    Writing data to the .c4d file
    r20python
    26 Posts 4 Posters 18.3k Views 3 Watching
    • ? Offline
      A Former User @Cairyn
      Fantastic, thank you both for your help!
      • ? Offline
        @Cairyn said in Writing data to the .c4d file:
        I suppose you mean saving data to the BaseContainer of the BaseDocument? You'll need a plugin id for that so it will not collide with the existing IDs, then you can put a sub-BaseContainer with your data into that container. Or you can define your own datatype.
        Here's what I've got so far for the sub-BaseContainer. It doesn't seem to be working. Any ideas about what I'm doing incorrectly?
        PLUGIN_ID = 1234567
        MyUniqueId = 1000001
           #get the document's BaseContainer
           bc = doc.GetDataInstance()
           #create a sub-BaseContainer
           subBc = c4d.BaseContainer()
           subBc[1000] = "hello"
           subBc[2000] = "world!"
           #add the sub-BaseContainer to the document Base Container
           bc.SetContainer(MyUniqueId, subBc)
           #set the Document Data using the plugin ID
           doc.SetDocumentData(PLUGIN_ID, bc)
           #get the sub containers data
           print bc[PLUGIN_ID][2000]
          your second example is correct. Implementing your own data type that can be serialized with a BaseContainer, is a feature, that is only available in C++. But with stacking BaseContainers you can do alot.
          zipit
          • ? Offline
            A Former User @ferdinand
            @zipit
            Hi! I updated my code example with line-by-line comments.
            It doesn't seem to be working as I can't close the file, then read back the SubContainer's data with this:
              for cid, value in doc.GetDocumentData(MyUniqueId):
                    print cid, value
              and
              doc.SetDocumentData(MyUniqueId, subBc)
              instead of
              i.e.: Your misconception is that you can get/set all document data in one container. You can't (with this method). You only write/read one settings container at a time. In this case the container you did register.
              zipit
              ? 1 Reply Last reply Reply Quote 1
              • ? Offline
                @zipit Thank you so much for your patience. I changed what you said and
                does print a BaseContainer, but this doesn't print anything:
                      print cid, value
                Updated script:
                PLUGIN_ID = 1234567
                    print doc.GetDocumentData(MyUniqueId)
                    # <c4d.BaseContainer object at 0x0000018F956DC1B0>
                    #get the sub container's data
                        print cid, value
                • ? Offline
                  A Former User
                  I'm confused in this example how the SubBaseContainer is being added to the BaseContainer. It seems like they're both being added to the Document.
                  I might be mistaken, but this was how I envisioned the data structure:
                  Document ⮧
                     BaseContainer Data (ID = PLUGIN_ID) ⮧
                        SubBaseContainer Data (ID = MyUniqueId)
                    as I said, you can't set the whole container. Or in other words you don't need the variable bc in your example. Here is one one example that shows you how to store hierarchical data and then retrieve it. I wrote this on my iPad, so there might be bugs/typos, but the concept should be clear.
                    # Your settings container
                    bc = c4d.BaseContainer()
                    # One level of your container, we treat this like a list/folder
                    folder = c4d.BaseContainer()
                    # One item in your folder
                    recipe_1 = c4d.BaseContainer()
                    # Another item in your folder
                    recipe_2 = c4d.BaseContainer()
                    bc[ID_TITLE] = 'My Cooking recipes'
                    bc[ID_DATA] = folder
                    folder[1000] = recipe_1
                    folder[1001] = recipe_2
                    recipe_1[ID_TITLE] = 'Choclate delight'
                    recipe_1[ID_INSTRUCTIONS] = 'Lorem Ipsum ...'
                    recipe_2[ID_TITLE] = 'Cheesekake'
                    recipe_2[ID_INSTRUCTIONS] = 'Lorem Ipsum ...'
                    doc.SetDocumentData(ID_MY_SECRET_COOKING_RECIPES, bc)
                    def print_container(bc):
                        for cid, value in bc:
                            print cid, value
                            if isinstance(value, c4d.BaseContainer):
                                print_container(value)
                    print_container(doc.GetDocumentData(ID_MY_SECRET_COOKING_RECIPES))
                      ferdinand @Guest
                      @blastframe said in Writing data to the .c4d file:
                      Document ⮧
                      no, it is
                      Document
                      --- Stuff
                      --- Other Stuff
                      --- Your ID stuff
                      --- Some clown is saving his cooking recipes here
                      zipit
                      • ? Offline
                        @zipit Thanks for the explanation of the data structure (and the code for clarity).
                        I tried my best to get it working, but it's still not printing the data. I'm not sure if it was intentional, but I changed the line
                        print_container(doc.SetDocumentData(ID_MY_SECRET_COOKING_RECIPES))
                        as it was throwing an error for not passing a BaseContainer. Did you mean?
                        Regardless it's the same issue where it does see the BaseContainer in the print function, but cannot iterate through it.
                        ID_MY_SECRET_COOKING_RECIPES = 2999999
                        ID_TITLE = 1008
                        ID_DATA = 1009
                        ID_INSTRUCTIONS = 1010
                                print cid, value
                        • ? Offline
                          A Former User
                          Not sure if this matters, but my ultimate goal would be to save JSON data in the BaseContainer.
                            The function SetDocumentData can only be used to update the document settings.
                            It does accept an Int as a "type" but if you put something else than DOCUMENTSETTINGS_GENERAL DOCUMENTSETTINGS_MODELING DOCUMENTSETTINGS_DOCUMENT DOCUMENTSETTINGS_ANIMATIONSYSTEM the function will simply do nothing. (and the last one is marked as private)
                            BaseContainer is a tree system, you can see sub-BaseContainer just like a child object in the object manager.
                            So you can have (infinite ?) BaseContainer inside BaseContainer.
                            If you want to store json data, it's up to you. You can store all elements of your json data or simply store a string.
                            PLUGIN_ID = 1234567
                            MyUniqueId = 456789
                                #retrieves the document baseContainer
                                docBC = doc.GetDataInstance()
                                # Add the container to the "main" Container
                                docBC.SetContainer(MyUniqueId, subBc)
                                # Updates the document container
                                doc.SetData(docBC)
                                # Print the values stored in our container.
                                for cid, value in doc.GetDataInstance().GetContainer(MyUniqueId):
                                    print cid, value
                                # Print Hello World
                                print doc[MyUniqueId][1000], doc[MyUniqueId][2000]
                            ? 1 Reply Last reply Reply Quote 2
                            • ? Offline
                              A Former User @Manuel
                              @m_magalhaes Hi Manuel and thank you for this contribution. This code's data, however, is not persisting when I do the following:
                              • run the script to set the data
                              • close and reopen the document.
                              • comment out the lines setting the data (lines 11-19)
                              • run the script to print the data
                              Instead I get this error for doc[MyUniqueId]:
                              TypeError: 'NoneType' object has no attribute '__getitem__'
                              Also, is MyUniqueId supposed to be the PLUGIN_ID? Why is that not being used?
                              Thanks!
                              • CairynC Offline
                                Cairyn @Guest
                                @blastframe For me, it works fine this way. Did you really "close and reopen" the document? Not "save", "close", "load"? Because if you just close the document, the data from the container is gone, which leads to your error message.
                                The Q regarding MyUniqueId vs. PLUGIN_ID is not relevant (probably typed in a hurry), you can use either. But the ID value should come from Maxon in the end, so you avoid collisions with existing IDs.
                                • ? Offline
                                  @Cairyn I'm a little embarrassed, but you're right. I wasn't saving properly (I think just saving the Script) then going to the document in Recent Files. I'll mark this solved.
                                  Thank you all - @Cairyn ,@zipit ,@m_magalhaes .
                                    you could use the same ID, you just have to be sure that you are the only one to use that ID to store datas.
                                    That's why we use plugin's ID.
                                    Manuel.
                                    • ? Offline
                                      @m_magalhaes Thanks, Manuel.
                                      How would I delete the data of an individual sub-BaseContainer in the case of your script?
                                      I've tried several methods below but the doc[MyUniqueId][1000] still shows data in the print call.
                                      bc = doc.GetDataInstance().GetContainer(MyUniqueId)
                                      print bc.RemoveData(1000)
                                      # True
                                      print doc[MyUniqueId].RemoveData(1000)
                                      # True
                                      doc[MyUniqueId].FlushAll()
                                      #hello
                                      I was able to delete all of the data this way, but what if I want to keep the data in subBc[2000]?
                                      docBC.RemoveData(MyUniqueId)
                                      Thank you!
                                        hello,
                                        there's a difference between GetContainer and GetContainerInstance
                                        The first return a copy of the container the second the original link.
                                        So either you retrieve a copy and set back the container to the parent with SetData and/or SetContainer
                                        or you retrieve the original link and the changes are reflected immediately.
                                        You can also use del that is pythonic
                                            bc = doc.GetDataInstance().GetContainerInstance(MyUniqueId)
                                            bc.RemoveData(2000)
                                            #del (bc[2000])
                                        • ? Offline
                                          @m_magalhaes said in Writing data to the .c4d file:
                                              bc.RemoveData(2000)
                                              #del (bc[2000])
                                          Wonderful, @m_magalhaes , thank you so much!
