    Error after hitting Undo.
    r20python
    13 Posts 3 Posters 2.0k Views 2 Watching
    • R Offline
      rui_mac
      I created a script that performs a few subdivisions on splines, using the SendModelingCommand command, with the MCOMMAND_SUBDIVIDE.
      It performs the subdivision on segments of the spline between selected points. I tried adding undos, so that hitting Undo after the script executes, would return the original spline, without subdivisions.
      However, after hitting Undo, I get an error:
      A problem with this project as been detected: Object 'Spline' - Point selection out of bounds.
      Please save and contact Maxon Support with a description of the last used commands, actions or plugins.
      I start my script with two consecutive points along the spline selected.
      Besides this error, if I hit Undo, the code works fine.
      What could be the problem?
        the actual script would be helpful, or more specifically the type of undo you did apply, I assume c4d.UNDOTYPE_CHANGE? Have you tried the recommended procedure of applying SMC to a copy of the object? You would then have to open an undo group, apply c4d.UNDOTYPE_DELETE, delete the original, insert the copy, apply c4d.UNDOTYPE_NEW, and finally close the undo group.
        zipit
          the actual script or a part of it would help yes.
          I've also marked this thread as a question as you seem to never do it 😜
          Manuel.
          R 1 Reply Last reply Reply Quote 0
          • R Offline
            rui_mac
            I made the changes in order to work on a duplicate of the original spline.
            It still works, but it also still returns the same error when I undo.
            Here is the script:
            from c4d import gui
            # Find the length of the spline segment between points p1 and p2
            def GetLength(op,p1,p2):
                select=op.GetPointS()
                select.DeselectAll()
                select.Select(p1)
                select.Select(p2)
                bc=c4d.BaseContainer()
                result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SPLIT, [op], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc)
                leng=10000000.0
                if result!=False and result!=[]:
                    op2=result[0]
                    segm=c4d.utils.SplineHelp()
                    segm.InitSplineWith(op2, flags=c4d.SPLINEHELPFLAGS_GLOBALSPACE|c4d.SPLINEHELPFLAGS_CONTINUECURVE)
                    leng=segm.GetSplineLength()
                    segm.FreeSpline()
                return leng
            # Main function
                selected=doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_0)
                if len(selected) == 0:
                    c4d.gui.MessageDialog("You must select a spline and two consecutive points of that spline.")
                op=selected[0]
                if op.GetType()!=5101:
                selection=op.GetPointS()
                if selection.GetCount()!=2:
                    c4d.gui.MessageDialog("You must select two consecutive points of the spline.")
                # check if the selected points are consecutive
                p1,p2=-1,-1
                num=op.GetPointCount()
                for s in range(num):
                    if selection.IsSelected(s):
                        if p1==-1:
                            p1=s
                            p2=s
                if p2-p1!=1:
                # get the size of the segment
                shortest=GetLength(op,p1,p2)
                # work on a copy of the original spline
                op2=op.GetClone()
                # start at point 0
                i=0
                while i<num:
                    # get the length of the current segment between point i and i+1
                    new_length=GetLength(op2,i,i+1)
                    # if the segment is, at least one and a half times the size of the initial segment...
                    if (new_length>(shortest*1.5)):
                        subdivs=int(new_length/shortest)+1
                        # select point i and i+1
                        selection=op2.GetPointS()
                        selection.DeselectAll()
                        selection.Select(i)
                        selection.Select(i+1)
                        # subdivide that segment
                        bc.SetInt32(c4d.MDATA_SUBDIVIDE_SPLINESUB,subdivs)
                        result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SUBDIVIDE, [op2], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc)
                        # update the counter
                        i=i+subdivs-1
                        # update the limit
                        num=num+subdivs-1
                    # increase the counter
                    i=i+1
                # insert the new subdivided spline after the original spline
                # and delete the original spline, making sure this is undoable
                doc.StartUndo()
                doc.InsertObject(op2, parent=None, pred=op, checknames=False)
                doc.AddUndo(c4d.UNDOTYPE_NEW, op2)
                doc.AddUndo(c4d.UNDOTYPE_DELETE, op)
                op.Remove()
                doc.EndUndo()
                # update the document
            # Execute main()
            • R Offline
              rui_mac @Manuel
              @m_magalhaes said in Error after hitting Undo.:
              How can I mark it as a question?
              • R Offline
                rui_mac
                I finally made it work without the error after hitting undo, by replacing calls to GetLength, in the form:
                GetLength(op,p1,p2)
                to
                GetLength(op.GetClone(),p1,p2)
                  i just scratch a bit your code, but i've discovered that with the R21, MCOMMAND_SPLIT only return true.
                  I've opened a bug entry for that.
                  Happy to see your code is working. I will have a look at it and my comment on that.
                  Like it's not a good idea to use GetType() you should use IsInstanceOf
                  About the forum, those are the thread where you can have information on how to use the new functionalities of the forum. This will help futur user to find resolved question and the right post.
                  • Q&A New Functionality.
                  • How to Post Questions especially the tagging part.
                  • R Offline
                    rui_mac
                    Thank you, Manuel.
                    From what I see, several things are working differently in R21.
                    I suspect the MCOMMAND_EDGE_TO_SPLINE is also not working properly.
                    And the MCOMMAND_CURRENTSTATETOOBJECT (a very important one) is also not working as expected, requiring that the object to be converted to be in a new document.
                    I will start using IsInstanceOf instead of GetType 🙂
                    I will also pay more attention to the tagging part of my posts.
                    Once again, thank you.
                      @rui_mac said in Error after hitting Undo.:
                      This one is fixed on the next update.
                      I'll check MCOMMAND_EDGE_TO_SPLINE thanks.
                        hello,
                        just dig in a little bit more on your code.
                        I've added some AddUndo and i'm using the flag of the SendModelingCommand to add an undo.
                        Removing the need of a clone except in the GetLength function where you have to split the spline.
                        from c4d import gui
                            newSpline  = op.GetClone()
                            select = newSpline.GetPointS()
                            select.Select(p1)
                            select.Select(p2)
                            bc = c4d.BaseContainer()
                            result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SPLIT, [newSpline], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc)
                            leng = 10000000.0
                            if result:
                                print "ok "
                                segm.InitSplineWith(result[0], flags=c4d.SPLINEHELPFLAGS_GLOBALSPACE|c4d.SPLINEHELPFLAGS_CONTINUECURVE)
                                segm.FreeSpline()
                                print leng
                            return leng
                        # Main function
                            selected = doc.GetActiveObject() if  doc.GetActiveObject().IsInstanceOf(c4d.Ospline) else None
                            if selected is None:
                                c4d.gui.MessageDialog("Select a spline")
                            selection = op.GetPointS()
                            if selection.GetCount() != 2:
                                c4d.gui.MessageDialog("You must select two points of the spline.")
                            p1 = p2 = -1
                            num = op.GetPointCount()
                                    if p1 == -1:
                                        p1 = s
                                        p2 = s
                            if p2-p1 != 1:
                            shortest = GetLength(op,p1,p2)
                            # start at point 0
                            i = 0
                            doc.StartUndo()
                            while i<num:
                                new_length = GetLength(op,i,i+1)
                                if (new_length > (shortest * 1.5)):
                                    selection.Select(i)
                                    result=c4d.utils.SendModelingCommand(c4d.MCOMMAND_SUBDIVIDE, [op], mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc=bc, doc=doc, flags =c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)
                                    if result == False:
                                        raise ValueError("the subdivde command failed")
                                    i=i+subdivs-1
                                    # update the limit
                                    num=num+subdivs-1
                                i=i+1
                            doc.EndUndo()
                        # Execute main()
                          what doesn't work properly ?
                          from c4d import gui
                          from c4d import utils
                              #edge to spline.
                              res = utils.SendModelingCommand(c4d.MCOMMAND_EDGE_TO_SPLINE, list = [op], bc = bc, doc= doc)
                          # Execute main()
                          • R Offline
                            rui_mac
                            The addition of the undo as a flag is great. Thank you 🙂
                            What was not working was that, in R21, I was getting no spline as the return result of the SendModelingCommand, set to MCOMMAND_EDGE_TO_SPLINE.
                            I will try again, at home, as I don't have R21 here, at work.
                              this is fixed in R21.1
