    Calculate third point position aligned with two points(edge dir)
    2023python
    4 Posts 3 Posters 809 Views
    • ymoonY Offline
      ymoon
      There are three points. In the picture, I want to straighten the third point while keeping the edge length. What are the correct methods for vector and matrix arithmetic (Python/R2023)? Thank You.
      test.c4d
      • chuanzhenC Offline
        chuanzhen
        Here is one of the calculations:
        In world coordinates, get ab vector and the length of bc vector
        Then normalize the ab vector , then use the length of the bc vector to scale the length of the has normalized ab vector , use point b world position to offset the ab vector (that is, add the world position of the point b vector) to get the position of point C
        file use Xpresso to calculate C Position
        test.c4d
        相信我,可以的!
        ymoonY 1 Reply Last reply Reply Quote 0
        • ymoonY Offline
          ymoon @chuanzhen
          @chuanzhen said in Calculate third point position aligned with two points(edge dir):
          test.c4d
          Thanks for the quick reply.
          How do I change this to run in the local coordinate system?
          I'm not familiar with the matrix. Thank you.
          ah... sorry forget it. remove * mg
          • i_mazlovI Offline
            i_mazlov
            Hi @ymoon,
            Thanks for reaching out to us. Glad your problem is solved!
            Here are some pointers to the docs with related toolset:
            c4d.Vector, c4d.Matrix, c4d.utils.
            Please note, there's Matrix Manual, although math questions are generally out of scope of the support on this forum.
            Ilia
