Error after hitting Undo.
I created a script that performs a few subdivisions on splines, using the SendModelingCommand command, with the MCOMMAND_SUBDIVIDE.
It performs the subdivision on segments of the spline between selected points. I tried adding undos, so that hitting Undo after the script executes, would return the original spline, without subdivisions.
However, after hitting Undo, I get an error:A problem with this project as been detected: Object 'Spline' - Point selection out of bounds.
Please save and contact Maxon Support with a description of the last used commands, actions or plugins.I start my script with two consecutive points along the spline selected.
Besides this error, if I hit Undo, the code works fine.
What could be the problem? -
the actual script would be helpful, or more specifically the type of undo you did apply, I assume
c4d.UNDOTYPE_CHANGE? Have you tried the recommended procedure of applyingSMCto a copy of the object? You would then have to open an undo group, applyc4d.UNDOTYPE_DELETE, delete the original, insert the copy, applyc4d.UNDOTYPE_NEW, and finally close the undo group.Cheers
zipit -
the actual script or a part of it would help yes.
I've also marked this thread as a question as you seem to never do it
Manuel. -
I made the changes in order to work on a duplicate of the original spline.
It still works, but it also still returns the same error when I undo.
Here is the script:import c4d from c4d import gui # Welcome to the world of Python # Find the length of the spline segment between points p1 and p2 def GetLength(op,p1,p2): select=op.GetPointS() select.DeselectAll() select.Select(p1) select.Select(p2) bc=c4d.BaseContainer() result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SPLIT, [op], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc) leng=10000000.0 if result!=False and result!=[]: op2=result[0] segm=c4d.utils.SplineHelp() segm.InitSplineWith(op2, flags=c4d.SPLINEHELPFLAGS_GLOBALSPACE|c4d.SPLINEHELPFLAGS_CONTINUECURVE) leng=segm.GetSplineLength() segm.FreeSpline() return leng # Main function def main(): selected=doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_0) if len(selected) == 0: c4d.gui.MessageDialog("You must select a spline and two consecutive points of that spline.") return op=selected[0] if op.GetType()!=5101: c4d.gui.MessageDialog("You must select a spline and two consecutive points of that spline.") return selection=op.GetPointS() if selection.GetCount()!=2: c4d.gui.MessageDialog("You must select two consecutive points of the spline.") return # check if the selected points are consecutive p1,p2=-1,-1 num=op.GetPointCount() for s in range(num): if selection.IsSelected(s): if p1==-1: p1=s else: p2=s if p2-p1!=1: c4d.gui.MessageDialog("You must select two consecutive points of the spline.") return # get the size of the segment shortest=GetLength(op,p1,p2) # work on a copy of the original spline op2=op.GetClone() # start at point 0 i=0 while i<num: # get the length of the current segment between point i and i+1 new_length=GetLength(op2,i,i+1) # if the segment is, at least one and a half times the size of the initial segment... if (new_length>(shortest*1.5)): subdivs=int(new_length/shortest)+1 # select point i and i+1 selection=op2.GetPointS() selection.DeselectAll() selection.Select(i) selection.Select(i+1) # subdivide that segment bc=c4d.BaseContainer() bc.SetInt32(c4d.MDATA_SUBDIVIDE_SPLINESUB,subdivs) result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SUBDIVIDE, [op2], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc) # update the counter i=i+subdivs-1 # update the limit num=num+subdivs-1 # increase the counter i=i+1 # insert the new subdivided spline after the original spline # and delete the original spline, making sure this is undoable doc.StartUndo() doc.InsertObject(op2, parent=None, pred=op, checknames=False) doc.AddUndo(c4d.UNDOTYPE_NEW, op2) doc.AddUndo(c4d.UNDOTYPE_DELETE, op) op.Remove() doc.EndUndo() # update the document c4d.EventAdd() # Execute main() if __name__=='__main__': main() -
@m_magalhaes said in Error after hitting Undo.:
How can I mark it as a question?
I finally made it work without the error after hitting undo, by replacing calls to GetLength, in the form:
GetLength(op,p1,p2)
to
GetLength(op.GetClone(),p1,p2)
i just scratch a bit your code, but i've discovered that with the R21, MCOMMAND_SPLIT only return true.
I've opened a bug entry for that.Happy to see your code is working. I will have a look at it and my comment on that.
Like it's not a good idea to useGetType()you should use IsInstanceOfAbout the forum, those are the thread where you can have information on how to use the new functionalities of the forum. This will help futur user to find resolved question and the right post.
- Q&A New Functionality.
- How to Post Questions especially the tagging part.
Thank you, Manuel.
From what I see, several things are working differently in R21.
I suspect the MCOMMAND_EDGE_TO_SPLINE is also not working properly.
And the MCOMMAND_CURRENTSTATETOOBJECT (a very important one) is also not working as expected, requiring that the object to be converted to be in a new document.I will start using IsInstanceOf instead of GetType
I will also pay more attention to the tagging part of my posts.
Once again, thank you.
@rui_mac said in Error after hitting Undo.:
This one is fixed on the next update.
I'll check MCOMMAND_EDGE_TO_SPLINE thanks.
hello,
just dig in a little bit more on your code.
I've added someAddUndoand i'm using the flag of theSendModelingCommandto add an undo.
Removing the need of a clone except in the GetLength function where you have to split the spline.import c4d from c4d import gui # Welcome to the world of Python # Find the length of the spline segment between points p1 and p2 def GetLength(op,p1,p2): newSpline = op.GetClone() select = newSpline.GetPointS() select.DeselectAll() select.Select(p1) select.Select(p2) bc = c4d.BaseContainer() result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SPLIT, [newSpline], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc) leng = 10000000.0 if result: print "ok " segm=c4d.utils.SplineHelp() segm.InitSplineWith(result[0], flags=c4d.SPLINEHELPFLAGS_GLOBALSPACE|c4d.SPLINEHELPFLAGS_CONTINUECURVE) leng=segm.GetSplineLength() segm.FreeSpline() print leng return leng # Main function def main(): selected = doc.GetActiveObject() if doc.GetActiveObject().IsInstanceOf(c4d.Ospline) else None if selected is None: c4d.gui.MessageDialog("Select a spline") return selection = op.GetPointS() if selection.GetCount() != 2: c4d.gui.MessageDialog("You must select two points of the spline.") return # check if the selected points are consecutive p1 = p2 = -1 num = op.GetPointCount() for s in range(num): if selection.IsSelected(s): if p1 == -1: p1 = s else: p2 = s if p2-p1 != 1: c4d.gui.MessageDialog("You must select two consecutive points of the spline.") return # get the size of the segment shortest = GetLength(op,p1,p2) # start at point 0 i = 0 doc.StartUndo() while i<num: # get the length of the current segment between point i and i+1 new_length = GetLength(op,i,i+1) # if the segment is, at least one and a half times the size of the initial segment... if (new_length > (shortest * 1.5)): subdivs=int(new_length/shortest)+1 # select point i and i+1 selection=op.GetPointS() doc.AddUndo(c4d.UNDOTYPE_CHANGE, op) selection.DeselectAll() doc.AddUndo(c4d.UNDOTYPE_CHANGE, op) selection.Select(i) doc.AddUndo(c4d.UNDOTYPE_CHANGE, op) selection.Select(i+1) # subdivide that segment bc=c4d.BaseContainer() bc.SetInt32(c4d.MDATA_SUBDIVIDE_SPLINESUB,subdivs) result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SUBDIVIDE, [op], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc, flags =c4d.MODELINGCOMMANDFLAGS_CREATEUNDO) if result == False: raise ValueError("the subdivde command failed") # update the counter i=i+subdivs-1 # update the limit num=num+subdivs-1 # increase the counter i=i+1 doc.EndUndo() # update the document c4d.EventAdd() # Execute main() if __name__=='__main__': main()Cheers,
Manuel -
what doesn't work properly ?
import c4d from c4d import gui from c4d import utils def main(): #edge to spline. bc = c4d.BaseContainer() res = utils.SendModelingCommand(c4d.MCOMMAND_EDGE_TO_SPLINE, list = [op], bc = bc, doc= doc) c4d.EventAdd() # Execute main() if __name__=='__main__': main() -
The addition of the undo as a flag is great. Thank you
What was not working was that, in R21, I was getting no spline as the return result of the SendModelingCommand, set to MCOMMAND_EDGE_TO_SPLINE.
I will try again, at home, as I don't have R21 here, at work. -
I've opened a bug entry for that.this is fixed in R21.1
