    Object Plugin - Generator Objects - Hiding the child objects in Editor View
    windowsr23python2023
    6 Posts 4 Posters 1.4k Views 3 Watching
    • ThomasBT Offline
      ThomasB
      Happy New Year
      I have an internal development question.
      How does this work, for example with Generators such as the Boole Object or Spline-Mask, when two objects are under the Bool-Object as childs, but these are no longer visible in their original form in the Editor View? But only the newly created object. They have to be hidden somehow but they are still visible in the Object Manager.
      • How does this work exactly?
      • Does this happen when registering the plugin with the method and specifying the info argument and type
      plugins.RegisterObjectPlugin(info=type))
      • Or do they have to be saved in a variable and deleted somehow or is there a Function to make them invisible?
      Just to get the idea?
      Thanks,
      T.B
      CJtheTigerC 1 Reply Last reply Reply Quote 0
      • CJtheTigerC Offline
        CJtheTiger @ThomasB
        Hi @ThomasB,
        ~~these generators are (probably) plugins of type ObjectData. These plugins implement the GetVirtualObjects method which returns what will be drawn on the screen, and only this will be drawn with complete disregard of the children. They do use their children as inputs to generate the result which you then see but the children themselves are not returned by GetVirtualObjects.
        See also the documentation on ObjectData.~~
        Seems I was wrong about this, sorry. Maybe this plays together with TouchDependenceList but I'm not sure so I'll just keep my mouth shut now.
        Daniel
        ThomasBT 1 Reply Last reply Reply Quote 0
        • ThomasBT Offline
          ThomasB @CJtheTiger
          @CJtheTiger
          thanks
          But that doesn't seem to work because if, for example, I create an object plug-in that returns a cube in the GetVirtualObjects() method and I assign 2 objects to this plug-in in the Object Manager, then I still see the child objects in the editor window.
          Do I have to set a parameter or a flag somewhere to specify the ObjectPlugin somehow?
          Thanks,
          T.B
          • M Offline
            m_adam
            Hi there is 2 options, the first one is to pass the flag OBJECT_INPUT when used with OBJECT_GENERATOR this will force the generator to touch the children object.
            The second option, is to manually touch the object either by calling BaseObject.Touch or via a DependencyList as explained in this C++ manual (all methods exist in Python)
            Touching an object means destructing its cache (so if there is no cache, there is nothing to show...), it also define BIT_CONTROLOBJECT on the child object and finally it reset it's dirty state.
            ThomasBT 1 Reply Last reply Reply Quote 1
            • ThomasBT Offline
              ThomasB @m_adam
              @m_adam
              Thank you very much Maxime.
              But there is one more thing I would like to know.
              Why don't the highlighted links work? I am always referred to this site.
              Thanks,
              T.B
                ferdinand @ThomasB
                Hey @ThomasB,
                That has nothing to do with the highlighting but with the fact that Maxime used incorrect links. developers.maxon.net/docs/ links will only work from outside of the forum. Inside the forum you currently have to use dvelopers.maxon.net/assets/docs/ as otherwise nodebb is trying to take over the routing. I am working on fixing that issue.
                I have fixed both links of Maxime.
