    Renaming bug in COFFEE
    SDK Help
    0
    19
    1.3k
    • H
      On 20/01/2005 at 04:27, xxxxxxxx wrote:
      Cinema 4D Version:   9
      Hi all, I´m experincing strange behaviour trying to renamin an object in cinema
      var obj;
      var objCont = obj->GetContainer();
      var objName = obj->GetName();
      var newName = "test_name";
      obj->SetName(newname + objName);
      this renames the object using the new Name as a prefix, but creates NEW!?? objects in the scene.
      Am I doing something wrong or is this a bug?
      thanks
      • H
        On 20/01/2005 at 08:05, xxxxxxxx wrote:
        Hi, was willst du? Neue Namen oder neue Objekte mit neuem Namen?
        Gruß Tim
        • H
          On 20/01/2005 at 08:51, xxxxxxxx wrote:
          Just new names, I know how to create new objects:
          var newObj = new(objType);
          // insert into document
          doc->InsertObject(newObj, NULL, NULL);
          I´m just wondering why the code in my previous post creates new objects in the active doc.
          • H
            On 21/01/2005 at 00:49, xxxxxxxx wrote:
            try this:
            var obj;
            newObj->Remove();
            Grüße aus Freiburg
            Tim
            • H
              On 21/01/2005 at 11:38, xxxxxxxx wrote:
              Thanks wegfressen, but you dont seem to understand what I´m getting at. I am not creating any new objects, I am renaming objects that are alreading in the scene.
              • H
                On 21/01/2005 at 14:15, xxxxxxxx wrote:
                Anybody? Could someone at least confirm this, then I know I can give up.
                • H
                  On 21/01/2005 at 14:27, xxxxxxxx wrote:
                  Have you tried changing 'newName' to something else? This might be slipping past the interpreter as 'new Name' or something. The actual code would be useful as well (iow, I suppose that 'var obj' has been set to an object in the Document's Object Manager or one that's about to be placed there).
                  Robert
                  • H
                    On 23/01/2005 at 04:49, xxxxxxxx wrote:
                    kuroyume0161, newname is a user set variable, it is retrieved from an edittext box in the GUI, var obj is dynamically set when the code climbs down a hierachy in the present document.
                    • H
                      On 26/01/2005 at 05:49, xxxxxxxx wrote:
                      Well if Maxon would admit its a bug I would be happy, just plain not saying anything is a drag.
                      • H
                        On 26/01/2005 at 23:57, xxxxxxxx wrote:
                        I can't confirm this bug. I used the following code in a menu plugin: (In the example you have written newname instead of newName. I also had to fill in obj myself.)
                            MyMenuPlugin::Execute(doc)
                              var obj = doc->FindObject("Cube");
                              obj->SetName(newName + objName);
                              GeEventAdd(ACTIVE_OBJECT_CHANGED);
                        There are no new objects created afaics. Where is the code run in your plugin? Could you post a little more code? (Preferably to the point where its a complete but scaled down plugin still showing the error.)
                        • H
                          On 27/01/2005 at 08:22, xxxxxxxx wrote:
                          Thanks Michael for your reply, is it okay if I post you the code? If yes, where to?
                          > Quote: Originally posted by Mikael Sterner on 26 January 2005
                          \>  var obj = doc->FindObject("Cube");
                          \>  var objName = obj->GetName();
                          \>  var newName = "test_name";
                          \>  obj->SetName(newName + objName);
                          \>  GeEventAdd(ACTIVE_OBJECT_CHANGED);
                          • H
                            On 27/01/2005 at 12:37, xxxxxxxx wrote:
                            If you don't want to post the code here you can send it to [email protected].
                            • H
                              On 05/02/2005 at 13:39, xxxxxxxx wrote:
                              Hi Mikael, could you confirm the bug? I sent you a code snippet last week.
                              • H
                                On 09/02/2005 at 03:59, xxxxxxxx wrote:
                                Sorry, I will have a look at it as soon as possible.
                                • H
                                  On 16/02/2005 at 14:38, xxxxxxxx wrote:
                                  Hi Mike, have you checked up on my problem?
                                  Sharriff
                                  • H
                                    On 20/02/2005 at 15:03, xxxxxxxx wrote:
                                    Hmm, I did run the code now by adding the missing parts to make it a complete function:
                                        GetGlobalRotation(obj);
                                        SetGlobalRotation(obj, rot);
                                        GetGlobalPosition(obj);
                                        SetGlobalPosition(obj, pos);
                                        // register plugin in menu
                                        class MyMenuPlugin : MenuPlugin
                                          MyMenuPlugin();
                                          GetID();
                                          GetName();
                                          GetHelp();
                                          Execute(doc);
                                        MyMenuPlugin::MyMenuPlugin() { super(); }
                                        MyMenuPlugin::GetID()        { return 13215235; }
                                        MyMenuPlugin::GetName()      { return "Hello World"; }
                                        MyMenuPlugin::GetHelp()      { return "Demonstrates a simple modal dialog";
                                         mirrorEditOrigBone(doc->GetFirstObject());
                                        prefixOrigBone = "bar";
                                        prefixMirrorBone = "foo";
                                         Register(MyMenuPlugin);
                                    Then I added a bone to the scene and ran the plugin. As expected I get two new bones, one named "fooBone" and one named "barBone". Do you get more than two bones if you do that? That sounds really weird. I tried both in 9.013 and 9.101, but unless I can duplicate the bug there's not much I can do. Does the bug show up if you do a small expression that renames stuff as well?
                                    • H
                                      On 22/02/2005 at 12:31, xxxxxxxx wrote:
                                      Thanks for looking into my problem Mike, yes, the problem arises only when I rename the bones, this happens in 8.2, 9.0 and 9.1. I use a recursive function to traverse the hierachy, in the loop, I create and name bones, this works well if i dont rename the bones. I I do, I get the renamed bones, the clones and the original bones in addition.
                                      • H
                                        On 28/02/2005 at 12:48, xxxxxxxx wrote:
                                        Have you checked up on the bug Mikael?
                                        Thanks.
                                        • H
                                          On 28/02/2005 at 13:43, xxxxxxxx wrote:
                                          I still haven't been able to reproduce it. My bones rename just fine with the code you sent. Sorry that this has taken so long, but unless I can duplicate the behaviour I can't find out what's wrong.
                                          Just to be absolutely eliminate all sources of confusion, could you send a specific scene and the whole plugin to the support account? (Please remove as much code as possible, while making sure that the error still occurs on your side.)
