    Objects are still not displayed after ChangeNBit is works
    python20242025
    3 Posts 2 Posters 903 Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi Everyone!
      I'm Trying to use GeListNode.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_SET) to hide some objects and save the project file and close it.
      And I open the project file again and try to using GeListNode.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_CLEAR), I find that although the code works, but the hidden objects are still not displayed in viewport.
      Is this a bug or something special thing happend?
      This is the project file I tested, and it's already hide the 4 objects top of the OM:
      show-hide_test.c4d
      And this the simple testing code for displayed them:
          objs = doc.GetObjects()
          for obj in objs:
              if obj.GetNBit(c4d.NBIT_EHIDE):
                  print(obj.ChangeNBit(c4d.NBIT_EHIDE, c4d.NBITCONTROL_CLEAR))
                  print(obj.GetNBit(c4d.NBIT_EHIDE))
      P.S: I also found that after running the test code in the above project file and saving the project, closing it and then opening it again, those hidden objects came back.
      www.boghma.com
        Hi, thanks a lot for the report, I filled a bug report.
        As a workaround you can enable and disable the deform mode and it will work.
            for obj in objs:
                    if obj.GetDeformMode():
                        obj.SetDeformMode(False)
                        obj.SetDeformMode(True)
        gheyretG 1 Reply Last reply Reply Quote 0
        • M m_adam moved this topic from Cinema 4D SDK on
        • gheyretG Offline
          gheyret @m_adam
          Thank you for your reply and solution!
          Cheers~
          www.boghma.com
