    DrawHUDText returns a white box instead of a text?
    r20python
    19 Posts 5 Posters 5.2k Views 2 Watching
    • B Offline
      bentraje
      @m_magalhaes
      Thanks for the tree example. It loads successfully.
      But it gives an error of tdrawexample.str
      https://www.dropbox.com/s/rcr1xid9cqml92o/c4d132_HUD_draw_text_c.jpg?dl=0
      My concern is there is really nothing on .str file. Should I put something in there?
        hey @bentraje,
        I've update the other thread with all information and files.
        In fact you always need a "minimum" in those files.
        Sorry for not being clear.
        • B Offline
          bentraje
          @m_magalhaes
          Thank you so much for the patience. It loads with no errors. Just one thing, how does it draw in the viewport?
          I guess the name of the tag will appear on the viewport?
          You can see the current state here:
          https://www.dropbox.com/s/pekm2msrut6f2ia/c4d132_HUD_draw_text_d.jpg?dl=0
          Sorry again for the trouble.
            Don't worry 🙂
            the code prevent to work with non polygon object because we need to acces point position information with GetAllPoints
            if not op.IsInstanceOf(c4d.Opolygon):
                        return c4d.DRAWRESULT_OK
            just edit your primitive. (by the way be carefull with the point number, it can be messy xD)
            • B Offline
              bentraje
              @m_magalhaes
              Thanks for the response! It works as expected. You can see the result here:
              https://www.dropbox.com/s/c4iivf56vaqzztk/c4d132_HUD_draw_text_e.jpg?dl=0
              Using the plug-in code you provided, I just replaced the DrawMultiple command to
              bd.DrawHUDText(50, 50, 'HUD Test')
              I see now what you mean by "the viewport is redraw so you have to redraw your text again."
              I tried adding print "Hello World" within the code and it prints every redraw.
              Will consider the thread as solved.
              Thanks again. Have a great day ahead!
                mdr74
                Hi Manuel,
                I've tried to follow your example from the thread you linked but it gives me "Could not initialize global resource for the plugin"
                I thought it was solved, maybe something is changed in R21 or S22?
                thanks
                  mdr74
                  I started again from scratch and now it works but only in R21.
                  In S22 here's no error in the console but nothing shows in the viewport (the object is a polygon).
                    in s22 you have to register the tag with this tag : TAG_IMPLEMENTS_DRAW_FUNCTION
                    info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE | c4d.TAG_IMPLEMENTS_DRAW_FUNCTION ,
                      mdr74
                      it works.
                      thanks
                        mdr74
                        I discovered another problem in S22, maybe.
                        The Hud text is correct but when I deselect the polygon object I cannot select anything in the viewport anymore.
                        I don't know if it's a bug or an error in the plugin
                        thanks again
                          thanks a lot for that, i didn't tested it.
                          I've opened a bug entry for that one. We changed the viewport and lot of stuff.
                          I'll update this thread when the bug will be fixed.
                          • Paul EverettP Offline
                            Paul Everett
                            @m_magalhaes said in DrawHUDText returns a white box instead of a text?:
                            I came across this problem today.
                            #define TAG_IMPLEMENTS_DRAW_FUNCTION (1 << 😎
                            note : you can add this flag to R21 builds, and your tags then display as expected in 22.
                            RE: DrawHUDText
                            z settings have no effect on text.
                            in 21, text is drawn behind poly objects.
                            in 22 text is drawn in front of obejcts.
                            IMO, this is a bit of a mess. the new draw flag should be the exact opposite to what it is, to keep compatibility.
                            small differences, make a big difference when your already bending over backwards trying not to have to rebuild everything yet again, for 22.
                              Regarding the Z setting of DrawHUDText (I'm not sure about which one to be honest since there is no Z param for this method) previously the fact that HUD was behind poly object was a limitation regarding how our draw call was done by the viewport, but this is addressed in S22 and its the expected result that a HUD text is not overridden by any other objects but act as a HUD and to be draw in front of everything.
