    Renaming bug in COFFEE
    19 Posts 0 Posters 2.0k Views
      On 20/01/2005 at 08:05, xxxxxxxx wrote:
      Hi, was willst du? Neue Namen oder neue Objekte mit neuem Namen?
      Gruß Tim
        On 20/01/2005 at 08:51, xxxxxxxx wrote:
        Just new names, I know how to create new objects:
        var newObj = new(objType);
        // insert into document
        doc->InsertObject(newObj, NULL, NULL);
        I´m just wondering why the code in my previous post creates new objects in the active doc.
          On 21/01/2005 at 00:49, xxxxxxxx wrote:
          try this:
          var obj;
          var objCont = obj->GetContainer();
          var objName = obj->GetName();
          var newName = "test_name";
          obj->SetName(newname + objName);
          newObj->Remove();
          Grüße aus Freiburg
          Tim
            On 21/01/2005 at 11:38, xxxxxxxx wrote:
            Thanks wegfressen, but you dont seem to understand what I´m getting at. I am not creating any new objects, I am renaming objects that are alreading in the scene.
              On 21/01/2005 at 14:15, xxxxxxxx wrote:
              Anybody? Could someone at least confirm this, then I know I can give up.
                On 21/01/2005 at 14:27, xxxxxxxx wrote:
                Have you tried changing 'newName' to something else? This might be slipping past the interpreter as 'new Name' or something. The actual code would be useful as well (iow, I suppose that 'var obj' has been set to an object in the Document's Object Manager or one that's about to be placed there).
                Robert
                  On 23/01/2005 at 04:49, xxxxxxxx wrote:
                  kuroyume0161, newname is a user set variable, it is retrieved from an edittext box in the GUI, var obj is dynamically set when the code climbs down a hierachy in the present document.
                    On 26/01/2005 at 05:49, xxxxxxxx wrote:
                    Well if Maxon would admit its a bug I would be happy, just plain not saying anything is a drag.
                      On 26/01/2005 at 23:57, xxxxxxxx wrote:
                      I can't confirm this bug. I used the following code in a menu plugin: (In the example you have written newname instead of newName. I also had to fill in obj myself.)
                          MyMenuPlugin::Execute(doc)
                            var obj = doc->FindObject("Cube");
                            obj->SetName(newName + objName);
                            GeEventAdd(ACTIVE_OBJECT_CHANGED);
                      There are no new objects created afaics. Where is the code run in your plugin? Could you post a little more code? (Preferably to the point where its a complete but scaled down plugin still showing the error.)
                        On 27/01/2005 at 08:22, xxxxxxxx wrote:
                        Thanks Michael for your reply, is it okay if I post you the code? If yes, where to?
                        > Quote: Originally posted by Mikael Sterner on 26 January 2005
                        \>  var obj = doc->FindObject("Cube");
                        \>  var objName = obj->GetName();
                        \>  var newName = "test_name";
                        \>  obj->SetName(newName + objName);
                        \>  GeEventAdd(ACTIVE_OBJECT_CHANGED);
                          On 27/01/2005 at 12:37, xxxxxxxx wrote:
                          If you don't want to post the code here you can send it to [email protected].
                            On 05/02/2005 at 13:39, xxxxxxxx wrote:
                            Hi Mikael, could you confirm the bug? I sent you a code snippet last week.
                              On 09/02/2005 at 03:59, xxxxxxxx wrote:
                              Sorry, I will have a look at it as soon as possible.
                                On 16/02/2005 at 14:38, xxxxxxxx wrote:
                                Hi Mike, have you checked up on my problem?
                                Sharriff
                                  On 20/02/2005 at 15:03, xxxxxxxx wrote:
                                  Hmm, I did run the code now by adding the missing parts to make it a complete function:
                                      GetGlobalRotation(obj);
                                      SetGlobalRotation(obj, rot);
                                      GetGlobalPosition(obj);
                                      SetGlobalPosition(obj, pos);
                                      // register plugin in menu
                                      class MyMenuPlugin : MenuPlugin
                                        MyMenuPlugin();
                                        GetID();
                                        GetName();
                                        GetHelp();
                                        Execute(doc);
                                      MyMenuPlugin::MyMenuPlugin() { super(); }
                                      MyMenuPlugin::GetID()        { return 13215235; }
                                      MyMenuPlugin::GetName()      { return "Hello World"; }
                                      MyMenuPlugin::GetHelp()      { return "Demonstrates a simple modal dialog";
                                       mirrorEditOrigBone(doc->GetFirstObject());
                                      prefixOrigBone = "bar";
                                      prefixMirrorBone = "foo";
                                       Register(MyMenuPlugin);
                                  Then I added a bone to the scene and ran the plugin. As expected I get two new bones, one named "fooBone" and one named "barBone". Do you get more than two bones if you do that? That sounds really weird. I tried both in 9.013 and 9.101, but unless I can duplicate the bug there's not much I can do. Does the bug show up if you do a small expression that renames stuff as well?
                                    On 22/02/2005 at 12:31, xxxxxxxx wrote:
                                    Thanks for looking into my problem Mike, yes, the problem arises only when I rename the bones, this happens in 8.2, 9.0 and 9.1. I use a recursive function to traverse the hierachy, in the loop, I create and name bones, this works well if i dont rename the bones. I I do, I get the renamed bones, the clones and the original bones in addition.
                                      On 28/02/2005 at 12:48, xxxxxxxx wrote:
                                      Have you checked up on the bug Mikael?
                                      Thanks.
                                        On 28/02/2005 at 13:43, xxxxxxxx wrote:
                                        I still haven't been able to reproduce it. My bones rename just fine with the code you sent. Sorry that this has taken so long, but unless I can duplicate the behaviour I can't find out what's wrong.
                                        Just to be absolutely eliminate all sources of confusion, could you send a specific scene and the whole plugin to the support account? (Please remove as much code as possible, while making sure that the error still occurs on your side.)
