    Problems with Reloading Python Plugins in Cinema 4D 2024.1.0
    2024python
    14 Posts 5 Posters 2.7k Views 1 Watching
    • RenatoTR Offline
      RenatoT
      Hello everyone,
      I have read the documentation for Cinema 4D version 2024.0.1, which states that a 'stability issue with reloading Python plugins' has been fixed. However, in the latest version, this functionality does not seem to be working as expected.
      I am encountering persistent problems in reloading Python plugins without having to restart the entire application each time. This is significantly impacting my workflow. I am wondering if anyone else in the community is facing similar issues, or if I might be missing some crucial step in the plugin reloading process.
      Any insights or shared experiences would be greatly appreciated. Thank you in advance for your support and responses.
      • M Offline
        m_adam
        Hi @RenatoT, with the information you provided it will be hard for us to really pinpoint the issue.
        How is your project? Do you have 1 pyp file or multiple one? Which part of your function are not exactly reloaded?
        What are the issue you are encountering?
        • RenatoTR Offline
          RenatoT
          Hi Maxime, all my plugins that I was editing on the 2023 version (which I can no longer use because it crashes with my RTX 4080 OGL drivers) are not being loaded anymore on the 2024 version after modification, and I have to close and reopen Cinema. I don't have duplicate sources or anything else. It simply doesn't reload them as the old versions used to do.
          bacaB 1 Reply Last reply Reply Quote 0
          • M Offline
            m_adam
            Hi having the ability to reproduce your issue would be the first step. so would it be possible for you to share one of your plugin demonstrating the issue at [email protected] ?
            How do you see that it fail to be loaded? Normally you can only change already loaded plugin, with reload plugin you are not allowed to register new plugin. So at least your plugin should be still there.
            And finally what is your OS?
            Thanks in advance.
            • RenatoTR Offline
              RenatoT
              Yes, my plugin loads and runs correctly on both 2023 and 2024. It registers and works. The difference is that 'Reload Python Plugins' after source code modifications works on 2023, but not on 2024. I have developed about ten plugins on the previous versions... but on 2024 the code is not updated even though in the Python console the plugin writes the message of successful loading. Simply, the code remains the same as before. On the older versions of Cinema, I have never encountered this problem. If it works correctly for you, then the problem is in my installation.
              • M Offline
                m_adam
                Hi just to let you know I was able to reproduce the issue, it seems that only some part are loaded and not everything e.g. in an ObjectData, the GetVirtualObject method is not correctly reloaded. I'm investigating the issue and hopefully will be able to fix it soon, but I doubt there will be any workaround possible for the 2024.0 and 2024.1 release.
                RenatoTR 1 Reply Last reply Reply Quote 0
                • bacaB Offline
                  baca @RenatoT
                  Hi @RenatoT
                  Looks like existing instances of the plugin aren't updated after "Python Reload", or partially updated.
                  That's just my thought, but faced similar issue when switched to C4D2024.
                  So now I'm closing current project(s), and only blank project is remain opened in app.
                  Then execute "Reload Python plugins".
                  The re-open test scene, or create new from scratch.
                  Not optimal, but more or less stable on my macOs machine.
                  • RenatoTR Offline
                    RenatoT @m_adam
                    @m_adam said in Problems with Reloading Python Plugins in Cinema 4D 2024.1.0:
                    Thank you Maxime, I hope that the issue will be resolved as soon as possible because I am unable to use the 2023 version due to compatibility problems with the Nvidia drivers.
                    • RenatoTR Offline
                      RenatoT
                      @baca So I'm not alone. Many thanks for your suggestion šŸ™‚
                      • RenatoTR Offline
                        RenatoT
                        @maxime I have also noticed that on the 2024 version, in case of an error in the .res file, classic syntax errors, no dialog is opened to warn of the error and indicate the line in the res file where the problem is. On the 2024 version, it simply does not load the GUI and does not report anything.
                        • K Offline
                          kalugin
                          I've also had the same issues with an ObjectData plugin. I've also noticed a huge memory leak by simple clicking the reload python plugins button, but that could have been something from my code.
                          • gheyretG Offline
                            gheyret
                            I had the same problem yesterday works
                            www.boghma.com
                            • M Offline
                              m_adam
                              Hi @kalugin there was a memory leak in 2024.0 but it was fixed in 2024.1. Could you send us a file at [email protected] and the plugin to test, as we would like to ensure the memory leak is indeed gone.
                              Regarding the issue, it will be fixed in an upcoming release.
                              • M Offline
                                m_adam
                                Hi thanks a lot for your report, the issue regarding Reloading Python Plugin not working as expected have been fixed in 2024.2.
