    Creating Attribute manager controls
    30 Posts 0 Posters 25.1k Views
      On 25/05/2011 at 09:34, xxxxxxxx wrote:
      Hm I could now look it up and i used this:
      def GetMessageID(data) :
        try:
            return data["id"][0].id
        except:
            return None
      cheers
        On 25/05/2011 at 14:09, xxxxxxxx wrote:
        What I have now (and fully working) is something like this:
        def Message(self, tag, type, data) :
        if not type: return True
        if type<>18: return True
        but=data.values()[0]
        if but[0].id==1001:
            # stuff
        if but[0].id==1002:
            # stuff
        Would this be what you need, Scott?
        Thank you all for the help 🙂
        Rui Batista
          On 25/05/2011 at 15:14, xxxxxxxx wrote:
          Yeah.. That helps a lot Rui.
          But it doesn't seem to work with ID names
          if but[0].id==1006:     print "button enabled" #<---Works
          if but[0].id==CLICK_ME: print "button enabled" #<---Does Not Work!
          I'm sure there's a good reason for why the ID names don't work. But it's not the end of the world to have to use the ID numbers.
          Where did you find this?:type<>18
          I've never seen that before. And I'm wondering what it means.
          Is that a C4D SDK thing. Or is that something that is built into the Python language?
            On 25/05/2011 at 15:43, xxxxxxxx wrote:
            Actually I found out by trial&error.;
            I just placed a print type inside the Message procedure. I noted the values. Then I placed a:
            if type==(numbers the I noted, one by one) :
            print data
            And when I compared the type with 18, it printed out:
            (1001, 8, 100000011)
            Not a very elegant way to find out, but it did the trick. However, I don't know what the 18 means 😉
            Rui Batista
              On 25/05/2011 at 16:49, xxxxxxxx wrote:
              LOL. Whatever it takes.
              You don't want to know what goes through my head in order for me to use pointers in C++ 😉
              The main reason I was curious about it is because your code doesn't work when I try to use it on something other than a button. Like say a checkbox for example.
              I thought that maybe the "if type<>18: " meant "if the type is a button".
              So I was curious if there were other numbers that would allow things like checkboxes to work in a similar manner.
              I guess I'll have to try them out too. And see if anything happens.
              Thanks for the information.
                On 25/05/2011 at 21:58, xxxxxxxx wrote:
                Your ID is not wokring because of the missing prefix. 😉
                c4d.CLICK_ME
                  On 26/05/2011 at 02:20, xxxxxxxx wrote:
                  With this simple example of what happened to me I realized once more that the documentation for python in Cinema4D is still very sparcely arranged, lacking a lot of stuff and not very clean in general 😞
                  One has to do lots of questions, lots of digging in and a whole lot of trial&error; attempts to get even the simplest results 😞
                  Rui Batista
                    On 26/05/2011 at 05:30, xxxxxxxx wrote:
                    I donÄt understand what you want to do with type != 18.. ?!
                    The GetMessageID function works fine for me. It returns the pressed GUI Element's ID, i.e. a button's id.
                      On 26/05/2011 at 07:21, xxxxxxxx wrote:
                      c4d.CLICK_ME
                      Son of a @#@$#@$#@#@!!!.
                      I swear to God. That frakin' c4d. prefix is out to get me. 😂
                      I thought I had finally squashed that prefix demon...Guess not.
                      Instead of going round and round. And telling us it works for you in two threads nux.
                      Why not take that plugin example I posted. And add the button code to it and show us?
                      You have my permission to do that.
                        On 26/05/2011 at 08:13, xxxxxxxx wrote:
                        And where is the GetMessageID information?
                        I typed it in the search field of the python documentation and nothing appeared 😞
                          On 26/05/2011 at 10:52, xxxxxxxx wrote:
                          @Rui:
                          The function is self-made. 😉
                            try:
                            except:
                                return None
                          cheers
                          @Scott:
                          So it's still not working for you ? (my english is too bad -.-)
                          I will tomorrow post you an absolutely fully working example !
                            Yes. Using the .c4d prefix works. 👍
                            I was just yelling at myself for making such a stupid mistake. That I thought I had stopped myself from making anymore.
                            Please do post a working example with your button code in it.
                            Feel free to use the plugin I posted.  Or one of your own if you prefer.
                            Whatever is easier.
                              On 26/05/2011 at 14:36, xxxxxxxx wrote:
                              I changed my plug-in tag to use the GetMessageID(data) function and the id names.
                              I guess that the type check for 18 allow the procedure to terminate sooner if no button is being pressed but I also removed that check.
                              It is working just fine, now 🙂
                              Thank you all, once again.
                              Rui Batista
                                On 27/05/2011 at 07:10, xxxxxxxx wrote:
                                So, here it is. A fully working example of a TagData Plugin demonstrating the use of descriptions.
                                http://www.file-upload.net/download-3462169/PyTag-Example.rar.html
                                Niklas
