    Open source wrapper for Octane/Redshift/Arnold/Vray/Corona in Cinema 4D.
    programminglearning-resource
    23 Posts 7 Posters 34.4k Views 4 Watching
    • DunhouD Offline
      Dunhou
      Hi community!
      the renderEngine helper is beta now, I set version number to 1.0.0, it contains three renderer now:
      • Octane
      • Arnold ( MaterialHelper only support NodeGragh )
      • Redshift ( MaterialHelper only support NodeGragh )
      I personally not use Vray and Corona quite often, if anyone is a pro user of these , very welcome to add them to renderEngine
      You can modify the aovs/materials with renderEngine quickly and easliy . See the examples above this topic.
      Hope you can have fun with it, and any improvement and fix is very appreciated.
      Cheers~
      DunHou
      https://boghma.com
      https://github.com/DunHouGo
      • T Offline
        thomas
        @Dunhou is it possible to get in touch for you for freelance development? I couldn't find any email or socials.
        DunhouD 1 Reply Last reply Reply Quote 0
        • DunhouD Offline
          Dunhou @thomas
          @thomas Hi, I had update my github readme file, and put my email on it😊
          Cheers~
          DunHou
          https://boghma.com
          • DunhouD Dunhou referenced this topic on
          • DunhouD Offline
            Dunhou
            Hi community!
            Th renderEngine library has been updated to the 1.0.4 version, there are some re-write functions and may not incompatible with older versions,see the main changes as follows:
            • rename all node & material functions to Capitalize style.
            • remove transaction in node_helper, use it in the final scripts.
            • organize the functions in node_helper with comments ( node\port\wire\util )
            • add some functions to check node or port info, like if it is connected , see the README.
            • add a InserShader function to create a shader into a wire.
            • re-write RemoveConnection in node_helper and support one argument(port) to remove connection.
            • see the Version & Updates
            Cheers~
            DunHou
            https://boghma.com
            • DunhouD Offline
              Dunhou
              Hi community!
              Since my last post, I had some updates and fix to this library.
              And the following picture shows the new node functions added to my Render Flow plugin based on the use of this library within few lines( just the node context ).
              Have fun with it.
              Cheers~
              DunHou
              https://boghma.com
              gheyretG 1 Reply Last reply Reply Quote 3
              • gheyretG Offline
                gheyret @Dunhou
                @Dunhou
                It's realy cool and usefull, keep going bro šŸ»
                www.boghma.com
                  mogh
                  Wow ... good stuff
                  My c4d Programing slowed down this year, but this might be something I want to use some day ...
                  • czt_306C Offline
                    czt_306
                    amazing!
                    • DunhouD Offline
                      Dunhou @czt_306
                      Hi community!
                      New versions here!
                      I had change the name from renderEngine to Renderer, and also changed the main structure. see more in the very first of this topic. (renderEngine had been move to versions folder, if you still interested.)
                      This version is way more organized and user-friendly, you can use few lines of code to do something normal work, find an example below:
                      Cheers~
                      DunHou
                      Result:
                      Code:
                      import maxon
                      from Renderer import Redshift, EasyTransaction, TextureHelper
                      tex_helper: TextureHelper = TextureHelper()
                      disp: maxon.Url = tex_helper.GetAssetUrl("file_fa9c42774dd05049")
                      def HowToUse():
                          material: c4d.BaseMaterial = Redshift.Material("MyMaterial")
                          with EasyTransaction(material) as tr:
                              tr.AddDisplacementTree(filepath = disp, shadername = "DISP")
                              tr.InsertMaterial()
                          HowToUse()
                      https://boghma.com
                      DunhouD 1 Reply Last reply Reply Quote 2
                      • DunhouD Offline
                        Dunhou @Dunhou
                        Hi community!
                        Here is a little example of how we modify aovs in Octane, find more examples in the top.
                        Have fun with it😊
                        Cheers~
                        DunHou
                        Result:
                        Codes:
                        import maxon
                        import Renderer
                        from Renderer import Octane
                        from pprint import pprint
                        # How to create and modify octane aovs
                        def modify_octane_aov():
                            # Get the doc host the aovs, in this case th active doc
                            doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
                            # Set Octane AOVHelper instance
                            aov_helper = Octane.AOV(doc)
                            # Create a Octane aov item
                            # the id can find from Renderer.constants.octane_id.py or in octane folder
                            # If #name is None, defulat to type.
                            diff_aov = aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_DIFFUSE)
                            # Add the DIFFUSE aov we just created to the Octane aov system
                            aov_helper.add_aov(diff_aov)
                            # Add some aovs
                            aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_POST,aov_name = 'POST'))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_D))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_I))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_D))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_I))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_WIRE))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_OBJECT_LAYER_COLOR))
                            aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_VOLUME))
                            # Remove last aov: volume
                            aov_helper.remove_last_aov()
                            # Remove specified aov: wire
                            aov_helper.remove_aov_type(aov_type = Octane.RNDAOV_WIRE)
                            # Add 2 custom aovs with id 1 and 2
                            aov_helper.add_custom_aov(customID = 1)
                            aov_helper.add_custom_aov(customID = 2)
                            # Get the custom aov with id 2
                            custom2 = aov_helper.get_custom_aov(customID = 2)
                            if custom2:
                                print(f'We find a Custom AOV with id 2 Named{custom2.GetName()}')
                            # Print current aov info
                            aov_helper.print_aov()
                            Renderer.ClearConsole()
                            modify_octane_aov()
                        https://boghma.com
                        • DunhouD Offline
                          Dunhou @Dunhou
                          Hi community!
                          Here is a little example of how we modify scene objects in Arnold, find more examples in the top.
                          We want:
                          • Add a Arnold Sky with hdr
                          • Add a gobo light with a node-base gobo material, and a IES light
                          • Add a cube and add a custom mask to the driver
                          • Add a Scatter with custom instance shapes
                          • Auto export proxy with a BaseObject and load back the ass file (need to save project first)
                          Have fun with it😊
                          Cheers~
                          DunHou
                          Results:
                          Codes:
                          import maxon
                          import Renderer
                          from Renderer import Arnold, TextureHelper
                          # Create a TextureHelper instance
                          # How to create and modify arnold scene
                          def modify_arnold_scene():
                              # Get the doc host the scene, in this case th active doc
                              # Set arnold SceneHelper instance
                              scene_helper = Arnold.Scene(doc)
                              ### == Light == ###
                              # Add a rig of hdr and rgb backdrop
                              hdr_url: str =  tex_helper.GetAssetStr(maxon.Id("file_d21cf4cfdec8c636"))
                              scene_helper.add_dome_rig(texture_path = hdr_url, rgb = c4d.Vector(0,0,0))
                              # Add a light object and and some modify tags
                              gobo_url: maxon.Url = tex_helper.GetAssetUrl("file_66b116a34a150e7e")
                              gobo_light = scene_helper.add_gobo(texture_path = str(gobo_url), intensity=2, exposure=0)
                              scene_helper.add_light_modifier(light = gobo_light, gsg_link = True, rand_color = True)
                              # Add a IES light
                              ies_url: str = tex_helper.GetAssetStr("file_6f300f2ba077da4a")
                              ies = scene_helper.add_ies(texture_path = ies_url, intensity=1, exposure=0)
                              ### == Tag == ###
                              # Add a Cude object and an arnold tag with mask_name
                              cube = c4d.BaseObject(c4d.Ocube)
                              scene_helper.add_mask_tag(node=cube, mask_name='My Mask 01')
                              doc.InsertObject(cube)
                              ### == Object == ###
                              # Add a scatter obejct with some children and count 12345
                              generate_object = c4d.BaseObject(c4d.Oplane)
                              doc.InsertObject(generate_object)
                              scatter_A = c4d.BaseObject(c4d.Oplatonic)
                              scatter_B = c4d.BaseObject(c4d.Ooiltank)
                              doc.InsertObject(scatter_A)
                              doc.InsertObject(scatter_B)
                              scatters: list[c4d.BaseObject] = [scatter_A, scatter_B]
                              scene_helper.add_scatter(generator_node=generate_object, scatter_nodes=scatters, count=12345)
                              # Add a object and set auto proxy
                              the_object = c4d.BaseObject(c4d.Oplane)
                              doc.InsertObject(the_object)
                              the_object.SetName("Original Object")
                              scene_helper.auto_proxy(nodes=the_object,remove_objects=False)
                          https://boghma.com
                          • DunhouD Offline
                            Dunhou @Dunhou
                            Hi community!
                            Another little update, as we didn't have DataDescriptionDatabaseInterface as @ferdinand said in How can we get the default port of a GraphNode?
                            I add a ConverterPorts to Renderer, we can use this to get the "default " port of a node until the DataDescriptionDatabaseInterface is valid in python.
                            Note: It can only provide the str data of the port and it's not 100% rigorous
                            Cheers~
                            DunHou
                            Result:
                            Codes:
                            from Renderer import Redshift,EasyTransaction,ClearConsole
                            def ConvertTest():
                                material: c4d.BaseMaterial = c4d.documents.GetActiveDocument().GetActiveMaterial()
                                    nodes = tr.GetActiveNodes()
                                    for node in nodes:
                                        print(f"Node: {tr.GetName(node)}")
                                        print(f"Default Input: {tr.GetConvertInput(node)}")
                                        print(f"Default Output: {tr.GetConvertOutput(node)}")
                                        print("-"*10)
                                ClearConsole()
                                ConvertTest()
                            https://boghma.com
                            • DunhouD Offline
                              Dunhou @Dunhou
                              Hi community!
                              I had add a basic support to V-Ray and Corona to fit the basic PBR usage, no Scene and AOV yet (AOV seems I can not get them in python, if someone knows where it stores, please let me know that).
                              Cheers~
                              DunHou
                              https://boghma.com
                                Hi regarding Vray, I once wrote this plugin that have the duty to create ObjectId passes.
                                I did not try it since age, but previously Vray AOV where stored within a branch on the Render Engine.
                                I don't have vray installed currently, but I guess if you compile the C++ SDK, with the help of the C++ SDK Active Object Example it should be trivial to inspect a Vray scene and find these AOV.
                                Maxime
                                DunhouD 1 Reply Last reply Reply Quote 1
                                • DunhouD Offline
                                  Dunhou @m_adam
                                  Hi community!
                                  Thanks for @m_adam prompt, I had add a AOV to Vray as same as other renderers, see a basic example here, hope it can help 😊
                                  Cheer~
                                  DunHou
                                  Result:
                                  Code:
                                  import Renderer
                                  from Renderer import Vray
                                  def modify_vray_aov():
                                      # Set Vray AOVHelper instance
                                      vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_VRAY)
                                      aov_helper = Vray.AOV(vp)
                                      diff_aov = aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_DIFFUSE)
                                      # Add some aovs
                                      aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_BACKGROUND, aov_name = 'BG'))
                                      aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SPECULAR))
                                      aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_REFLECTION))
                                      aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SHADOW))
                                      aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_LIGHT_MIX))
                                      # Remove last aov
                                      # Remove specified aov: diffuse
                                      aov_helper.remove_aov_type(aov_type = Vray.VRAY_AOV_DIFFUSE[0])
                                      modify_vray_aov()
                                  https://boghma.com
                                  • DunhouD Offline
                                    Dunhou @Dunhou
                                    Hi again,
                                    Also another Corona AOV example here .
                                    Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .
                                    The learning process was very enjoyable, hope you also have fun with it ✌
                                    Cheers~
                                    DunHou
                                    Result:
                                    Code:
                                    import Renderer
                                    from Renderer import Corona
                                    def modify_corona_aov():
                                        # Get the doc host the aovs, in this case th active doc vp
                                        vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
                                        # Set Corona AOVHelper instance
                                        aov_helper = Corona.AOV(vp)
                                        # turn on the mutipass
                                        aov_helper.enable_mutipass(True)
                                        diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
                                        # Add some aovs
                                        aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
                                        aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
                                        aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
                                        aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
                                        aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
                                        aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
                                        Corona.AovManager()
                                        modify_aorona_aov()
                                    https://boghma.com
                                    • DunhouD Offline
                                      Dunhou
                                      Hi community!
                                      New Updates here :
                                      • Fix some Octane and Corona functions (base on layer)
                                      • Add MaterialMaker and PBRPackage
                                      PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:
                                      • we have a texture pack named Rock Stone 01
                                      • this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.
                                      • we can provide the folder like D:/myTextures and its name like Rock Stone 01
                                      • then we get textures in a dictionary
                                      data = {"diffuse": Rock Stone 01_albedo.jpg,
                                                    "normal": Rock Stone 01_Normal.jpg,
                                                    "displacement": Rock Stone 01_disp.jpg,
                                                    etc...
                                      Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.
                                      But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.
                                      Cheers~
                                      DunHou
                                      https://boghma.com
                                      • DunhouD Offline
                                        Dunhou
                                        Hi community!
                                        Add Basic CentiLeo Material support, also with ConvertPorts data, This a "new" GPU Renderer and in active development. I am very interested in it.
                                        Not add AOV due to still being in the early stages of development, waiting for this.
                                        Cheers~
                                        DunHou
                                        https://boghma.com
