    Get Selected Keyframes?
    20232024python
    6 Posts 2 Posters 1.5k Views 1 Watching
    • B Offline
      bentraje
      Is there now an API in getting the selected keyframe?
      Much like doc.GetActiveObjects or doc.GetActiveMaterials
      My end goal operation is change the tangent handles (in the graph editor) of the selected kefyrames.
      The closest solution is in this thead (https://developers.maxon.net/forum/topic/10989/how-to-get-the-selected-keyframes-in-active-timeline-fcurve-manager/7)
      But it doesn't work on the latest versions of Cinema4D (even if you changed it to Python 3 syntax).
      Is there a way around this?
        ferdinand @bentraje
        Hello @bentraje,
        Thank you for reaching out to us. There always has been a means to retrieve the selection states of keyframes, namely the bit flags NBIT_TL1_SELECT, ..., NBIT_TL4_SELECT. There are no plans to extend this with convenance methods, as this is just fine as is. On c4d.BaseList2D there are some keyframe selection convenance methods, but they are very specialized and probably not too useful for the average Python user.
        There is also a slight bump in the road here, namely that a CKey is a C4DAtom and a GeListNode, but not a BaseList2D, which is a quite uncommon thing. This throws a wrench into the usual way of determining a selection state, BaseList2D.GetBit(c4d.BIT_ACTIVE). The reason is that there can be up to four dope sheet timeline editors active at once, which each can have its own selection state. Therefore there are four answers to the question "is this keyframe selected in a dopesheet editor?".
        Find a simple example attached below.
        Result:
        Code:
        """Prints out the selection state of keyframes for the currently selected object.
        Because there can be up to four timelines which do not share a selection state, there are four
        answers to the question "is this keyframe selected?".
            if not op:
            # Iterate over all tracks of the active object.
            track: c4d.CTrack
            for track in op.GetCTracks():
                curve: c4d.CCurve = track.GetCurve()
                # Iterate over all keys of the curve of this track.
                for i in range(curve.GetKeyCount()):
                    key: c4d.CKey = curve.GetKey(i)
                    # Check if the key #i is selected in any of the up to four timeline editors.
                    for n in (c4d.NBIT_TL1_SELECT,
                              c4d.NBIT_TL2_SELECT,
                              c4d.NBIT_TL3_SELECT,
                              c4d.NBIT_TL4_SELECT):
                        isSelected: bool = key.GetNBit(n)
                        if isSelected:
                            # NBIT_TL1_SELECT has the value 5, NBIT_TL2_SELECT 6, etc.
                            print (f"The key {key} in the track {track} is selected in the timeline '{n - 4}'.")
        • B Offline
          bentraje
          Thanks for the response. This is probably the info I missed out:
          I tried your code but I'm not sure if its a bug.
          If I select a key in the timeline (dope sheet mode). It works.
          But if I select a key in the timeline (fcurve sheet mode). It doesn't.
          (It spits out a value but the value it spits out is the last selected key in dopesheet and not the actively selected key in fcurve)
          So I'm guessing I need to replace NBIT_TL1_SELECT with NBIT_TL1_FCSELECT but it still doesn't work.
          Am I missing something?
            ferdinand @bentraje
            The NBITs you are looking for are NBIT_TL1_SELECT2 ... NBIT_TL4_SELECT2.
            • B Offline
              bentraje
              Slr. I can confirm the "Select2" works as expected.
              Just want to point out though. That option is present in the documentation but doesn't have a proper description (?).
              It's set to Private.
              https://developers.maxon.net/docs/py/2024_2_0/consts/NBIT.html?highlight=nbit_tl1_select
                ferdinand @bentraje
                Hey @bentraje,
                yes, we are aware that internal and private tags are something that plagues our documentation as they often have been abused by developers to skip documentation. But that is not so easy to fix.
                I for example did and still do not know the purpose NBIT_TLX_SELECT2 either. I was just experienced enough with the C4D API to poke in this place first.
                Physically fixing the docs, i.e., adding a blab here or there, is not the problem. The problem is to evaluate if the private tag in C++ (which then radiates into Python) is well founded or not, especially for ancient things like this. I would have to read a lot of code to make an assessment if this should be private or not, and even then would not be sure. And even an 'Expresses the selection state of f-curve keys. @markprivate' is problematic because for that I would have to be sure that it does not have a weird side effect.
