    CreateRay
    sdkc++
    6 Posts 5 Posters 1.2k Views 2 Watching
    • Z Offline
      zmilez
      I used the example code from
      https://developers.maxon.net/forum/topic/11585/example-createray?_=1639590161417
      to build a VideoPostData plugin to modify the rays.
      I noticed CreateRay wouldnt work with other renderers Vray, Corona,
      but was wondering if there was a way to hook up the plugin to work with Redshift
      Or if Redshift has its own SDK
      Any info much appreciated.
        While Redshift can call this function, it calls it only once. And some renders are not rays based, so it doesn't make senses for them.
        What are you trying to achieve?
        rsodreR 1 Reply Last reply Reply Quote 0
          Hello @zmilez,
          without any further questions or postings, we will consider this thread as solved by Friday the 4th, February 2022.
          • rsodreR Offline
            rsodre @Manuel
            Hey @Manuel ,
            Do you mean RedShift is compatible with C4D lens effects?
            Can I really use CreateRay() with RedShift?
            I have a lens plugin that works well on the standard renderer but not on the RS camera.
            Is there anything extra to do to enable it on RS?
            Thanl you,
            Roger
            • i_mazlovI Offline
              i_mazlov
              Hi @rsodre ,
              CreateRay() is not fully functional with RS and this is likely what Manuel meant by saying that is called by RS only once.
              Ilia
              • rsodreR Offline
                rsodre
                Ok, but if RS can call it, when and how does it?
                Call just once... makes no sense, because the effect calls once per pixel at least, on every frame.
                Why would RS call it in a different context?
                What do you mean not fully functional?
                Is it partially functional?
                How so?
