    Objects are still not displayed after ChangeNBit is works
    Scheduled Pinned Locked Moved Bugs
    python20242025
    3 Posts 2 Posters 1.6k Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi Everyone!
      I'm Trying to use GeListNode.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_SET) to hide some objects and save the project file and close it.
      And I open the project file again and try to using GeListNode.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_CLEAR), I find that although the code works, but the hidden objects are still not displayed in viewport.
      Is this a bug or something special thing happend?
      This is the project file I tested, and it's already hide the 4 objects top of the OM:
      show-hide_test.c4d
      And this the simple testing code for displayed them:
          objs = doc.GetObjects()
          for obj in objs:
              if obj.GetNBit(c4d.NBIT_EHIDE):
                  print(obj.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_CLEAR))
                  print(obj.GetNBit(c4d.NBIT_EHIDE))
      P.S: I also found that after running the test code in the above project file and saving the project, closing it and then opening it again, those hidden objects came back.
      www.boghma.com
      • M Offline
        m_adam
        Hi, thanks a lot for the report, I filled a bug report.
        As a workaround you can enable and disable the deform mode and it will work.
            for obj in objs:
                    if obj.GetDeformMode():
                        obj.SetDeformMode(False)
                        obj.SetDeformMode(True)
        gheyretG 1 Reply Last reply Reply Quote 0
        • M m_adam moved this topic from Cinema 4D SDK on
        • gheyretG Offline
          gheyret @m_adam
          Thank you for your reply and solution!
          Cheers~
          www.boghma.com
