    DrawHUDText returns a white box instead of a text?
    r20python
    19 Posts 5 Posters 5.3k Views 2 Watching
    • B Offline
      bentraje
      @m_magalhaes
      Thanks for the response.
      Although I am a bit confused. You mentioned it is not possible in Python but you presented a Python Plug-in?
      This is what I understand so far
      1. You can't use the built-in DrawHUDText or Draw() function in Python. Use C++
      2. However, if you want to draw text in Python you can use DrawMultipleHUDText() instead?
      Can you confirm if this is the case?
      Anyhow, thanks for the tag code example. Sorry but I'm having a problem loading it.
      It presents an error
       File "C:\Program Files\MAXON\Cinema 4D R20\plugins\draw_text.pyp", line 62, in <module>
      icon=None)
      RuntimeError:Could not initialize global resource for the plugin.
      The code is referring to this portion of the code. Sorry I don't really know how to navigate the plug-ins api. Is there some additional procedure I should do for it to work?
          c4d.plugins.RegisterTagPlugin(id=PLUGIN_ID,
                                        str="Tag that draw on viewport",
                                        info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE,
                                        g=TDRAW_EXAMPLE,
                                        description="tdrawexample",
                                        icon=None)
        hiya,
        SceneHookPlugin. It's a type of plugin that you can't be created in python.
        Of course you can use the DrawHUDText in Python but you should use every draw possibilities (text, line, polygons) within a Draw() function that you override in your object (witch can be a tag, a generator, a tool etc..).
        Is it more clear ? Let me know i'll try to reformulate.
        ha, yes, about the error, you have to create a basic res directory with an empty description and string. Those files should be named 'tdrawexample' (.res, .str, .h)
        • B Offline
          bentraje
          @m_magalhaes
          RE: Of course you can use the DrawHUDText in Python but you should use every draw possibilities (text, line, polygons) within a Draw() function that you override in your object (witch can be a tag, a generator, a tool etc..).
          So, does this mean it is not possible with a script. Only a through plug-in. That's why you referred the tag plug-in as a solution right? Sorry. I don't really see a Python documentation for the Draw() function.
          RE: create a basic res directory.
          Thanks for the clarification. I tried making one, but still gives me a could not initialize error
          Here is the current directory is:
          https://www.dropbox.com/s/nd9mwvanmrxabkt/c4d132_HUD_draw_text_b.jpg?dl=0
          Thank you for looking at the problem.
            hello @bentraje
            Sorry i should have linked you to the c++ Draw manual.
            About the directory structure you should have a look at this documentation
            something like so
            • B Offline
              bentraje
              @m_magalhaes
              Thanks for the tree example. It loads successfully.
              But it gives an error of tdrawexample.str
              https://www.dropbox.com/s/rcr1xid9cqml92o/c4d132_HUD_draw_text_c.jpg?dl=0
              My concern is there is really nothing on .str file. Should I put something in there?
                hey @bentraje,
                I've update the other thread with all information and files.
                In fact you always need a "minimum" in those files.
                Sorry for not being clear.
                • B Offline
                  bentraje
                  @m_magalhaes
                  Thank you so much for the patience. It loads with no errors. Just one thing, how does it draw in the viewport?
                  I guess the name of the tag will appear on the viewport?
                  You can see the current state here:
                  https://www.dropbox.com/s/pekm2msrut6f2ia/c4d132_HUD_draw_text_d.jpg?dl=0
                  Sorry again for the trouble.
                    Don't worry 🙂
                    the code prevent to work with non polygon object because we need to acces point position information with GetAllPoints
                    if not op.IsInstanceOf(c4d.Opolygon):
                                return c4d.DRAWRESULT_OK
                    just edit your primitive. (by the way be carefull with the point number, it can be messy xD)
                    • B Offline
                      bentraje
                      @m_magalhaes
                      Thanks for the response! It works as expected. You can see the result here:
                      https://www.dropbox.com/s/c4iivf56vaqzztk/c4d132_HUD_draw_text_e.jpg?dl=0
                      Using the plug-in code you provided, I just replaced the DrawMultiple command to
                      bd.DrawHUDText(50, 50, 'HUD Test')
                      I see now what you mean by "the viewport is redraw so you have to redraw your text again."
                      I tried adding print "Hello World" within the code and it prints every redraw.
                      Will consider the thread as solved.
                      Thanks again. Have a great day ahead!
                        mdr74
                        Hi Manuel,
                        I've tried to follow your example from the thread you linked but it gives me "Could not initialize global resource for the plugin"
                        I thought it was solved, maybe something is changed in R21 or S22?
                        thanks
                          mdr74
                          I started again from scratch and now it works but only in R21.
                          In S22 here's no error in the console but nothing shows in the viewport (the object is a polygon).
                            in s22 you have to register the tag with this tag : TAG_IMPLEMENTS_DRAW_FUNCTION
                            info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE | c4d.TAG_IMPLEMENTS_DRAW_FUNCTION ,
                              mdr74
                              it works.
                              thanks
                                mdr74
                                I discovered another problem in S22, maybe.
                                The Hud text is correct but when I deselect the polygon object I cannot select anything in the viewport anymore.
                                I don't know if it's a bug or an error in the plugin
                                thanks again
                                  thanks a lot for that, i didn't tested it.
                                  I've opened a bug entry for that one. We changed the viewport and lot of stuff.
                                  I'll update this thread when the bug will be fixed.
                                  • Paul EverettP Offline
                                    Paul Everett
                                    @m_magalhaes said in DrawHUDText returns a white box instead of a text?:
                                    I came across this problem today.
                                    #define TAG_IMPLEMENTS_DRAW_FUNCTION (1 << 😎
                                    note : you can add this flag to R21 builds, and your tags then display as expected in 22.
                                    RE: DrawHUDText
                                    z settings have no effect on text.
                                    in 21, text is drawn behind poly objects.
                                    in 22 text is drawn in front of obejcts.
                                    IMO, this is a bit of a mess. the new draw flag should be the exact opposite to what it is, to keep compatibility.
                                    small differences, make a big difference when your already bending over backwards trying not to have to rebuild everything yet again, for 22.
                                      Regarding the Z setting of DrawHUDText (I'm not sure about which one to be honest since there is no Z param for this method) previously the fact that HUD was behind poly object was a limitation regarding how our draw call was done by the viewport, but this is addressed in S22 and its the expected result that a HUD text is not overridden by any other objects but act as a HUD and to be draw in front of everything.
