    Renaming bug in COFFEE
    19 Posts 0 Posters 2.0k Views
      On 23/01/2005 at 04:49, xxxxxxxx wrote:
      kuroyume0161, newname is a user set variable, it is retrieved from an edittext box in the GUI, var obj is dynamically set when the code climbs down a hierachy in the present document.
        On 26/01/2005 at 05:49, xxxxxxxx wrote:
        Well if Maxon would admit its a bug I would be happy, just plain not saying anything is a drag.
          On 26/01/2005 at 23:57, xxxxxxxx wrote:
          I can't confirm this bug. I used the following code in a menu plugin: (In the example you have written newname instead of newName. I also had to fill in obj myself.)
              MyMenuPlugin::Execute(doc)
                var obj = doc->FindObject("Cube");
                var objName = obj->GetName();
                var newName = "test_name";
                obj->SetName(newName + objName);
                GeEventAdd(ACTIVE_OBJECT_CHANGED);
          There are no new objects created afaics. Where is the code run in your plugin? Could you post a little more code? (Preferably to the point where its a complete but scaled down plugin still showing the error.)
            On 27/01/2005 at 08:22, xxxxxxxx wrote:
            Thanks Michael for your reply, is it okay if I post you the code? If yes, where to?
            > Quote: Originally posted by Mikael Sterner on 26 January 2005
            \>  var obj = doc->FindObject("Cube");
            \>  var objName = obj->GetName();
            \>  var newName = "test_name";
            \>  obj->SetName(newName + objName);
            \>  GeEventAdd(ACTIVE_OBJECT_CHANGED);
              On 27/01/2005 at 12:37, xxxxxxxx wrote:
              If you don't want to post the code here you can send it to [email protected].
                On 05/02/2005 at 13:39, xxxxxxxx wrote:
                Hi Mikael, could you confirm the bug? I sent you a code snippet last week.
                  On 09/02/2005 at 03:59, xxxxxxxx wrote:
                  Sorry, I will have a look at it as soon as possible.
                    On 16/02/2005 at 14:38, xxxxxxxx wrote:
                    Hi Mike, have you checked up on my problem?
                    Sharriff
                      On 20/02/2005 at 15:03, xxxxxxxx wrote:
                      Hmm, I did run the code now by adding the missing parts to make it a complete function:
                          GetGlobalRotation(obj);
                          SetGlobalRotation(obj, rot);
                          GetGlobalPosition(obj);
                          SetGlobalPosition(obj, pos);
                          // register plugin in menu
                          class MyMenuPlugin : MenuPlugin
                            MyMenuPlugin();
                            GetID();
                            GetName();
                            GetHelp();
                            Execute(doc);
                          MyMenuPlugin::MyMenuPlugin() { super(); }
                          MyMenuPlugin::GetID()        { return 13215235; }
                          MyMenuPlugin::GetName()      { return "Hello World"; }
                          MyMenuPlugin::GetHelp()      { return "Demonstrates a simple modal dialog";
                           mirrorEditOrigBone(doc->GetFirstObject());
                          prefixOrigBone = "bar";
                          prefixMirrorBone = "foo";
                           Register(MyMenuPlugin);
                      Then I added a bone to the scene and ran the plugin. As expected I get two new bones, one named "fooBone" and one named "barBone". Do you get more than two bones if you do that? That sounds really weird. I tried both in 9.013 and 9.101, but unless I can duplicate the bug there's not much I can do. Does the bug show up if you do a small expression that renames stuff as well?
                        On 22/02/2005 at 12:31, xxxxxxxx wrote:
                        Thanks for looking into my problem Mike, yes, the problem arises only when I rename the bones, this happens in 8.2, 9.0 and 9.1. I use a recursive function to traverse the hierachy, in the loop, I create and name bones, this works well if i dont rename the bones. I I do, I get the renamed bones, the clones and the original bones in addition.
                          On 28/02/2005 at 12:48, xxxxxxxx wrote:
                          Have you checked up on the bug Mikael?
                          Thanks.
                            On 28/02/2005 at 13:43, xxxxxxxx wrote:
                            I still haven't been able to reproduce it. My bones rename just fine with the code you sent. Sorry that this has taken so long, but unless I can duplicate the behaviour I can't find out what's wrong.
                            Just to be absolutely eliminate all sources of confusion, could you send a specific scene and the whole plugin to the support account? (Please remove as much code as possible, while making sure that the error still occurs on your side.)
