    Open source wrapper for Octane/Redshift/Arnold/Vray/Corona in Cinema 4D.
    programminglearning-resource
    23 Posts 7 Posters 33.5k Views 4 Watching
    • DunhouD Offline
      Dunhou
      Hi community!
      Since my last post, I had some updates and fix to this library.
      And the following picture shows the new node functions added to my Render Flow plugin based on the use of this library within few lines( just the node context ).
      Have fun with it.
      Cheers~
      DunHou
      https://boghma.com
      https://github.com/DunHouGo
      gheyretG 1 Reply Last reply Reply Quote 3
      • gheyretG Offline
        gheyret @Dunhou
        @Dunhou
        It's realy cool and usefull, keep going bro 🍻
        www.boghma.com
          mogh
          Wow ... good stuff
          My c4d Programing slowed down this year, but this might be something I want to use some day ...
          • czt_306C Offline
            czt_306
            amazing!
            DunhouD 1 Reply Last reply Reply Quote 0
            • DunhouD Dunhou referenced this topic on
            • DunhouD Offline
              Dunhou @czt_306
              Hi community!
              New versions here!
              I had change the name from renderEngine to Renderer, and also changed the main structure. see more in the very first of this topic. (renderEngine had been move to versions folder, if you still interested.)
              This version is way more organized and user-friendly, you can use few lines of code to do something normal work, find an example below:
              Cheers~
              DunHou
              Result:
              Code:
              import maxon
              from Renderer import Redshift, EasyTransaction, TextureHelper
              tex_helper: TextureHelper = TextureHelper()
              disp: maxon.Url = tex_helper.GetAssetUrl("file_fa9c42774dd05049")
              def HowToUse():
                  material: c4d.BaseMaterial = Redshift.Material("MyMaterial")
                  with EasyTransaction(material) as tr:
                      tr.AddDisplacementTree(filepath = disp, shadername = "DISP")
                      tr.InsertMaterial()
                  HowToUse()
              https://boghma.com
              DunhouD 1 Reply Last reply Reply Quote 2
              • DunhouD Offline
                Dunhou @Dunhou
                Hi community!
                Here is a little example of how we modify aovs in Octane, find more examples in the top.
                Have fun with it😊
                Cheers~
                DunHou
                Result:
                Codes:
                import maxon
                import Renderer
                from Renderer import Octane
                from pprint import pprint
                # How to create and modify octane aovs
                def modify_octane_aov():
                    # Get the doc host the aovs, in this case th active doc
                    doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
                    # Set Octane AOVHelper instance
                    aov_helper = Octane.AOV(doc)
                    # Create a Octane aov item
                    # the id can find from Renderer.constants.octane_id.py or in octane folder
                    # If #name is None, defulat to type.
                    diff_aov = aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_DIFFUSE)
                    # Add the DIFFUSE aov we just created to the Octane aov system
                    aov_helper.add_aov(diff_aov)
                    # Add some aovs
                    aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_POST,aov_name = 'POST'))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_D))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_I))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_D))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_I))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_WIRE))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_OBJECT_LAYER_COLOR))
                    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_VOLUME))
                    # Remove last aov: volume
                    aov_helper.remove_last_aov()
                    # Remove specified aov: wire
                    aov_helper.remove_aov_type(aov_type = Octane.RNDAOV_WIRE)
                    # Add 2 custom aovs with id 1 and 2
                    aov_helper.add_custom_aov(customID = 1)
                    aov_helper.add_custom_aov(customID = 2)
                    # Get the custom aov with id 2
                    custom2 = aov_helper.get_custom_aov(customID = 2)
                    if custom2:
                        print(f'We find a Custom AOV with id 2 Named{custom2.GetName()}')
                    # Print current aov info
                    aov_helper.print_aov()
                    Renderer.ClearConsole()
                    modify_octane_aov()
                https://boghma.com
                • DunhouD Offline
                  Dunhou @Dunhou
                  Hi community!
                  Here is a little example of how we modify scene objects in Arnold, find more examples in the top.
                  We want:
                  • Add a Arnold Sky with hdr
                  • Add a gobo light with a node-base gobo material, and a IES light
                  • Add a cube and add a custom mask to the driver
                  • Add a Scatter with custom instance shapes
                  • Auto export proxy with a BaseObject and load back the ass file (need to save project first)
                  Have fun with it😊
                  Cheers~
                  DunHou
                  Results:
                  Codes:
                  import maxon
                  import Renderer
                  from Renderer import Arnold, TextureHelper
                  # Create a TextureHelper instance
                  # How to create and modify arnold scene
                  def modify_arnold_scene():
                      # Get the doc host the scene, in this case th active doc
                      # Set arnold SceneHelper instance
                      scene_helper = Arnold.Scene(doc)
                      ### == Light == ###
                      # Add a rig of hdr and rgb backdrop
                      hdr_url: str =  tex_helper.GetAssetStr(maxon.Id("file_d21cf4cfdec8c636"))
                      scene_helper.add_dome_rig(texture_path = hdr_url, rgb = c4d.Vector(0,0,0))
                      # Add a light object and and some modify tags
                      gobo_url: maxon.Url = tex_helper.GetAssetUrl("file_66b116a34a150e7e")
                      gobo_light = scene_helper.add_gobo(texture_path = str(gobo_url), intensity=2, exposure=0)
                      scene_helper.add_light_modifier(light = gobo_light, gsg_link = True, rand_color = True)
                      # Add a IES light
                      ies_url: str = tex_helper.GetAssetStr("file_6f300f2ba077da4a")
                      ies = scene_helper.add_ies(texture_path = ies_url, intensity=1, exposure=0)
                      ### == Tag == ###
                      # Add a Cude object and an arnold tag with mask_name
                      cube = c4d.BaseObject(c4d.Ocube)
                      scene_helper.add_mask_tag(node=cube, mask_name='My Mask 01')
                      doc.InsertObject(cube)
                      ### == Object == ###
                      # Add a scatter obejct with some children and count 12345
                      generate_object = c4d.BaseObject(c4d.Oplane)
                      doc.InsertObject(generate_object)
                      scatter_A = c4d.BaseObject(c4d.Oplatonic)
                      scatter_B = c4d.BaseObject(c4d.Ooiltank)
                      doc.InsertObject(scatter_A)
                      doc.InsertObject(scatter_B)
                      scatters: list[c4d.BaseObject] = [scatter_A, scatter_B]
                      scene_helper.add_scatter(generator_node=generate_object, scatter_nodes=scatters, count=12345)
                      # Add a object and set auto proxy
                      the_object = c4d.BaseObject(c4d.Oplane)
                      doc.InsertObject(the_object)
                      the_object.SetName("Original Object")
                      scene_helper.auto_proxy(nodes=the_object,remove_objects=False)
                  https://boghma.com
                  • DunhouD Offline
                    Dunhou @Dunhou
                    Hi community!
                    Another little update, as we didn't have DataDescriptionDatabaseInterface as @ferdinand said in How can we get the default port of a GraphNode?
                    I add a ConverterPorts to Renderer, we can use this to get the "default " port of a node until the DataDescriptionDatabaseInterface is valid in python.
                    Note: It can only provide the str data of the port and it's not 100% rigorous
                    Cheers~
                    DunHou
                    Result:
                    Codes:
                    from Renderer import Redshift,EasyTransaction,ClearConsole
                    def ConvertTest():
                        material: c4d.BaseMaterial = c4d.documents.GetActiveDocument().GetActiveMaterial()
                            nodes = tr.GetActiveNodes()
                            for node in nodes:
                                print(f"Node: {tr.GetName(node)}")
                                print(f"Default Input: {tr.GetConvertInput(node)}")
                                print(f"Default Output: {tr.GetConvertOutput(node)}")
                                print("-"*10)
                        ClearConsole()
                        ConvertTest()
                    https://boghma.com
                    • DunhouD Offline
                      Dunhou @Dunhou
                      Hi community!
                      I had add a basic support to V-Ray and Corona to fit the basic PBR usage, no Scene and AOV yet (AOV seems I can not get them in python, if someone knows where it stores, please let me know that).
                      Cheers~
                      DunHou
                      https://boghma.com
                        Hi regarding Vray, I once wrote this plugin that have the duty to create ObjectId passes.
                        I did not try it since age, but previously Vray AOV where stored within a branch on the Render Engine.
                        I don't have vray installed currently, but I guess if you compile the C++ SDK, with the help of the C++ SDK Active Object Example it should be trivial to inspect a Vray scene and find these AOV.
                        Maxime
                        DunhouD 1 Reply Last reply Reply Quote 1
                        • DunhouD Offline
                          Dunhou @m_adam
                          Hi community!
                          Thanks for @m_adam prompt, I had add a AOV to Vray as same as other renderers, see a basic example here, hope it can help 😊
                          Cheer~
                          DunHou
                          Result:
                          Code:
                          import Renderer
                          from Renderer import Vray
                          def modify_vray_aov():
                              # Set Vray AOVHelper instance
                              vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_VRAY)
                              aov_helper = Vray.AOV(vp)
                              diff_aov = aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_DIFFUSE)
                              # Add some aovs
                              aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_BACKGROUND, aov_name = 'BG'))
                              aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SPECULAR))
                              aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_REFLECTION))
                              aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SHADOW))
                              aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_LIGHT_MIX))
                              # Remove last aov
                              # Remove specified aov: diffuse
                              aov_helper.remove_aov_type(aov_type = Vray.VRAY_AOV_DIFFUSE[0])
                              modify_vray_aov()
                          https://boghma.com
                          • DunhouD Offline
                            Dunhou @Dunhou
                            Hi again,
                            Also another Corona AOV example here .
                            Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .
                            The learning process was very enjoyable, hope you also have fun with it ✌
                            Cheers~
                            DunHou
                            Result:
                            Code:
                            import Renderer
                            from Renderer import Corona
                            def modify_corona_aov():
                                # Get the doc host the aovs, in this case th active doc vp
                                vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
                                # Set Corona AOVHelper instance
                                aov_helper = Corona.AOV(vp)
                                # turn on the mutipass
                                aov_helper.enable_mutipass(True)
                                diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
                                # Add some aovs
                                aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
                                aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
                                aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
                                aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
                                aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
                                aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
                                Corona.AovManager()
                                modify_aorona_aov()
                            https://boghma.com
                            • DunhouD Offline
                              Dunhou
                              Hi community!
                              New Updates here :
                              • Fix some Octane and Corona functions (base on layer)
                              • Add MaterialMaker and PBRPackage
                              PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:
                              • we have a texture pack named Rock Stone 01
                              • this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.
                              • we can provide the folder like D:/myTextures and its name like Rock Stone 01
                              • then we get textures in a dictionary
                              data = {"diffuse": Rock Stone 01_albedo.jpg,
                                            "normal": Rock Stone 01_Normal.jpg,
                                            "displacement": Rock Stone 01_disp.jpg,
                                            etc...
                              Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.
                              But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.
                              Cheers~
                              DunHou
                              https://boghma.com
                              • DunhouD Offline
                                Dunhou
                                Hi community!
                                Add Basic CentiLeo Material support, also with ConvertPorts data, This a "new" GPU Renderer and in active development. I am very interested in it.
                                Not add AOV due to still being in the early stages of development, waiting for this.
                                Cheers~
                                DunHou
                                https://boghma.com
