<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D.]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<pre><code class="language-txt">Older version called renderEngine had been move to versions folder, if you are still interested.
</code></pre>
<p dir="auto"><a href="https://github.com/DunHouGo/renderEngine" target="_blank" rel="noopener noreferrer nofollow ugc">Renderer </a>is a wrapper class for the <code>maxon</code> and <code>c4d</code> api of popular render engine for Cinema 4D.</p>
<p dir="auto">Intended for more user-friendly manipulation of node materials with the new <strong>maxon.GraphNode</strong> model. And also with <strong>Octane Material</strong>.</p>
<p dir="auto">Provide helper class for convenient access <strong>AOV</strong> , <strong>Material</strong> , <strong>Scene Object</strong>(Object/Tag/Light/...) in Cinema 4D popular renderer.</p>
<p dir="auto">I try to keep it as same as possible, but each renderer has their own logic, so there are some compromises.</p>
<p dir="auto">Happy Rendering and Scpriting!<img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
<p dir="auto">Cheers~<br />
DunHou</p>
<hr />
<h2>Renderer</h2>
<p dir="auto">This is a custom wrapper for most popular render engine like Octane\Redshift\Arnold\Corona\VRay in Cinema 4D, which is also contains in <strong>boghma</strong> library.</p>
<pre><code class="language-txt">All the boghma plugins and boghma library is FREE.
</code></pre>
<h2>Supported Renderer</h2>
<ul>
<li>Octane</li>
<li>Corona</li>
<li>Node Materials with the new GraphNode model</li>
<li>Redshift ( Only Node Material for Material Helper)</li>
<li>Arnold ( Only Node Material for Material Helper)</li>
<li>Vray ( Only Node Material for Material Helper)</li>
</ul>
<h2>Installation</h2>
<ol>
<li>(<strong>Recommend</strong>) Download <a href="https://storage.boghma.com/c4d/plugins-manager/main/boghma-plugins-manager-v1.0.1.zip" target="_blank" rel="noopener noreferrer nofollow ugc">Boghma Plugin Manager</a> and install any plugin, the boghma lib will auto installed or updated.</li>
<li>Download the source code and import it to your Cinema 4D.</li>
</ol>
<h1>Quick Intro</h1>
<pre><code class="language-python">
import maxon
from Renderer import Redshift, EasyTransaction, TextureHelper
from pprint import pprint
# Create a TextureHelper instance
# 创建一个 TextureHelper 实例
tex_helper: TextureHelper = TextureHelper()
# Get the url with given asset id
# 获取给定资产ID的URL
# "si-v1_fingerprints_02_15cm.png" with AssetId : file_fa9c42774dd05049
disp: maxon.Url = tex_helper.GetAssetUrl("file_fa9c42774dd05049")
def HowToUse():
    How to reate a redshift material and modify the gragh with EasyTransaction.
    # Create Redshift Node Material instance, if no material filled, we create a new STD material
    # 创建一个Redshift节点材质实例,如果没有材质传入，创建新的STD材质
    material: c4d.BaseMaterial = Redshift.Material("MyMaterial")
    # Use EasyTransaction to modify the graph
    # 使用EasyTransaction来修改材质
    with EasyTransaction(material) as tr:
        # the attribute #tr is the instance of Redshift.MaterialHelper,
        # we got it with just apply to the #material to the EasyTransaction
        # it will inherit from NodeGraghHelper class
        # 属性tr是Redshift.MaterialHelper的实例，通过将材质赋予EasyTransaction获得，继承自NodeGraghHelper
        # Use Redshift.MaterialHelper methods : add a texture + displacement to the Output node
        # 使用Redshift.MaterialHelper中的方法: 添加图片+置换节点到Output节点
        tr.AddDisplacementTree(filepath = disp, shadername = "DISP")
        # Use NodeGraghHelper methods： get the Output(endNode)
        # 使用NodeGraghHelper中的方法: 获取输出节点
        output = tr.GetOutput()
        print(f"{output = }")
        # Insert the material to the document
        # 导入材质(来自Redshift MaterialHelper)
        tr.InsertMaterial()
    # Auto apply GraphTransaction.Commit() to the graph
    # 退出with后, 自动执行GraphTransaction.Commit()
</code></pre>
<h1>Limit</h1>
<ul>
<li>For some reasons, AddShader-like methods(maxon.GraphModelInterface.AddChild) will add the node in the center of the graph, if we call those methods on exsited material, it will return a mess graph, you can call Renderer.ArrangeAll() after.</li>
<li>Material(except Octane) helper only support material with the new GraphNode model(Node Material after R26)</li>
<li>Due to Octane use his Custom UserArea UI base on old layer system, and didn't support python, we can only modify Octane materials in material level, but can not interactive with selections in octane node editor.</li>
<li>Also Octane materials didn't have a "port" or "wire" context, we can not use all those methods as same as NodeGraghHelper.</li>
<li>Arnold mask tag SetPrameter has a refresh bug.</li>
</ul>
<h1>Examples</h1>
<ul>
<li><a href="https://github.com/DunHouGo/renderEngine/blob/main/tests/01_material_basic.py" target="_blank" rel="noopener noreferrer nofollow ugc"><strong>Material Example</strong></a></li>
<li><a href="https://github.com/DunHouGo/renderEngine/blob/main/tests/02_aov_basic.py" target="_blank" rel="noopener noreferrer nofollow ugc"><strong>AOV Example</strong></a></li>
<li><a href="https://github.com/DunHouGo/renderEngine/blob/main/tests/03_scene_basic.py" target="_blank" rel="noopener noreferrer nofollow ugc"><strong>Scene Example</strong> </a></li>
</ul>
<h1>Class Presentation and Highlights</h1>
<p dir="auto">Renderer</p>
<ul>
<li>NodeGraghHelper</li>
<li>TextureHelper</li>
<li>EasyTransaction</li>
<li>Redshift
<ul>
<li>AOV</li>
<li>Material</li>
<li>Scene</li>
</ul>
</li>
<li>Octane
<ul>
<li>AOV</li>
<li>Material</li>
<li>Scene</li>
</ul>
</li>
<li>Arnold
<ul>
<li>AOV</li>
<li>Material</li>
<li>Scene</li>
</ul>
</li>
<li>Vray
<ul>
<li>AOV</li>
<li>Material</li>
</ul>
</li>
<li>Corona
<ul>
<li>AOV</li>
<li>Material</li>
</ul>
</li>
<li>utils
<ul>
</ul>
</li>
<li>constants</li>
</ul>
<h1>Version &amp; Updates</h1>
<ul>
<li><a href="https://github.com/DunHouGo/renderEngine/blob/main/ChangeLog.md" target="_blank" rel="noopener noreferrer nofollow ugc">Change Log</a></li>
</ul>
]]></description><link>http://developers.maxon.net/forum/topic/14842/open-source-wrapper-for-octane-redshift-arnold-vray-corona-in-cinema-4d</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 11:28:20 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/14842.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Jun 2023 07:46:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 11 Aug 2024 10:09:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Add Basic <a href="https://centileo.com/" target="_blank" rel="noopener noreferrer nofollow ugc">CentiLeo</a> Material support,  also with ConvertPorts data, This a "new" GPU Renderer and in active development. I am very interested in it.</p>
<p dir="auto">Not add AOV due to still being in the early stages of development, waiting for this.</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/74741</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74741</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 11 Aug 2024 10:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Mon, 08 Jul 2024 02:10:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">New Updates here :</p>
<ul>
<li>Fix some Octane and Corona functions (base on layer)</li>
<li>Add MaterialMaker and PBRPackage</li>
</ul>
<p dir="auto">PBRPackage means a suite of pbr textures, like a stone texture pack form PolyHaven or Megascan, you can provide the folder and the name to get the slot they should be:</p>
<ul>
<li>we have a texture pack named Rock Stone 01</li>
<li>this package had some textures in D:/myTextures ,like Rock Stone 01_albedo.jpg/Rock Stone 01_Normal.png/Rock Stone 01_disp.exr.</li>
<li>we can provide the folder like D:/myTextures and its name like Rock Stone 01</li>
<li>then we get textures in a dictionary</li>
</ul>
<pre><code class="language-python">data = {"diffuse": Rock Stone 01_albedo.jpg,
              "normal": Rock Stone 01_Normal.jpg,
              "displacement": Rock Stone 01_disp.jpg,
              etc...
</code></pre>
<p dir="auto">Material Maker can easily add pbr materials from a package, and also you can use it with individuals textures.</p>
<p dir="auto">But all of this build with this library, so only node materials on Redshift/Arnold/Vray, Octane and Corona is supported by thier own logics.</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/74543</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74543</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Mon, 08 Jul 2024 02:10:51 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 05 May 2024 14:33:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi again,</p>
<p dir="auto">Also another Corona AOV example here .</p>
<p dir="auto">Finally preliminarily implemented using this library to approximate the operation of the renderer in Cinema 4D .</p>
<p dir="auto">The learning process was very enjoyable, hope you also have fun with it <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/270c.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--v" style="height:23px;width:auto;vertical-align:middle" title=":v:" alt="✌" /></p>
DunHou</p>
<hr />
<h3>Result:</h3>
<p dir="auto"><img src="/forum/assets/uploads/files/1714919179846-3a357d30-a82d-4905-94ca-b914295cb296-image.png" alt="3a357d30-a82d-4905-94ca-b914295cb296-image.png" class=" img-fluid img-markdown" /></p>
<h3>Code:</h3>
<pre><code class="language-python">import c4d
import Renderer
from Renderer import Corona
def modify_corona_aov():
    # Get the doc host the aovs, in this case th active doc vp
    doc: c4d.documents.BaseDocument = c4d.documents.GetActiveDocument()
    vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_CORONA)
    # Set Corona AOVHelper instance
    aov_helper = Corona.AOV(vp)
    # turn on the mutipass
    aov_helper.enable_mutipass(True)
    # Add the DIFFUSE aov
    diff_aov = aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_ALBEDO)
    aov_helper.add_aov(diff_aov)
    # Add some aovs
    aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Corona.CORONA_MULTIPASS_TYPE_EMISSION, aov_name = 'emmision aov'))
    aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFLECT))
    aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_REFRACT))
    aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY))
    aov_helper.add_aov(aov_helper.create_aov_shader(Corona.CORONA_MULTIPASS_TYPE_ZDEPTH))
    # Remove last aov: volume
    aov_helper.remove_last_aov()
    # Remove specified aov: wire
    aov_helper.remove_aov_type(aov_type = Corona.CORONA_MULTIPASS_TYPE_TRANSLUCENCY)
    # Print current aov info
    aov_helper.print_aov()
    Corona.AovManager()
    Renderer.ClearConsole()
    modify_aorona_aov()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/74270</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74270</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 05 May 2024 14:33:22 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 05 May 2024 10:42:26 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Thanks for <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/m_adam">@<bdi>m_adam</bdi></a> prompt, I had add a <strong>AOV</strong> to <strong>Vray</strong> as same as other renderers, see a basic example here, hope it can help <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
<p dir="auto">Cheer~<br />
DunHou</p>
<hr />
<h3>Result:</h3>
<p dir="auto"><img src="/forum/assets/uploads/files/1714905519994-3b1dfcb9-efb4-4dcc-a65f-a4800c3b9517-image.png" alt="3b1dfcb9-efb4-4dcc-a65f-a4800c3b9517-image.png" class=" img-fluid img-markdown" /></p>
<h3>Code:</h3>
import Renderer
from Renderer import Vray
def modify_vray_aov():
    # Set Vray AOVHelper instance
    vp: c4d.documents.BaseVideoPost = Renderer.GetVideoPost(doc, Renderer.ID_VRAY)
    aov_helper = Vray.AOV(vp)
    diff_aov = aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_DIFFUSE)
    # Add some aovs
    aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Vray.VRAY_AOV_BACKGROUND, aov_name = 'BG'))
    aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SPECULAR))
    aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_REFLECTION))
    aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_SHADOW))
    aov_helper.add_aov(aov_helper.create_aov_shader(Vray.VRAY_AOV_LIGHT_MIX))
    # Remove last aov
    # Remove specified aov: diffuse
    aov_helper.remove_aov_type(aov_type = Vray.VRAY_AOV_DIFFUSE[0])
    modify_vray_aov()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/74268</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74268</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 05 May 2024 10:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Thu, 02 May 2024 08:08:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi regarding Vray, I once wrote <a href="https://github.com/gr4ph0s/EasyObjectId_V2/blob/master/source/Render/VrayRenderEngine.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">this plugin</a> that have the duty to create ObjectId passes.<br />
I did not try it since age, but previously Vray AOV where stored within a branch on the Render Engine.</p>
<p dir="auto">I don't have vray installed currently, but I guess if you compile the <a href="https://developers.maxon.net/downloads/" target="_blank" rel="noopener noreferrer nofollow ugc">C++ SDK</a>, with the help of the <a href="https://github.com/PluginCafe/cinema4d_cpp_sdk_extended/blob/master/plugins/example.main/source/gui/activeobject.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">C++ SDK Active Object Example</a> it should be trivial to inspect a Vray scene and find these AOV.</p>
<p dir="auto">Cheers,<br />
Maxime</p>
]]></description><link>http://developers.maxon.net/forum/post/74241</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74241</guid><dc:creator><![CDATA[m_adam]]></dc:creator><pubDate>Thu, 02 May 2024 08:08:25 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Thu, 02 May 2024 04:36:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">I had add a basic support to V-Ray and Corona to fit the basic PBR usage, no Scene and AOV yet (AOV seems I can not get them in python, if someone knows where it stores, please let me know that).</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/74240</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74240</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Thu, 02 May 2024 04:36:01 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Mon, 01 Apr 2024 17:20:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Another little update, as we didn't have <strong>DataDescriptionDatabaseInterface</strong> as <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a> said in <a href="https://developers.maxon.net/forum/topic/15404/how-can-we-get-the-default-port-of-a-graphnode/7" target="_blank" rel="noopener noreferrer nofollow ugc"> How can we get the default port of a GraphNode?</a></p>
<p dir="auto">I add a <strong><a href="https://github.com/DunHouGo/renderEngine/blob/main/utils/node_helper.py#L665" target="_blank" rel="noopener noreferrer nofollow ugc">ConverterPorts</a></strong> to <strong>Renderer</strong>,  we can use this to get the "default " port of a node until the <strong>DataDescriptionDatabaseInterface</strong> is valid in python.</p>
<p dir="auto"><s>Note: It can only provide the str data of the port and it's not 100% rigorous</s></p>
DunHou</p>
<hr />
<h3>Result:</h3>
<p dir="auto"><img src="/forum/assets/uploads/files/1711982966316-ef6aaffd-aa4f-4def-9b4e-e626bda37c51-image.png" alt="ef6aaffd-aa4f-4def-9b4e-e626bda37c51-image.png" class=" img-fluid img-markdown" /></p>
<h3>Codes:</h3>
from Renderer import Redshift,EasyTransaction,ClearConsole
def ConvertTest():
    material: c4d.BaseMaterial = c4d.documents.GetActiveDocument().GetActiveMaterial()
        nodes = tr.GetActiveNodes()
        for node in nodes:
            print(f"Node: {tr.GetName(node)}")
            print(f"Default Input: {tr.GetConvertInput(node)}")
            print(f"Default Output: {tr.GetConvertOutput(node)}")
            print("-"*10)
    ClearConsole()
    ConvertTest()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/74046</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/74046</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Mon, 01 Apr 2024 17:20:05 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Thu, 25 Jan 2024 03:25:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Here is a little example of how we modify scene objects in Arnold, find more examples in the top.</p>
<p dir="auto">We want:</p>
<ul>
<li>Add a Arnold Sky with hdr</li>
<li>Add a gobo light with a node-base gobo material, and a IES light</li>
<li>Add a cube and add a custom mask to the driver</li>
<li>Add a Scatter with custom instance shapes</li>
<li>Auto export proxy with a BaseObject and load back the ass file (need to save project first)</li>
</ul>
<p dir="auto">Have fun with it<img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title="😊" alt="😊" /></p>
DunHou</p>
<h3>Results:</h3>
<p dir="auto"><img src="/forum/assets/uploads/files/1706152688321-63288895-1f52-49f3-8a3e-5a691c394d8f-image.png" alt="63288895-1f52-49f3-8a3e-5a691c394d8f-image.png" class=" img-fluid img-markdown" /><br />
<img src="/forum/assets/uploads/files/1706153038997-8cfd5b22-0bbe-42f5-b949-86aa3d19591a-image.png" alt="8cfd5b22-0bbe-42f5-b949-86aa3d19591a-image.png" class=" img-fluid img-markdown" /></p>
<h3>Codes:</h3>
import maxon
import Renderer
from Renderer import Arnold, TextureHelper
# How to create and modify arnold scene
def modify_arnold_scene():
    # Get the doc host the scene, in this case th active doc
    # Set arnold SceneHelper instance
    scene_helper = Arnold.Scene(doc)
    ### == Light == ###
    # Add a rig of hdr and rgb backdrop
    hdr_url: str =  tex_helper.GetAssetStr(maxon.Id("file_d21cf4cfdec8c636"))
    scene_helper.add_dome_rig(texture_path = hdr_url, rgb = c4d.Vector(0,0,0))
    # Add a light object and and some modify tags
    gobo_url: maxon.Url = tex_helper.GetAssetUrl("file_66b116a34a150e7e")
    gobo_light = scene_helper.add_gobo(texture_path = str(gobo_url), intensity=2, exposure=0)
    scene_helper.add_light_modifier(light = gobo_light, gsg_link = True, rand_color = True)
    # Add a IES light
    ies_url: str = tex_helper.GetAssetStr("file_6f300f2ba077da4a")
    ies = scene_helper.add_ies(texture_path = ies_url, intensity=1, exposure=0)
    ### == Tag == ###
    # Add a Cude object and an arnold tag with mask_name
    cube = c4d.BaseObject(c4d.Ocube)
    scene_helper.add_mask_tag(node=cube, mask_name='My Mask 01')
    doc.InsertObject(cube)
    ### == Object == ###
    # Add a scatter obejct with some children and count 12345
    generate_object = c4d.BaseObject(c4d.Oplane)
    doc.InsertObject(generate_object)
    scatter_A = c4d.BaseObject(c4d.Oplatonic)
    scatter_B = c4d.BaseObject(c4d.Ooiltank)
    doc.InsertObject(scatter_A)
    doc.InsertObject(scatter_B)
    scatters: list[c4d.BaseObject] = [scatter_A, scatter_B]
    scene_helper.add_scatter(generator_node=generate_object, scatter_nodes=scatters, count=12345)
    # Add a object and set auto proxy
    the_object = c4d.BaseObject(c4d.Oplane)
    doc.InsertObject(the_object)
    the_object.SetName("Original Object")
    scene_helper.auto_proxy(nodes=the_object,remove_objects=False)
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/73607</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73607</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Thu, 25 Jan 2024 03:25:10 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Thu, 25 Jan 2024 03:06:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Here is a little example of how we modify aovs in Octane,  find more examples in the top.</p>
<p dir="auto">Have fun with it<img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
DunHou</p>
<h3>Result:</h3>
<p dir="auto"><img src="/forum/assets/uploads/files/1706151578642-a25ad801-72c0-4e10-9572-e4e20541d0e3-image-resized.png" alt="a25ad801-72c0-4e10-9572-e4e20541d0e3-image.png" class=" img-fluid img-markdown" /></p>
<h3>Codes:</h3>
import maxon
import Renderer
from Renderer import Octane
# How to create and modify octane aovs
def modify_octane_aov():
    # Set Octane AOVHelper instance
    aov_helper = Octane.AOV(doc)
    # Create a Octane aov item
    # the id can find from Renderer.constants.octane_id.py or in octane folder
    # If #name is None, defulat to type.
    diff_aov = aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_DIFFUSE)
    # Add the DIFFUSE aov we just created to the Octane aov system
    # Add some aovs
    aov_helper.add_aov(aov_helper.create_aov_shader(aov_type = Octane.RNDAOV_POST,aov_name = 'POST'))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_D))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_DIF_I))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_D))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_REFL_I))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_WIRE))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_OBJECT_LAYER_COLOR))
    aov_helper.add_aov(aov_helper.create_aov_shader(Octane.RNDAOV_VOLUME))
    aov_helper.remove_aov_type(aov_type = Octane.RNDAOV_WIRE)
    # Add 2 custom aovs with id 1 and 2
    aov_helper.add_custom_aov(customID = 1)
    aov_helper.add_custom_aov(customID = 2)
    # Get the custom aov with id 2
    custom2 = aov_helper.get_custom_aov(customID = 2)
    if custom2:
        print(f'We find a Custom AOV with id 2 Named{custom2.GetName()}')
    modify_octane_aov()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/73606</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73606</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Thu, 25 Jan 2024 03:06:01 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Wed, 24 Jan 2024 17:32:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">New versions here!</p>
<p dir="auto">I had change the name from <strong>renderEngine</strong> to <strong>Renderer</strong>, and also changed the main structure. see more in the very first of this topic. (<a href="https://github.com/DunHouGo/renderEngine/tree/main/versions/renderEngine" target="_blank" rel="noopener noreferrer nofollow ugc">renderEngine</a> had been move to versions folder, if you still interested.)</p>
<p dir="auto">This version is way more organized and user-friendly, you can use few lines of code to do something normal work, find an example below:</p>
DunHou</p>
<hr />
<h2>Result:</h2>
<p dir="auto"><img src="/forum/assets/uploads/files/1706117264369-e7eb47f4-f118-45d7-9101-bb610a25921b-image.png" alt="e7eb47f4-f118-45d7-9101-bb610a25921b-image.png" class=" img-fluid img-markdown" /></p>
<h2>Code:</h2>
import maxon
def HowToUse():
        tr.InsertMaterial()
    HowToUse()
</code></pre>
]]></description><link>http://developers.maxon.net/forum/post/73604</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73604</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Wed, 24 Jan 2024 17:32:02 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Wed, 22 Nov 2023 05:32:59 GMT]]></title><description><![CDATA[<p dir="auto">amazing！</p>
]]></description><link>http://developers.maxon.net/forum/post/73082</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73082</guid><dc:creator><![CDATA[czt_306]]></dc:creator><pubDate>Wed, 22 Nov 2023 05:32:59 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Mon, 20 Nov 2023 07:25:31 GMT]]></title><description><![CDATA[<p dir="auto">Wow ... good stuff<br />
My c4d Programing slowed down this year, but this might be something I want to use some day ...</p>
]]></description><link>http://developers.maxon.net/forum/post/73062</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73062</guid><dc:creator><![CDATA[mogh]]></dc:creator><pubDate>Mon, 20 Nov 2023 07:25:31 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sat, 18 Nov 2023 18:56:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dunhou">@<bdi>Dunhou</bdi></a><br />
It's realy cool and usefull, keep going bro <img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f37b.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--beers" style="height:23px;width:auto;vertical-align:middle" title="🍻" alt="🍻" /></p>
]]></description><link>http://developers.maxon.net/forum/post/73057</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73057</guid><dc:creator><![CDATA[gheyret]]></dc:creator><pubDate>Sat, 18 Nov 2023 18:56:23 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Fri, 17 Nov 2023 15:43:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Since my last post, I had some updates and fix to this library.</p>
<p dir="auto">And the following picture shows the new node functions added to my <a href="https://flowus.cn/75212a8b-df57-4bd8-9aa4-a8d12e090fba" target="_blank" rel="noopener noreferrer nofollow ugc">Render Flow</a> plugin based on the use of this library within few lines( just the node context ).</p>
<p dir="auto">Have fun with it.</p>
DunHou</p>
<p dir="auto"><img src="https://developers.maxon.net/forum/assets/uploads/files/1700235394383-all.gif" alt="all.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>http://developers.maxon.net/forum/post/73050</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/73050</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Fri, 17 Nov 2023 15:43:05 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Mon, 14 Aug 2023 08:03:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">Th renderEngine library has been updated to the 1.0.4 version, there are some re-write functions and may not incompatible with older versions，see  the main changes as follows：</p>
<ul>
<li>rename all <strong>node &amp; material</strong> functions to Capitalize style.</li>
<li>remove <strong>transaction</strong> in node_helper, use it in the final scripts.</li>
<li>organize the functions in node_helper with comments ( node\port\wire\util )</li>
<li>add some functions to check node or port info, like if it is connected , see the README.</li>
<li>add a <strong>InserShader</strong> function to create a shader into a wire.</li>
<li>re-write <strong>RemoveConnection</strong> in node_helper and support one argument(port) to remove connection.</li>
<li>see the <a href="https://github.com/DunHouGo/renderEngine/blob/main/ReadME.md#version--updates" target="_blank" rel="noopener noreferrer nofollow ugc">Version &amp; Updates</a></li>
</ul>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/72236</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72236</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Mon, 14 Aug 2023 08:03:44 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 23 Jul 2023 16:05:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/thomas">@<bdi>thomas</bdi></a> Hi, I had update my github readme file, and put my email on it<img src="http://developers.maxon.net/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f60a.png?v=0b8ddba251d" class="not-responsive emoji emoji-android emoji--blush" style="height:23px;width:auto;vertical-align:middle" title=":blush:" alt="😊" /></p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/72089</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72089</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 23 Jul 2023 16:05:06 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sat, 22 Jul 2023 17:52:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dunhou">@<bdi>Dunhou</bdi></a> is it possible to get in touch for you for freelance development? I couldn't find any email or socials.</p>
]]></description><link>http://developers.maxon.net/forum/post/72088</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72088</guid><dc:creator><![CDATA[thomas]]></dc:creator><pubDate>Sat, 22 Jul 2023 17:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 16 Jul 2023 06:42:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi community!</p>
<p dir="auto">the renderEngine helper is beta now, I set version number to 1.0.0, it contains three renderer now:</p>
<ul>
<li>Octane</li>
<li>Arnold ( MaterialHelper only support NodeGragh )</li>
<li>Redshift ( MaterialHelper only support NodeGragh )</li>
</ul>
<p dir="auto">I personally not use Vray and Corona quite often, if anyone is a pro user of these , very welcome to add them to renderEngine</p>
<p dir="auto">You can modify the aovs/materials with renderEngine quickly and easliy . See the examples above this topic.</p>
<p dir="auto">Hope you can have fun with it, and any improvement and fix is very appreciated.</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/72056</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72056</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 16 Jul 2023 06:42:54 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 02 Jul 2023 14:51:32 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/thomas">@<bdi>thomas</bdi></a> , thanks for your like, redshift_helper is 80% for beta I think, I will try to post ASAP.</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/71960</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71960</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 02 Jul 2023 14:51:32 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sun, 02 Jul 2023 14:49:55 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ferdinand">@<bdi>ferdinand</bdi></a> , that's very honor to contribute to the community, and also thanks for your pin, that inspire me a lot too.</p>
<p dir="auto">And a little plan I want to take your advice, what do you think the next update I should post, should I edit the first post, or just update the links when redshift/arnold is ready, and reply to the topic to show the main changes? which is better for more read convinence?</p>
DunHou</p>
]]></description><link>http://developers.maxon.net/forum/post/71959</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71959</guid><dc:creator><![CDATA[Dunhou]]></dc:creator><pubDate>Sun, 02 Jul 2023 14:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Sat, 01 Jul 2023 13:14:35 GMT]]></title><description><![CDATA[<p dir="auto">this looks amazing. Can't wait to see arnold / RS</p>
]]></description><link>http://developers.maxon.net/forum/post/71954</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71954</guid><dc:creator><![CDATA[thomas]]></dc:creator><pubDate>Sat, 01 Jul 2023 13:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to Open source wrapper for Octane&#x2F;Redshift&#x2F;Arnold&#x2F;Vray&#x2F;Corona in Cinema 4D. on Fri, 30 Jun 2023 07:58:15 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/dunhou">@<bdi>Dunhou</bdi></a>,</p>
<p dir="auto">This looks AWESOME! Thank you so much for all the awesome stuff you create!</p>
<p dir="auto">I have pinned this topic, so that it remains visible.</p>
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/71948</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/71948</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Fri, 30 Jun 2023 07:58:15 GMT</pubDate></item></channel></rss>
