    2024.4 update makes CheckDirty error for ObjectData plugin Fieldlist
    pythonmacos2024
    5 Posts 3 Posters 1.1k Views 2 Watching
    • mikeudinM Offline
      mikeudin
      Hello there!
      After updating to Cinema 4D 2024.4 my plugin causes this Exception:
      ReferenceError: the object 'c4d.modules.mograph.FieldLayer' is not alive
      The above exception was the direct cause of the following exception:
      SystemError: <function VTexterData.CheckDirty at 0x4b3546450> returned a result with an exception set
      It happens after adding some fieldlayer to the Field List. What is problem it can be?
      Here is my CheckDirty func:
      def get_field_layers(op):
          Returns all field layers that are referenced in a field list.
          Source: https://plugincafe.maxon.net/topic/11809/iterating-trough-field-list/2?_=1678357010902
          def flatten_tree(node):
              """ Listifies a GeListNode tree. """
              r = []
              while node:
                  r.append(node)
                  for child in node.GetChildren():
                      r += flatten_tree(child)
                  mask = node.GetMaskHead()
                  if mask:
                      for child in mask.GetChildren():
                  node = node.GetNext()
              return r
          # get the GeListHead for the FieldList
          root = op.GetLayersRoot()
          if root is None:
              return []
          # Get the first node under the GeListHead
          first = root.GetFirst()
          if first is None:
              return []
          # traverse the graph
          return flatten_tree(first)
      def CheckDirty(self, op, doc):
          fdirty = 0
          desc = op.GetDescription(c4d.DESCFLAGS_DESC_NONE)
          bc = desc.GetParameterI(c4d.VFTAG_TEXT_ANIMATOR_TRANSFORM, None)
          if not bc:
          fenabled = [t[c4d.VFTAG_TEXT_ANIMATOR_ENABLE] for t in op.GetTags() if t.CheckType(c4d.Tvfanimatortag)]
          get_tvalue = lambda i: fenabled[i] if i < len(fenabled) else False #get correct value in case if tags count != axes count
          tfields = [op[c4d.VFTAG_TEXT_ANIMATOR_FIELDS + i] for i in range(len(bc[c4d.DESC_CYCLE])) if get_tvalue(i)]
          if not tfields:
          for f in tfields:
              if not f or not f.HasContent(): continue
              fdirty += f.GetDirty(doc)
              for l in get_field_layers(f):
                  if not l.IsAlive(): continue
                  if l.GetTypeName() in ('Time','Decay','Delay') and l.GetStrength() > 0.0:
                      fdirty += doc.GetTime().GetFrame(doc.GetFps())
                      continue
                  fdirty += l.GetDirty(c4d.DIRTYFLAGS_ALL)
                  lobject = l.GetLinkedObject(doc)
                  if lobject:
                      fdirty += lobject.GetDirty(c4d.DIRTYFLAGS_MATRIX | c4d.DIRTYFLAGS_DATA | c4d.DIRTYFLAGS_DESCRIPTION)
          fdirty += op.GetDirty(c4d.DIRTYFLAGS_MATRIX)
          if fdirty != self.lastFieldsDirty:
              self.lastFieldsDirty = fdirty
              op.SetDirty(c4d.DIRTYFLAGS_DATA)
      Checkout my python tutorials, plugins, scripts, xpresso presets and more
      https://mikeudin.net
        ferdinand @mikeudin
        Hey @mikeudin,
        Thank you for reaching out to us and I am sorry for the inconvenience this has caused you. This error very likely means that there is a bug in our code as a node reference should not loose connection in this context. It would have been better if you have included line numbers in your stack trace, as without them I have to guess, but it seems very likely that the return r of flatten_tree is the culprit with returning a dangling reference to a FieldLayer, a 'not alive' node.
        While the code you have posted is sufficient for understanding the problem, we will need your full plugin code to debug the problem and possibly provide a temporary workaround before a fix arrives.
        • Please send us your full plugin to sdk_support(at)maxon(dot(net).
        • Please also provide an example scene which triggers the problem.
        • Please also include a crash/bug report in the exact form lined out here.
        • Finally, please make sure to provide us the unencrypted form of your plugin, or to give us explicit permission to decrypt it (we obviously prefer the former). We will have to look at your code and debug the actual plugin.
        • mikeudinM Offline
          mikeudin
          It would have been better if you have included line numbers in your stack trace, as without them I have to guess...
          Error messages going not in traceback format πŸ€”
          Here is a sample plugin with same issue.
          odatafieldsexample.zip
          ferdinandF i_mazlovI 2 Replies Last reply Reply Quote 0
            ferdinand @mikeudin
            Hey @mikeudin,
            ah okay my bad, I thought you had a more expressive stack trace and just truncated it. We will have a look and keep you posted. Although I am fairly sure that this is a bug, we will wait with promoting/moving this topic to bugs until we have confirmed that it is a bug.
            edit: I just looked into your zip. At least I do neither see there a scene file nor a bug report. Please provide these. When not, and we cannot reproduce an issue on first attempt without any instructions, we will simply declare it as "not reproducible". Even when you consider things obvious or trivial, you must provide reproduction steps and a scene.
            • i_mazlovI Offline
              i_mazlov @mikeudin
              Hi @mikeudin ,
              To me it sounds pretty much like this issue here: issue with inserting fieldlayers in r2024, particularly after I couldn't reproduce this issue with the internally available next version of cinema.
              Ilia
