    How do I get the cache of a cloner in an ObjectData Plugin
    20232024r23r25python
    4 Posts 2 Posters 1.0k Views 2 Watching
    • ThomasBT Offline
      ThomasB
      Hi, sorry for this as always dumb question.
      I was trying to get the Cache of a cloner object in the GetVirtualObjects(self, op, hh) method.
      First I tried it in the python generator, there was already a cloner in the scene and in the python generator I returned the cache so to say, but this approach doesn´t work out in an object plugin.
      Even if I create a temp_doc. The returned cache is always None.
      But converting the cloner with a ModelingCommand is not the best way, if the cloner produces for instance a million clones.
      This method works in a python generator when the clone is already in the scene
      cloner = op.GetDown()
      return cloner.GetCache().GetClone()
      But creating a cloner and returning its cache doesn`t work.
      cloner = c4d.BaseObject(1018544)
      c4d.BaseObject(c4d.Ocube).InsertUnder(cloner)
      Is there a way to get the cache in a plugin?
      Sweep, Extrude, other Generators, Deformers and parametric objects work perfectly.
      T.B
        ferdinand @ThomasB
        Hey @ThomasB,
        thank you for reaching out to us. First of all, there are no dumb questions 🙂 Caches must be built, and a newly allocated object has no cache. Please have a look at geometry_caches_s26.py for an introduction into caches, including how to build them.
        ThomasBT 1 Reply Last reply Reply Quote 0
        • ThomasBT Offline
          ThomasB @ferdinand
          oh man thanks I forgot this
          BaseDocument.ExecutePasses(bt=None, animation=False, expressions=False, caches=True, flags=c4d.BUILDFLAGS_NONE)
          I tried that before but it seems I have set the caches parameter wrong.
          Thank you very much....
          T.B
            Good to hear!
