    Change parameter's unit type
    5 Posts 3 Posters 892 Views 1 Watching
    • bacaB Offline
      baca
      Hi everyone,
      Trying to create a functionality, when parameter's unit would be changed based on selected mode - either real unit, either percentage.
      I'm pretty sure it has to be handled within the GetDDescription method, but I can't find related example or doc.
      Here's what I need, I have integer parameter TESTPLUGIN_MODE, which might be one of the TESTPLUGIN_DISTANCE or TESTPLUGIN_PERCENTAGE values.
      And I have float offset parameter TESTPLUGIN_OFFSET
      So if TESTPLUGIN_MODE equals to TESTPLUGIN_DISTANCE, then TESTPLUGIN_OFFSET unit should be METER
      else unit should be PERCENT;
      Below is my res file "testplugin.res":
      CONTAINER Otestplugin {
          NAME Otestplugin;
          INCLUDE Obase;
          GROUP ID_OBJECTPROPERTIES {
              DEFAULT 1;
              GROUP {
                  LONG TESTPLUGIN_MODE {
                      CYCLE {
                          TESTPLUGIN_DISTANCE;
                          TESTPLUGIN_PERCENTAGE;
                      DEFAULT TESTPLUGIN_DISTANCE;
                  REAL TESTPLUGIN_OFFSET {
                      CUSTOMGUI LONGSLIDER;
                      MINSLIDER -1000; MAXSLIDER 1000;
                      DEFAULT 0;
      And Otestplugin.pyp part (actually nothing):
        def GetDDescription(self, node, description, flags):
          if not description.LoadDescription(node.GetType()): return False
          data = node.GetDataInstance()
          return (True, flags | c4d.DESCFLAGS_DESC_LOADED)
      • P Offline
        PluginStudent
        Parameter units are defined with the c4d.DESC_UNITproperty. See Description Settings Manual.
        To change the properties of an existing parameter, one would have to translate this code to Python: Description Manual.
        bacaB 1 Reply Last reply Reply Quote 2
          in case you struggle, here is an example for Python, which hides stuff based on based on some booleans. There is also a Python specific resource for that what @PluginStudent already linked you. You can find it here.
          zipit
              """Show and hide parameters based on the sampling type.
              Args:
                  node (c4d.GeListNode): An instance of a TopologyMap tag.
                  description (c4d.Description): The description of the tag.
                  flags (int): The flags for the description operation.
              Returns:
                  bool or tuple(bool, int): Success of the description modification.
              if (not description or not node or
                      not description.LoadDescription(node.GetType())):
                  return False
              # Here I am polling the passed description for a specific attribute.
              bc = description.GetParameterI(c4d.DescID(
                  c4d.DescLevel(c4d.IDC_CURVATURE_FOLD)))
              if bc:
                  # Here I am just polling the node, i.e. the tag in this case, for
                  # an attribute based on which we want to do something.
                  state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_CURVATURE
                  # And here I modify the description, see c4d.Description for details.
                  bc.SetBool(c4d.DESC_HIDE, state)
              # And the rest is just the same stuff, but for other attributes.
              # Orientation
                  c4d.DescLevel(c4d.IDC_ORIENTATION_OPTIONS)))
              if bc:
                  state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_ORIENTATION
              # Thickness
                  c4d.DescLevel(c4d.IDC_THICKNESS_SAMPLES)))
              if bc:
                  state = node[c4d.IDC_SAMPLING_TYPE] != c4d.IDV_TYPE_THICKNESS
          • bacaB Offline
            baca @PluginStudent
            @PluginStudent thanks
            • bacaB Offline
              baca @ferdinand
              @zipit thanks a lot, but based on c++ docs made this (seems there are just more checking):
                def GetDDescription(self, node, description, flags) :
                  if data is None or not description.LoadDescription(node.GetType()): return False
                  singleID = description.GetSingleDescID()
                  paramID = c4d.DescID(c4d.DescLevel(c4d.TESTPLUGIN_OFFSET))
                  if ( singleID is None or paramID.IsPartOf(singleID)[0] ):
                    bc = description.GetParameterI(paramID)
                    if (bc):
                      if data.GetLong(c4d.TESTPLUGIN_MODE) == TESTPLUGIN_MODE_DISTANCE: bc.SetLong(c4d.DESC_UNIT, c4d.DESC_UNIT_METER)
                      else: bc.SetLong(c4d.DESC_UNIT, c4d.DESC_UNIT_PERCENT)
