    Encrypt .pyp file to .pypv with script or command line?
    2024python
    4 Posts 3 Posters 966 Views 3 Watching
    • F Offline
      f2b86
      Is it possible to encrypt .pyp files with script, like manual source protector in C4D would do it?
      I thought it was possible with c4dpy, but unfortunately it doesn't seem to work.
      Regards.
        Hi g_encryptPypFile="file" should work as explained in c4dpy - CommandLine, note that this is a general command line so you can also use Cinema 4D.
        Maxime
        • J Offline
          JACK0319
          here is some code i used for create pypv
          def call_c4dpy(C4D_PATH, cmd):
              # 需要把c4dpy.exe所在路径添加到环境变量
              # C4D_PATH = r"~\Maxon Cinema 4D R26"
              if C4D_PATH not in os.environ["PATH"]:
                  os.environ["PATH"]+=f"{C4D_PATH};"
              # cmd 也可以是脚本路径 cmd = r"~\c4dtest script.py"
              _cmd = f"c4dpy \"{cmd}\"" # 脚本路径必须是字符串
              subprocess.call(_cmd) # 调用并且可以实时看到结果
          def creat_pypv(C4D_PATH, plugin_path):
              # pyp 生成 pypv
              # c4dpy.exe g_encryptPypFile="G:\C4D JACK Plugins\G4Designer\G4Designer.pyp"
              cmd = f"c4dpy g_encryptPypFile=\"{plugin_path}\""
          • F Offline
            f2b86
            Thank you, it works perfectly!
            • ferdinandF ferdinand forked this topic on
