    How to Encrypt Python Plugins without a License?
    python2025
    2 Posts 2 Posters 414 Views
    This topic was forked from Encrypt .pyp file to .pypv with script or command line? ferdinand
    • kbarK Offline
      kbar
      @m_adam I just thought I would try use this command line method to create a pypv file as part of my build and publishing process. I found that it requires a valid license for this to work. I was wondering if this would be able to be changed so that this particular feature does not need licensing to call it. Since I would like this to be on a build machine and it doesn't really make sense to have a full C4D license just for this one purpose. As it stands I can't use this great feature (which I actually think I proposed in another thread quite a while back). I am only just getting back into some python plugin work and it would have been great to have.
      https://www.gamelogicdesign.com
      https://www.plugins4d.com
        ferdinand @kbar
        Hey @kbar,
        thank you for reaching out to us. Please remember creating new topics instead of posting in older one's, so that our forum remains a searchable database. I have forked your question.
        I understand the necessity and use case for this, but in the proposed form, this is not possible. At least not without more work than it makes sense to invest here. Because the license validation is one of the first steps in the boot sequence of Cinema 4D, and trying to evaluate a command line argument and use all the components of our API necessary to encrypt a file could easily lead to problems (as these modules might not have been loaded yet).
        What we could think about is offering this as a standalone tool. The issue is here that we cannot just ship the source for that tool (for third parties to compile it themself) as the source would then also be known to bad actors. And shipping it as a binary would be extra work. An alternative could be a REST service, but that is also extra work (but less than the former route). I currently have no time for either of this. At the end of the year I will probably do some website work, then we could think about the REST route. But it is likely that I then also do not have time for this.
        As an MRD, you also have the option to ask in our beta forums or make a source code sharing request. In the end, this is very simple code and could probably easily emulated with a couple of lines of Python code. That is probably the most sensible route, but we would have to involve PMs etc. here, if we are willing to do that. I myself am even not sure if I would greenlight such request due to the sensitive nature of the topic.
        So, unfortunately, there is no clear cut route here, although I definitely can see the use case.
