    How to add Button User Data with a Button GUI in python script?
    s24python
    3 Posts 2 Posters 1.7k Views 2 Watching
    • eZioPanE Offline
      eZioPan
      How can I add a button to an object with python?
      I'm trying to add a button to a Null Object, but only get a button userdata without button itself. Here is the code:
          null_object = c4d.BaseObject(c4d.Onull)
          ud_btn_bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BUTTON)
          ud_btn_bc.SetString(c4d.DESC_NAME, "Click")
          ud_btn_bc.SetString(c4d.DESC_SHORT_NAME, "click")
          null_object.AddUserData(ud_btn_bc)
          doc.InsertObject(null_object)
      It seems that creating a button user data from GUI is different from Python. But I don't know how to do it correctly in Python.
      Thanks!
        the function 'GetCustomDatatypeDefault' do not always return a BaseContainer with DESC_CUSTOMGUI defined. In the case of the 'Button' datatype, the returned BaseContainer is empty. You must define the custom GUI you want to use.
        In your case using ' ud_btn_bc.SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_BUTTON)' will work.
        • eZioPanE Offline
          eZioPan
          It works like a charm!
          Thanks a lot!
