<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CreateRay]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I used the example code from<br />
<a href="https://developers.maxon.net/forum/topic/11585/example-createray?_=1639590161417" target="_blank" rel="noopener noreferrer nofollow ugc">https://developers.maxon.net/forum/topic/11585/example-createray?_=1639590161417</a><br />
to build a VideoPostData plugin to modify the rays.<br />
I noticed CreateRay wouldnt work with other renderers Vray, Corona,<br />
but was wondering if there was a way to hook up the plugin to work with Redshift<br />
Or if Redshift has its own SDK<br />
Any info much appreciated.</p>
]]></description><link>http://developers.maxon.net/forum/topic/13726/createray</link><generator>RSS for Node</generator><lastBuildDate>Mon, 05 Oct 2026 11:48:19 GMT</lastBuildDate><atom:link href="http://developers.maxon.net/forum/topic/13726.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Dec 2021 17:48:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CreateRay on Sat, 14 Oct 2023 04:41:08 GMT]]></title><description><![CDATA[<p dir="auto">Ok,  but if RS can call it, when and how does it?<br />
Call just once... makes no sense, because the effect calls once per pixel at least, on every frame.<br />
Why would RS call it in a different context?</p>
<p dir="auto">What do you mean not fully functional?<br />
Is it partially functional?<br />
How so?</p>
]]></description><link>http://developers.maxon.net/forum/post/72715</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72715</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Sat, 14 Oct 2023 04:41:08 GMT</pubDate></item><item><title><![CDATA[Reply to CreateRay on Fri, 13 Oct 2023 15:03:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/rsodre">@<bdi>rsodre</bdi></a> ,</p>
<p dir="auto">CreateRay() is not fully functional with RS and this is likely what Manuel meant by saying that is called by RS only once.</p>
<p dir="auto">Cheers,<br />
Ilia</p>
]]></description><link>http://developers.maxon.net/forum/post/72713</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72713</guid><dc:creator><![CDATA[i_mazlov]]></dc:creator><pubDate>Fri, 13 Oct 2023 15:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to CreateRay on Thu, 12 Oct 2023 01:27:33 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/manuel">@<bdi>Manuel</bdi></a> ,</p>
<p dir="auto">Do you mean RedShift is compatible with C4D lens effects?<br />
Can I really use CreateRay() with RedShift?</p>
<p dir="auto">I have a lens plugin that works well on the standard renderer but not on the RS camera.<br />
Is there anything extra to do to enable it on RS?</p>
<p dir="auto">Thanl you,<br />
Roger</p>
]]></description><link>http://developers.maxon.net/forum/post/72692</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/72692</guid><dc:creator><![CDATA[rsodre]]></dc:creator><pubDate>Thu, 12 Oct 2023 01:27:33 GMT</pubDate></item><item><title><![CDATA[Reply to CreateRay on Tue, 01 Feb 2022 17:47:46 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/zmilez">@<bdi>zmilez</bdi></a>,</p>
<p dir="auto">without any further questions or postings, we will consider this thread as solved by Friday the 4th, February 2022.</p>
<p dir="auto">Thank you for your understanding,<br />
Ferdinand</p>
]]></description><link>http://developers.maxon.net/forum/post/68352</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/68352</guid><dc:creator><![CDATA[ferdinand]]></dc:creator><pubDate>Tue, 01 Feb 2022 17:47:46 GMT</pubDate></item><item><title><![CDATA[Reply to CreateRay on Thu, 16 Dec 2021 18:57:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">While Redshift can call this function, it calls it only once. And some renders are not rays based, so it doesn't make senses for them.<br />
What are you trying to achieve?</p>
Manuel</p>
]]></description><link>http://developers.maxon.net/forum/post/68199</link><guid isPermaLink="true">http://developers.maxon.net/forum/post/68199</guid><dc:creator><![CDATA[Manuel]]></dc:creator><pubDate>Thu, 16 Dec 2021 18:57:39 GMT</pubDate></item></channel></rss>
