general 😞
                        One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results 😞
                        Rui Batista
                          On 26/05/2011 at 05:30, xxxxxxxx wrote:
                          I donÄt understand what you want to do with type != 18.. ?!
                          The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
                            On 26/05/2011 at 07:21, xxxxxxxx wrote:
                            c4d.CLICK_ME
                            Son of a @#@$#@$#@#@!!!.
                            I swear to God. That frakin' c4d. prefix is out to get me. 😂
                            I thought I had finally squashed that prefix demon...Guess not.
                            Instead of going round and round. And telling us it works for you in two threads nux.
                            Why not take that plugin example I posted. And add the button code to it and show us?
                            You have my permission to do that.
                              On 26/05/2011 at 08:13, xxxxxxxx wrote:
                              And where is the GetMessageID information?
                              I typed it in the search field of the python documentation and nothing appeared 😞
                                On 26/05/2011 at 10:52, xxxxxxxx wrote:
                                @Rui:
                                The function is self-made. 😉
                                  try:
                                  except:
                                      return None
                                cheers
                                @Scott:
                                So it's still not working for you ? (my english is too bad -.-)
                                I will tomorrow post you an absolutely fully working example !
                                  Yes. Using the .c4d prefix works. 👍
                                  I was just yelling at myself for making such a stupid mistake. That I thought I had stopped myself from making anymore.
                                  Please do post a working example with your button code in it.
                                  Feel free to use the plugin I posted.  Or one of your own if you prefer.
                                  Whatever is easier.
                                    On 26/05/2011 at 14:36, xxxxxxxx wrote:
                                    I changed my plug-in tag to use the GetMessageID(data) function and the id names.
                                    I guess that the type check for 18 allow the procedure to terminate sooner if no button is being pressed but I also removed that check.
                                    It is working just fine, now 🙂
                                    Thank you all, once again.
                                    Rui Batista
                                      On 27/05/2011 at 07:10, xxxxxxxx wrote:
                                      So, here it is. A fully working example of a TagData Plugin demonstrating the use of descriptions.
                                      http://www.file-upload.net/download-3462169/PyTag-Example.rar.html
                                      Niklas
