    Custom node-locked licensing: Bypassing checks for Team Renderer, Clients, Server safely?
    python2023202420252026windows
    3 Posts 2 Posters 452 Views 2 Watching
    • ThomasBT Offline
      ThomasB
      I am using a custom node-locked licensing system (2 Nodes) for my Cinema 4D plugin. Since Team Render clients running on other machines shouldn't consume a license activation, I want to bypass the license check on startup for them.
      My plan is to check c4d.isClient() or rather, c4d.GeGetVersionType() right before the licensing routine and skip it if it returns true.
      Example:
      client = c4d.GeGetVersionType()
      if client == c4d.VERSIONTYPE_TEAMRENDER_CLIENT or client == c4d.VERSIONTYPE_TEAMRENDER_SERVER:
              print("yes free rendering for all")
      My question: Is c4d.isClient() or c4d.GeGeVersionType() reliable and secure against spoofing, meaning a user couldn't just fake this flag on a normal Cinema 4D master instance to bypass the node-lock? Or is there a better way to handle this for Team Renderer, Clients and Server?
      Thanks!
      T.B
        ferdinand @ThomasB
        Hey @ThomasB,
        while I understand the direction, your question is a bit ambiguous. What would you consider 'reliable and secure against spoofing'? This very much a question of perspective. Everything can be faked and altered with enough knowledge and determination when the data is local. The functions you mention are based on our licensing API (and are also a bit outdated, you should use the newer endpoints). This API is used by Maxon products itself to verify licenses and is considered secure enough for that purpose. However, nothing prevents a user from patching the Cinema binary so that these functions return whatever the user wants. But that is of course expert knowledge domain.
        I would recommend using the relative new Licensing Manual which also explains how to identify the current product and how to find out how many licenses of a given type are available in a user account. In the video I also touch the subject of hardening for plugin licenses, the TLDR is: Do not over-do it, it is not worth the effort. Everything can be cracked.
        ThomasBT 1 Reply Last reply Reply Quote 0
        • ThomasBT Offline
          ThomasB @ferdinand
          Yes, thanks, that indirect answer is enough for me. I was mainly wondering whether a check performed on both the client and the server is robust enough, or if it could be bypassed using Python, for instance. I’m well aware that it can be cracked somehow. I’m also already using ExportLicenses() for my node-locking system in combination.
          Thanks a lot for your help.
          T.B
