    Writing data to the .c4d file
    r20python
    26 Posts 4 Posters 18.3k Views 3 Watching
    • ? Offline
      A Former User @ferdinand
      @zipit Thank you so much for your patience. I changed what you said and
      doc.GetDocumentData(MyUniqueId)
      does print a BaseContainer, but this doesn't print anything:
      for cid, value in doc.GetDocumentData(MyUniqueId):
            print cid, value
      Updated script:
      PLUGIN_ID = 1234567
      MyUniqueId = 1000001
          #get the document's BaseContainer
          bc = doc.GetDataInstance()
          #create a sub-BaseContainer
          subBc = c4d.BaseContainer()
          subBc[1000] = "hello"
          subBc[2000] = "world!"
          #add the sub-BaseContainer to the document Base Container
          doc.SetDocumentData(MyUniqueId, subBc)
          #set the Document Data using the plugin ID
          doc.SetDocumentData(PLUGIN_ID, bc)
          print doc.GetDocumentData(MyUniqueId)
          # <c4d.BaseContainer object at 0x0000018F956DC1B0>
          #get the sub container's data
              print cid, value
      • ? Offline
        A Former User
        I'm confused in this example how the SubBaseContainer is being added to the BaseContainer. It seems like they're both being added to the Document.
        I might be mistaken, but this was how I envisioned the data structure:
        Document ⮧
           BaseContainer Data (ID = PLUGIN_ID) ⮧
              SubBaseContainer Data (ID = MyUniqueId)
          as I said, you can't set the whole container. Or in other words you don't need the variable bc in your example. Here is one one example that shows you how to store hierarchical data and then retrieve it. I wrote this on my iPad, so there might be bugs/typos, but the concept should be clear.
          # Your settings container
          bc = c4d.BaseContainer()
          # One level of your container, we treat this like a list/folder
          folder = c4d.BaseContainer()
          # One item in your folder
          recipe_1 = c4d.BaseContainer()
          # Another item in your folder
          recipe_2 = c4d.BaseContainer()
          bc[ID_TITLE] = 'My Cooking recipes'
          bc[ID_DATA] = folder
          folder[1000] = recipe_1
          folder[1001] = recipe_2
          recipe_1[ID_TITLE] = 'Choclate delight'
          recipe_1[ID_INSTRUCTIONS] = 'Lorem Ipsum ...'
          recipe_2[ID_TITLE] = 'Cheesekake'
          recipe_2[ID_INSTRUCTIONS] = 'Lorem Ipsum ...'
          doc.SetDocumentData(ID_MY_SECRET_COOKING_RECIPES, bc)
          def print_container(bc):
              for cid, value in bc:
                  print cid, value
                  if isinstance(value, c4d.BaseContainer):
                      print_container(value)
          print_container(doc.GetDocumentData(ID_MY_SECRET_COOKING_RECIPES))
            ferdinand @Guest
            @blastframe said in Writing data to the .c4d file:
            Document ⮧
            no, it is
            Document
            --- Stuff
            --- Other Stuff
            --- Your ID stuff
            --- Some clown is saving his cooking recipes here
            zipit
            ? 1 Reply Last reply Reply Quote 1
            • ? Offline
              @zipit Thanks for the explanation of the data structure (and the code for clarity).
              I tried my best to get it working, but it's still not printing the data. I'm not sure if it was intentional, but I changed the line
              print_container(doc.SetDocumentData(ID_MY_SECRET_COOKING_RECIPES))
              as it was throwing an error for not passing a BaseContainer. Did you mean?
              Regardless it's the same issue where it does see the BaseContainer in the print function, but cannot iterate through it.
              ID_MY_SECRET_COOKING_RECIPES = 2999999
              ID_TITLE = 1008
              ID_DATA = 1009
              ID_INSTRUCTIONS = 1010
                      print cid, value
              • ? Offline
                A Former User
                Not sure if this matters, but my ultimate goal would be to save JSON data in the BaseContainer.
                  The function SetDocumentData can only be used to update the document settings.
                  It does accept an Int as a "type" but if you put something else than DOCUMENTSETTINGS_GENERAL DOCUMENTSETTINGS_MODELING DOCUMENTSETTINGS_DOCUMENT DOCUMENTSETTINGS_ANIMATIONSYSTEM the function will simply do nothing. (and the last one is marked as private)
                  BaseContainer is a tree system, you can see sub-BaseContainer just like a child object in the object manager.
                  So you can have (infinite ?) BaseContainer inside BaseContainer.
                  If you want to store json data, it's up to you. You can store all elements of your json data or simply store a string.
                  PLUGIN_ID = 1234567
                  MyUniqueId = 456789
                      #retrieves the document baseContainer
                      docBC = doc.GetDataInstance()
                      # Add the container to the "main" Container
                      docBC.SetContainer(MyUniqueId, subBc)
                      # Updates the document container
                      doc.SetData(docBC)
                      # Print the values stored in our container.
                      for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId):
                          print cid, value
                      # Print Hello World
                      print doc[MyUniqueId][1000], doc[MyUniqueId][2000]
                  ? 1 Reply Last reply Reply Quote 2
                  • ? Offline
                    A Former User @Manuel
                    @m_magalhaes Hi Manuel and thank you for this contribution. This code's data, however, is not persisting when I do the following:
                    • run the script to set the data
                    • close and reopen the document.
                    • comment out the lines setting the data (lines 11-19)
                    • run the script to print the data
                    Instead I get this error for doc[MyUniqueId]:
                    TypeError: 'NoneType' object has no attribute '__getitem__'
                    Also, is MyUniqueId supposed to be the PLUGIN_ID? Why is that not being used?
                    Thanks!
                    • CairynC Offline
                      Cairyn @Guest
                      @blastframe For me, it works fine this way. Did you really "close and reopen" the document? Not "save", "close", "load"? Because if you just close the document, the data from the container is gone, which leads to your error message.
                      The Q regarding MyUniqueId vs. PLUGIN_ID is not relevant (probably typed in a hurry), you can use either. But the ID value should come from Maxon in the end, so you avoid collisions with existing IDs.
                      • ? Offline
                        A Former User @Cairyn
                        @Cairyn I'm a little embarrassed, but you're right. I wasn't saving properly (I think just saving the Script) then going to the document in Recent Files. I'll mark this solved.
                        Thank you all - @Cairyn ,@zipit ,@m_magalhaes .
                          you could use the same ID, you just have to be sure that you are the only one to use that ID to store datas.
                          That's why we use plugin's ID.
                          Manuel.
                          • ? Offline
                            @m_magalhaes Thanks, Manuel.
                            How would I delete the data of an individual sub-BaseContainer in the case of your script?
                            I've tried several methods below but the doc[MyUniqueId][1000] still shows data in the print call.
                            bc = doc.GetDataInstance().GetContainer(MyUniqueId)
                            print bc.RemoveData(1000)
                            # True
                            print doc[MyUniqueId].RemoveData(1000)
                            # True
                            doc[MyUniqueId].FlushAll()
                            #hello
                            I was able to delete all of the data this way, but what if I want to keep the data in subBc[2000]?
                            docBC.RemoveData(MyUniqueId)
                            Thank you!
                              hello,
                              there's a difference between GetContainer and GetContainerInstance
                              The first return a copy of the container the second the original link.
                              So either you retrieve a copy and set back the container to the parent with SetData and/or SetContainer
                              or you retrieve the original link and the changes are reflected immediately.
                              You can also use del that is pythonic
                                  bc = doc.GetDataInstance().GetContainerInstance(MyUniqueId)
                                  bc.RemoveData(2000)
                                  #del (bc[2000])
                              • ? Offline
                                @m_magalhaes said in Writing data to the .c4d file:
                                    bc.RemoveData(2000)
                                    #del (bc[2000])
                                Wonderful, @m_magalhaes , thank you so much!
