    Modifier parameters change uppon scaling
    r20c++windowsmacos
    3 Posts 2 Posters 917 Views
    • N Offline
      neon
      I noticed that two of my parameters of my modifier change their values when I scale the modifier in the viewport.
      I thought that it might be the Handles, but the only ones I have are from the Falloff/Field.
      I tried changing the ids of those two parameters (both Realslider) but they do still change.
      The only time I set/get the values for the parameters are in the Init function and in the ModifyObject function.
      I am at a complete loss here. Is there anything I could check that I may be doing?
      Thanks in advance!
      Best Regards,
      Florian
      • S Offline
        s_bach
        float parameters using "meter" as a unit are automatically scaled, when the object is scaled.
        You can disable this by setting DESC_FORBID_SCALING or "FORBID_SCALING" in the resource file.
        See Description Settings Manual.
        • N Offline
          neon
          Hello Sebastian,
          thanks for this quick response!
          I dind't know about this. But this solved my issue!
          Best Regards,
          Florian
