    Open source wrapper for Octane/Redshift/Arnold/Vray/Corona in Cinema 4D.
    programminglearning-resource
    23 Posts 7 Posters 34.4k Views 4 Watching
    • T Offline
      thomas
      this looks amazing. Can't wait to see arnold / RS
      DunhouD 1 Reply Last reply Reply Quote 0
      • DunhouD Offline
        Dunhou @ferdinand
        Hey @ferdinand , that's very honor to contribute to the community, and also thanks for your pin, that inspire me a lot too.
        And a little plan I want to take your advice, what do you think the next update I should post, should I edit the first post, or just update the links when redshift/arnold is ready, and reply to the topic to show the main changes? which is better for more read convinence?
        Cheers~
        DunHou
        https://boghma.com
        https://github.com/DunHouGo
        • DunhouD Offline
          Dunhou @thomas
          Hey @thomas , thanks for your like, redshift_helper is 80% for beta I think, I will try to post ASAP.
          Cheers~
          DunHou
          https://boghma.com
          • DunhouD Offline
            Dunhou
            Hi community!
            the renderEngine helper is beta now, I set version number to 1.0.0, it contains three renderer now:
            • Octane
            • Arnold ( MaterialHelper only support NodeGragh )
            • Redshift ( MaterialHelper only support NodeGragh )
            I personally not use Vray and Corona quite often, if anyone is a pro user of these , very welcome to add them to renderEngine
            You can modify the aovs/materials with renderEngine quickly and easliy . See the examples above this topic.
            Hope you can have fun with it, and any improvement and fix is very appreciated.
            Cheers~
            DunHou
            https://boghma.com
            • T Offline
              thomas
              @Dunhou is it possible to get in touch for you for freelance development? I couldn't find any email or socials.
              • DunhouD Offline
                Dunhou @thomas
                @thomas Hi, I had update my github readme file, and put my email on it😊
                Cheers~
                DunHou
                https://boghma.com
                • DunhouD Dunhou referenced this topic on
                • DunhouD Offline
                  Dunhou
                  Hi community!
                  Th renderEngine library has been updated to the 1.0.4 version, there are some re-write functions and may not incompatible with older versions,see the main changes as follows:
                  • rename all node & material functions to Capitalize style.
                  • remove transaction in node_helper, use it in the final scripts.
                  • organize the functions in node_helper with comments ( node\port\wire\util )
                  • add some functions to check node or port info, like if it is connected , see the README.
                  • add a InserShader function to create a shader into a wire.
                  • re-write RemoveConnection in node_helper and support one argument(port) to remove connection.
                  • see the Version & Updates
                  Cheers~
                  DunHou
                  https://boghma.com
                  • DunhouD Offline
                    Dunhou
                    Hi community!
                    Since my last post, I had some updates and fix to this library.
                    And the following picture shows the new node functions added to my Render Flow plugin based on the use of this library within few lines( just the node context ).
                    Have fun with it.
                    Cheers~
                    DunHou
                    https://boghma.com
                    gheyretG 1 Reply Last reply Reply Quote 3
                    • gheyretG Offline
                      gheyret @Dunhou
                      @Dunhou
                      It's realy cool and usefull, keep going bro šŸ»
                      www.boghma.com
                        mogh
                        Wow ... good stuff
                        My c4d Programing slowed down this year, but this might be something I want to use some day ...
                        • czt_306C Offline
                          czt_306
                          amazing!
                          • DunhouD Offline
                            Dunhou @czt_306
                            Hi community!
                            New versions here!
                            I had change the name from renderEngine to Renderer, and also changed the main structure. see more in the very first of this topic. (renderEngine had been move to versions folder, if you still interested.)
                            This version is way more organized and user-friendly, you can use few lines of code to do something normal work, find an example below:
                            Cheers~
                            DunHou
                            Result:
                            Code:
                            import maxon
                            from Renderer import Redshift, EasyTransaction, TextureHelper
                            tex_helper: TextureHelper = TextureHelper()
                            disp: maxon.Url = tex_helper.GetAssetUrl("file_fa9c42774dd05049")
                            def HowToUse():
                                material: c4d.BaseMaterial = Redshift.Material("MyMaterial")
                                with EasyTransaction(material) as tr:
                                    tr.AddDisplacementTree(filepath = disp, shadername = "DISP")
                                    tr.InsertMaterial()
                                HowToUse()
                            https://boghma.com
                            DunhouD 1 Reply Last reply Reply Quote 2
                            • DunhouD Offline
                              Dunhou @Dunhou
                              Hi community!
                              Here is a little example of how we modify aovs in Octane, find more examples in the top.
                              Have fun with it😊
                              Cheers~
                              DunHou
                              Result:
                              Codes:
                              import maxon
                              import Renderer
                              from Renderer import Octane
                              from pprint import pprint
                              # How to create and modify octane aovs
                              def modify_octane_aov():
                                  # Get the doc host the aovs, in this case th active doc
                                  doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
                                  # Set Octane AOVHelper instance
                                  aov_helper = Octane.AOV(doc)
                                  # Create a Octane aov item
                                  # the id can find from Renderer.constants.octane_id.py or in octane folder
                                  # If #name is None, defulat to type.
                                  diff_aov = aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_DIFFUSE)
                                  # Add the DIFFUSE aov we just created to the Octane aov system
                                  aov_helper.add_aov(diff_aov)
                                  # Add some aovs
                                  aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_POST,aov_name = 'POST'))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_D))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_I))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_D))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_I))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_WIRE))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_OBJECT_LAYER_COLOR))
                                  aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_VOLUME))
                                  # Remove last aov: volume
                                  aov_helper.remove_last_aov()
                                  # Remove specified aov: wire
                                  aov_helper.remove_aov_type(aov_type = Octane.RNDAOV_WIRE)
                                  # Add 2 custom aovs with id 1 and 2
                                  aov_helper.add_custom_aov(customID = 1)
                                  aov_helper.add_custom_aov(customID = 2)
                                  # Get the custom aov with id 2
                                  custom2 = aov_helper.get_custom_aov(customID = 2)
                                  if custom2:
                                      print(f'We find a Custom AOV with id 2 Named{custom2.GetName()}')
                                  # Print current aov info
                                  aov_helper.print_aov()
                                  Renderer.ClearConsole()
                                  modify_octane_aov()
                              https://boghma.com
                              • DunhouD Offline
                                Dunhou @Dunhou
                                Hi community!
                                Here is a little example of how we modify scene objects in Arnold, find more examples in the top.
                                We want:
                                • Add a Arnold Sky with hdr
                                • Add a gobo light with a node-base gobo material, and a IES light
                                • Add a cube and add a custom mask to the driver
                                • Add a Scatter with custom instance shapes
                                • Auto export proxy with a BaseObject and load back the ass file (need to save project first)
                                Have fun with it😊
                                Cheers~
                                DunHou
                                Results:
                                Codes:
                                import maxon
                                import Renderer
                                from Renderer import Arnold, TextureHelper
                                # Create a TextureHelper instance
                                # How to create and modify arnold scene
                                def modify_arnold_scene():
                                    # Get the doc host the scene, in this case th active doc
                                    # Set arnold SceneHelper instance
                                    scene_helper = Arnold.Scene(doc)
                                    ### == Light == ###
                                    # Add a rig of hdr and rgb backdrop
                                    hdr_url: str =  tex_helper.GetAssetStr(maxon.Id("file_d21cf4cfdec8c636"))
                                    scene_helper.add_dome_rig(texture_path = hdr_url, rgb = c4d.Vector(0,0,0))
                                    # Add a light object and and some modify tags
                                    gobo_url: maxon.Url = tex_helper.GetAssetUrl("file_66b116a34a150e7e")
                                    gobo_light = scene_helper.add_gobo(texture_path = str(gobo_url), intensity=2, exposure=0)
                                    scene_helper.add_light_modifier(light = gobo_light, gsg_link = True, rand_color = True)
                                    # Add a IES light
                                    ies_url: str = tex_helper.GetAssetStr("file_6f300f2ba077da4a")
                                    ies = scene_helper.add_ies(texture_path = ies_url, intensity=1, exposure=0)
                                    ### == Tag == ###
                                    # Add a Cude object and an arnold tag with mask_name
                                    cube = c4d.BaseObject(c4d.Ocube)
                                    scene_helper.add_mask_tag(node=cube, mask_name='My Mask 01')
                                    doc.InsertObject(cube)
                                    ### == Object == ###
                                    # Add a scatter obejct with some children and count 12345
                                    generate_object = c4d.BaseObject(c4d.Oplane)
                                    doc.InsertObject(generate_object)
                                    scatter_A = c4d.BaseObject(c4d.Oplatonic)
                                    scatter_B = c4d.BaseObject(c4d.Ooiltank)
                                    doc.InsertObject(scatter_A)
                                    doc.InsertObject(scatter_B)
                                    scatters: list[c4d.BaseObject] = [scatter_A, scatter_B]
                                    scene_helper.add_scatter(generator_node=generate_object, scatter_nodes=scatters, count=12345)
                                    # Add a object and set auto proxy
                                    the_object = c4d.BaseObject(c4d.Oplane)
                                    doc.InsertObject(the_object)
                                    the_object.SetName("Original Object")
                                    scene_helper.auto_proxy(nodes=the_object,remove_objects=False)
                                https://boghma.com
                                • DunhouD Offline
                                  Dunhou @Dunhou
                                  Hi community!
                                  Another little update, as we didn't have DataDescriptionDatabaseInterface as @ferdinand said in How can we get the default port of a GraphNode?
                                  I add a ConverterPorts to Renderer, we can use this to get the "default " port of a node until the DataDescriptionDatabaseInterface is valid in python.
                                  Note: It can only provide the str data of the port and it's not 100% rigorous
                                  Cheers~
                                  DunHou
                                  Result:
                                  Codes:
                                  from Renderer import Redshift,EasyTransaction,ClearConsole
                                  def ConvertTest():
                                      material: c4d.BaseMaterial = c4d.documents.GetActiveDocument().GetActiveMaterial()
                                          nodes = tr.GetActiveNodes()
                                          for node in nodes:
                                              print(f"Node: {tr.GetName(node)}")
                                              print(f"Default Input: {tr.GetConvertInput(node)}")
                                              print(f"Default Output: {tr.GetConvertOutput(node)}")
                                              print("-"*10)
                                      ClearConsole()
                                      ConvertTest()
                                  https://boghma.com
                                  • DunhouD Offline
                                    Dunhou @Dunhou
                                    Hi community!
                                    I had add a basic support to V-Ray and Corona to fit the basic PBR usage, no Scene and AOV yet (AOV seems I can not get them in python, if someone knows where it stores, please let me know that).
                                    Cheers~
                                    DunHou
                                    https://boghma.com
                                      Hi regarding Vray, I once wrote this plugin that have the duty to create ObjectId passes.
                                      I did not try it since age, but previously Vray AOV where stored within a branch on the Render Engine.
                                      I don't have vray installed currently, but I guess if you compile the C++ SDK, with the help of the C++ SDK Active Object Example it should be trivial to inspect a Vray scene and find these AOV.
                                      Maxime
                                      DunhouD 1 Reply Last reply Reply Quote 1
                                      • DunhouD Offline
                                        Dunhou @m_adam
                                        Hi community!
                                        Thanks for @m_adam prompt, I had add a AOV to Vray as same as other renderers, see a basic example here, hope it can help 😊
                                        Cheer~
                                        DunHou
                                        Result:
                                        Code:
                                        import Renderer
                                        from Renderer import Vray
                                        def modify_vray_aov():
                                            # Set Vray AOVHelper instance
                                            vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_VRAY)
                                            aov_helper = Vray.AOV(vp)
                                            diff_aov = aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_DIFFUSE)
                                            # Add some aovs
                                            aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_BACKGROUND, aov_name = 'BG'))
                                            aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SPECULAR))
                                            aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_REFLECTION))
                                            aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SHADOW))
                                            aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_LIGHT_MIX))
                                            # Remove last aov
                                            # Remove specified aov: diffuse
                                            aov_helper.remove_aov_type(aov_type = Vray.VRAY_AOV_DIFFUSE[0])
                                            modify_vray_aov()
                                        https://boghma.com
                                        • DunhouD Offline
                                          Dunhou @Dunhou
                                          Hi again,
                                          Also another Corona AOV example here .
                                          Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .
                                          The learning process was very enjoyable, hope you also have fun with it ✌
                                          Cheers~
                                          DunHou
                                          Result:
                                          Code:
                                          import Renderer
                                          from Renderer import Corona
                                          def modify_corona_aov():
                                              # Get the doc host the aovs, in this case th active doc vp
                                              vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
                                              # Set Corona AOVHelper instance
                                              aov_helper = Corona.AOV(vp)
                                              # turn on the mutipass
                                              aov_helper.enable_mutipass(True)
                                              diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
                                              # Add some aovs
                                              aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
                                              aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
                                              aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
                                              aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
                                              aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
                                              aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
                                              Corona.AovManager()
                                              modify_aorona_aov()
                                          https://boghma.com
                                          • DunhouD Offline
                                            Dunhou
                                            Hi community!
                                            New Updates here :
                                            • Fix some Octane and Corona functions (base on layer)
                                            • Add MaterialMaker and PBRPackage
                                            PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:
                                            • we have a texture pack named Rock Stone 01
                                            • this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.
                                            • we can provide the folder like D:/myTextures and its name like Rock Stone 01
                                            • then we get textures in a dictionary
                                            data = {"diffuse": Rock Stone 01_albedo.jpg,
                                                          "normal": Rock Stone 01_Normal.jpg,
                                                          "displacement": Rock Stone 01_disp.jpg,
                                                          etc...
                                            Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.
                                            But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.
                                            Cheers~
                                            DunHou
                                            https://boghma.com
