    Open source wrapper for Octane/Redshift/Arnold/Vray/Corona in Cinema 4D.
    programminglearning-resource
    23 Posts 7 Posters 34.4k Views 4 Watching
    • czt_306C Offline
      czt_306
      amazing!
      DunhouD 1 Reply Last reply Reply Quote 0
      • DunhouD Dunhou referenced this topic on
      • DunhouD Offline
        Dunhou @czt_306
        Hi community!
        New versions here!
        I had change the name from renderEngine to Renderer, and also changed the main structure. see more in the very first of this topic. (renderEngine had been move to versions folder, if you still interested.)
        This version is way more organized and user-friendly, you can use few lines of code to do something normal work, find an example below:
        Cheers~
        DunHou
        Result:
        Code:
        import maxon
        from Renderer import Redshift, EasyTransaction, TextureHelper
        tex_helper: TextureHelper = TextureHelper()
        disp: maxon.Url = tex_helper.GetAssetUrl("file_fa9c42774dd05049")
        def HowToUse():
            material: c4d.BaseMaterial = Redshift.Material("MyMaterial")
            with EasyTransaction(material) as tr:
                tr.AddDisplacementTree(filepath = disp, shadername = "DISP")
                tr.InsertMaterial()
            HowToUse()
        https://boghma.com
        https://github.com/DunHouGo
        DunhouD 1 Reply Last reply Reply Quote 2
        • DunhouD Offline
          Dunhou @Dunhou
          Hi community!
          Here is a little example of how we modify aovs in Octane, find more examples in the top.
          Have fun with it😊
          Cheers~
          DunHou
          Result:
          Codes:
          import maxon
          import Renderer
          from Renderer import Octane
          from pprint import pprint
          # How to create and modify octane aovs
          def modify_octane_aov():
              # Get the doc host the aovs, in this case th active doc
              doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
              # Set Octane AOVHelper instance
              aov_helper = Octane.AOV(doc)
              # Create a Octane aov item
              # the id can find from Renderer.constants.octane_id.py or in octane folder
              # If #name is None, defulat to type.
              diff_aov = aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_DIFFUSE)
              # Add the DIFFUSE aov we just created to the Octane aov system
              aov_helper.add_aov(diff_aov)
              # Add some aovs
              aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_POST,aov_name = 'POST'))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_D))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_I))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_D))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_I))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_WIRE))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_OBJECT_LAYER_COLOR))
              aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_VOLUME))
              # Remove last aov: volume
              aov_helper.remove_last_aov()
              # Remove specified aov: wire
              aov_helper.remove_aov_type(aov_type = Octane.RNDAOV_WIRE)
              # Add 2 custom aovs with id 1 and 2
              aov_helper.add_custom_aov(customID = 1)
              aov_helper.add_custom_aov(customID = 2)
              # Get the custom aov with id 2
              custom2 = aov_helper.get_custom_aov(customID = 2)
              if custom2:
                  print(f'We find a Custom AOV with id 2 Named{custom2.GetName()}')
              # Print current aov info
              aov_helper.print_aov()
              Renderer.ClearConsole()
              modify_octane_aov()
          https://boghma.com
          • DunhouD Offline
            Dunhou @Dunhou
            Hi community!
            Here is a little example of how we modify scene objects in Arnold, find more examples in the top.
            We want:
            • Add a Arnold Sky with hdr
            • Add a gobo light with a node-base gobo material, and a IES light
            • Add a cube and add a custom mask to the driver
            • Add a Scatter with custom instance shapes
            • Auto export proxy with a BaseObject and load back the ass file (need to save project first)
            Have fun with it😊
            Cheers~
            DunHou
            Results:
            Codes:
            import maxon
            import Renderer
            from Renderer import Arnold, TextureHelper
            # Create a TextureHelper instance
            # How to create and modify arnold scene
            def modify_arnold_scene():
                # Get the doc host the scene, in this case th active doc
                # Set arnold SceneHelper instance
                scene_helper = Arnold.Scene(doc)
                ### == Light == ###
                # Add a rig of hdr and rgb backdrop
                hdr_url: str =  tex_helper.GetAssetStr(maxon.Id("file_d21cf4cfdec8c636"))
                scene_helper.add_dome_rig(texture_path = hdr_url, rgb = c4d.Vector(0,0,0))
                # Add a light object and and some modify tags
                gobo_url: maxon.Url = tex_helper.GetAssetUrl("file_66b116a34a150e7e")
                gobo_light = scene_helper.add_gobo(texture_path = str(gobo_url), intensity=2, exposure=0)
                scene_helper.add_light_modifier(light = gobo_light, gsg_link = True, rand_color = True)
                # Add a IES light
                ies_url: str = tex_helper.GetAssetStr("file_6f300f2ba077da4a")
                ies = scene_helper.add_ies(texture_path = ies_url, intensity=1, exposure=0)
                ### == Tag == ###
                # Add a Cude object and an arnold tag with mask_name
                cube = c4d.BaseObject(c4d.Ocube)
                scene_helper.add_mask_tag(node=cube, mask_name='My Mask 01')
                doc.InsertObject(cube)
                ### == Object == ###
                # Add a scatter obejct with some children and count 12345
                generate_object = c4d.BaseObject(c4d.Oplane)
                doc.InsertObject(generate_object)
                scatter_A = c4d.BaseObject(c4d.Oplatonic)
                scatter_B = c4d.BaseObject(c4d.Ooiltank)
                doc.InsertObject(scatter_A)
                doc.InsertObject(scatter_B)
                scatters: list[c4d.BaseObject] = [scatter_A, scatter_B]
                scene_helper.add_scatter(generator_node=generate_object, scatter_nodes=scatters, count=12345)
                # Add a object and set auto proxy
                the_object = c4d.BaseObject(c4d.Oplane)
                doc.InsertObject(the_object)
                the_object.SetName("Original Object")
                scene_helper.auto_proxy(nodes=the_object,remove_objects=False)
            https://boghma.com
            • DunhouD Offline
              Dunhou @Dunhou
              Hi community!
              Another little update, as we didn't have DataDescriptionDatabaseInterface as @ferdinand said in How can we get the default port of a GraphNode?
              I add a ConverterPorts to Renderer, we can use this to get the "default " port of a node until the DataDescriptionDatabaseInterface is valid in python.
              Note: It can only provide the str data of the port and it's not 100% rigorous
              Cheers~
              DunHou
              Result:
              Codes:
              from Renderer import Redshift,EasyTransaction,ClearConsole
              def ConvertTest():
                  material: c4d.BaseMaterial = c4d.documents.GetActiveDocument().GetActiveMaterial()
                      nodes = tr.GetActiveNodes()
                      for node in nodes:
                          print(f"Node: {tr.GetName(node)}")
                          print(f"Default Input: {tr.GetConvertInput(node)}")
                          print(f"Default Output: {tr.GetConvertOutput(node)}")
                          print("-"*10)
                  ClearConsole()
                  ConvertTest()
              https://boghma.com
              • DunhouD Offline
                Dunhou @Dunhou
                Hi community!
                I had add a basic support to V-Ray and Corona to fit the basic PBR usage, no Scene and AOV yet (AOV seems I can not get them in python, if someone knows where it stores, please let me know that).
                Cheers~
                DunHou
                https://boghma.com
                  Hi regarding Vray, I once wrote this plugin that have the duty to create ObjectId passes.
                  I did not try it since age, but previously Vray AOV where stored within a branch on the Render Engine.
                  I don't have vray installed currently, but I guess if you compile the C++ SDK, with the help of the C++ SDK Active Object Example it should be trivial to inspect a Vray scene and find these AOV.
                  Maxime
                  DunhouD 1 Reply Last reply Reply Quote 1
                  • DunhouD Offline
                    Dunhou @m_adam
                    Hi community!
                    Thanks for @m_adam prompt, I had add a AOV to Vray as same as other renderers, see a basic example here, hope it can help 😊
                    Cheer~
                    DunHou
                    Result:
                    Code:
                    import Renderer
                    from Renderer import Vray
                    def modify_vray_aov():
                        # Set Vray AOVHelper instance
                        vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_VRAY)
                        aov_helper = Vray.AOV(vp)
                        diff_aov = aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_DIFFUSE)
                        # Add some aovs
                        aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_BACKGROUND, aov_name = 'BG'))
                        aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SPECULAR))
                        aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_REFLECTION))
                        aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SHADOW))
                        aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_LIGHT_MIX))
                        # Remove last aov
                        # Remove specified aov: diffuse
                        aov_helper.remove_aov_type(aov_type = Vray.VRAY_AOV_DIFFUSE[0])
                        modify_vray_aov()
                    https://boghma.com
                    • DunhouD Offline
                      Dunhou @Dunhou
                      Hi again,
                      Also another Corona AOV example here .
                      Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .
                      The learning process was very enjoyable, hope you also have fun with it ✌
                      Cheers~
                      DunHou
                      Result:
                      Code:
                      import Renderer
                      from Renderer import Corona
                      def modify_corona_aov():
                          # Get the doc host the aovs, in this case th active doc vp
                          vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
                          # Set Corona AOVHelper instance
                          aov_helper = Corona.AOV(vp)
                          # turn on the mutipass
                          aov_helper.enable_mutipass(True)
                          diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
                          # Add some aovs
                          aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
                          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
                          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
                          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
                          aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
                          aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
                          Corona.AovManager()
                          modify_aorona_aov()
                      https://boghma.com
                      • DunhouD Offline
                        Dunhou
                        Hi community!
                        New Updates here :
                        • Fix some Octane and Corona functions (base on layer)
                        • Add MaterialMaker and PBRPackage
                        PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:
                        • we have a texture pack named Rock Stone 01
                        • this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.
                        • we can provide the folder like D:/myTextures and its name like Rock Stone 01
                        • then we get textures in a dictionary
                        data = {"diffuse": Rock Stone 01_albedo.jpg,
                                      "normal": Rock Stone 01_Normal.jpg,
                                      "displacement": Rock Stone 01_disp.jpg,
                                      etc...
                        Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.
                        But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.
                        Cheers~
                        DunHou
                        https://boghma.com
                        • DunhouD Offline
                          Dunhou
                          Hi community!
                          Add Basic CentiLeo Material support, also with ConvertPorts data, This a "new" GPU Renderer and in active development. I am very interested in it.
                          Not add AOV due to still being in the early stages of development, waiting for this.
                          Cheers~
                          DunHou
                          https://boghma.com
