    DrawHUDText returns a white box instead of a text?
    r20python
    19 Posts 5 Posters 5.3k Views 2 Watching
      hey @bentraje,
      I've update the other thread with all information and files.
      In fact you always need a "minimum" in those files.
      Sorry for not being clear.
      • B Offline
        bentraje
        @m_magalhaes
        Thank you so much for the patience. It loads with no errors. Just one thing, how does it draw in the viewport?
        I guess the name of the tag will appear on the viewport?
        You can see the current state here:
        https://www.dropbox.com/s/pekm2msrut6f2ia/c4d132_HUD_draw_text_d.jpg?dl=0
        Sorry again for the trouble.
          Don't worry 🙂
          the code prevent to work with non polygon object because we need to acces point position information with GetAllPoints
          if not op.IsInstanceOf(c4d.Opolygon):
                      return c4d.DRAWRESULT_OK
          just edit your primitive. (by the way be carefull with the point number, it can be messy xD)
          • B Offline
            bentraje
            @m_magalhaes
            Thanks for the response! It works as expected. You can see the result here:
            https://www.dropbox.com/s/c4iivf56vaqzztk/c4d132_HUD_draw_text_e.jpg?dl=0
            Using the plug-in code you provided, I just replaced the DrawMultiple command to
            bd.DrawHUDText(50, 50, 'HUD Test')
            I see now what you mean by "the viewport is redraw so you have to redraw your text again."
            I tried adding print "Hello World" within the code and it prints every redraw.
            Will consider the thread as solved.
            Thanks again. Have a great day ahead!
              mdr74
              Hi Manuel,
              I've tried to follow your example from the thread you linked but it gives me "Could not initialize global resource for the plugin"
              I thought it was solved, maybe something is changed in R21 or S22?
              thanks
                mdr74
                I started again from scratch and now it works but only in R21.
                In S22 here's no error in the console but nothing shows in the viewport (the object is a polygon).
                  in s22 you have to register the tag with this tag : TAG_IMPLEMENTS_DRAW_FUNCTION
                  info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE | c4d.TAG_IMPLEMENTS_DRAW_FUNCTION ,
                    mdr74
                    it works.
                    thanks
                      mdr74
                      I discovered another problem in S22, maybe.
                      The Hud text is correct but when I deselect the polygon object I cannot select anything in the viewport anymore.
                      I don't know if it's a bug or an error in the plugin
                      thanks again
                        thanks a lot for that, i didn't tested it.
                        I've opened a bug entry for that one. We changed the viewport and lot of stuff.
                        I'll update this thread when the bug will be fixed.
                        • Paul EverettP Offline
                          Paul Everett
                          @m_magalhaes said in DrawHUDText returns a white box instead of a text?:
                          I came across this problem today.
                          #define TAG_IMPLEMENTS_DRAW_FUNCTION (1 << 😎
                          note : you can add this flag to R21 builds, and your tags then display as expected in 22.
                          RE: DrawHUDText
                          z settings have no effect on text.
                          in 21, text is drawn behind poly objects.
                          in 22 text is drawn in front of obejcts.
                          IMO, this is a bit of a mess. the new draw flag should be the exact opposite to what it is, to keep compatibility.
                          small differences, make a big difference when your already bending over backwards trying not to have to rebuild everything yet again, for 22.
                            Regarding the Z setting of DrawHUDText (I'm not sure about which one to be honest since there is no Z param for this method) previously the fact that HUD was behind poly object was a limitation regarding how our draw call was done by the viewport, but this is addressed in S22 and its the expected result that a HUD text is not overridden by any other objects but act as a HUD and to be draw in front of everything.
