How to add Button User Data with a Button GUI in python script?
How can I add a button to an object with python?
I'm trying to add a button to a
Null Object, but only get a button userdata without button itself. Here is the code:import c4d def main(): null_object = c4d.BaseObject(c4d.Onull) ud_btn_bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BUTTON) ud_btn_bc.SetString(c4d.DESC_NAME, "Click") ud_btn_bc.SetString(c4d.DESC_SHORT_NAME, "click") null_object.AddUserData(ud_btn_bc) doc.InsertObject(null_object) c4d.EventAdd() if __name__ == "__main__": main()It seems that creating a button user data from GUI is different from Python. But I don't know how to do it correctly in Python.
Thanks!
the function 'GetCustomDatatypeDefault' do not always return a BaseContainer with DESC_CUSTOMGUI defined. In the case of the 'Button' datatype, the returned BaseContainer is empty. You must define the custom GUI you want to use.
In your case using ' ud_btn_bc.SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_BUTTON)' will work.
Manuel -
It works like a charm!
Thanks a lot!
