    PySide2 for Python 2.7 Windows Version?
    r21python
    15 Posts 7 Posters 6.5k Views 5 Watching
    • B Offline
      bentraje
      @zipit
      Thanks for the response! Yea, I guess there is no way around it unless its officially supported.
      Just got off on a Maya job and discovered PySide2 and it was joy to work with. I can use the QtDesigner to build the layout and just focus more on the backend tasks.
        @zipit said everything ๐Ÿ™‚
        I'm agree with you, creating UI is time consuming and we know that any tool to help in that direction would be really appreciate.
        • B Offline
          bentraje
          @m_magalhaes
          Thanks for the response. Here's hoping that PySide2 gets supported on later version.
          • I Offline
            iluxa7k
            Hello
            Trolltech officially does not support pyside2 for py27 Win.
            raw test of
            • P Offline
              ph1lh00k @iluxa7k
              Hi @iluxa7k
              I see you managed to get PySide2 working in C4D... I'm struggling to get it working - could you provide a little info on how you managed it?
              Phil
              I 1 Reply Last reply Reply Quote 0
                Hi @ph1lh00k,
                what is your approach to installing it? Are you using pip and on which OS are you? pip is still not delivered with Cinema's Python, but now supported in R23 (but for macOS it is broken at the moment). To install it, you have to first download get-pip.py and then run it with c4dpy and the command line (make sure to have admin rights in the app):
                cd c:\program files\maxon\R23 # or where ever your cinema r23 is sitting
                c:\Program Files\Maxon\R23>c4dpy %USERPROFILE%\Desktop\get-pip.py # assuming you saved get-pip to your desktop
                then you can install via pip pySide, which gave me the following output.
                c:\Program Files\Maxon\R23>c4dpy -m pip install `PySide2`
                T
                Collecting PySide2
                  Downloading PySide2-5.15.2-5.15.2-cp35.cp36.cp37.cp38.cp39-none-win_amd64.whl (136.3 MB)
                     |รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^| 136.3 MB 6.4 MB/s
                Collecting shiboken2==5.15.2
                  Downloading shiboken2-5.15.2-5.15.2-cp35.cp36.cp37.cp38.cp39-none-win_amd64.whl (2.3 MB)
                     |รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^รข-^| 2.3 MB 6.4 MB/s
                Installing collected packages: shiboken2, PySide2
                  WARNING: The scripts pyside2-designer.exe, pyside2-lupdate.exe, pyside2-rcc.exe and pyside2-uic.exe are installed in 'c:\Program Files\Maxon\R23\resource\modules\python\libs\python37.win64.framework\Scripts' which is not on PATH.
                  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                Successfully installed PySide2-5.15.2 shiboken2-5.15.2
                Which is somewhat what I expected to happen, due to c4dpy not being on PATH and also deviating from the python.exe signature. You can try to duct-tape this into place, but PySide2 is not supported by us, so you are unfortunately on your own here.
                  Just to add some extra information, but PySide being a Qt port, this is not 100% supported by Cinema 4D (while you can make it working) Qt may interfere with the usual Cinema 4D interface and you will need to find Cinema 4D specifics workaround for doing usual Qt things.
                  So I just warn you Qt is not officially supported by Cinema 4D.
                  • P Offline
                    ph1lh00k
                    Thanks @ferdinand @m_adam ,
                    I was hoping it would be straight forward as I have an existing tool built in PySide2 that I need to port to C4D... Guess I'll just have to build from scratch using the c4d GUI module. ={
                    Phil
                    • I Offline
                      iluxa7k @ph1lh00k
                      @ph1lh00k said in PySide2 for Python 2.7 Windows Version?:
                      Hi @iluxa7k
                      Phil
                      Hello Phil
                      Currently i stopped using of cinema4d, switch to flexible Blender. Remove any data for c4d content.
                      For that case, i implemented injection-methods code from several topics at autodesk's beta forum for 3dsmax. That's all
                      • U Offline
                        UnderArmor6555 @bentraje
                        @iluxa7k
                        Hey @iluxa7k ,
                        You mind giving us more info on how you achieved PySide2 within C4D R22 and under? I've tried, many methods, but I keep getting "DLL load failed". At this point, I'm hoping to pay someone to figure this out for us.
                          Hello @bentraje,
                          without any further questions, we will consider this posting as solved by Wednesday and flag it accordingly.
                          • B Offline
                            bentraje
                            Hi @ferdinand
                            Sorry for the late response. Sure sure. Let's close this thread.
                              Hello @bentraje,
                              no need to be sorry and thanks for closing it ๐Ÿ™‚
