    urllib2.urlopen fails on C4D for Mac
    32 Posts 8 Posters 24.1k Views 2 Watching
    • merkvilsonM Offline
      merkvilson
      Edit: Here is a solution by Maxime:
      import urllib2
      import os
      f = os.path.join(os.path.dirname(c4d.storage.GeGetStartupApplication()), "resource", "ssl", "cacert.pem")
      urllib2.urlopen("https://google.com", cafile=f)
      • mikeudinM Offline
        mikeudin
        This is a SSL certificates issue
        https://mikeudin.net
          Hi, @merkvilson thanks for contacting us.
          Unfortunately, this is an already a known issue and it's not fixed yet.
          You may find some workaround by googling the error message, but this indeed introduce some security issue so we can't recommend this as a correct workaround.
            merkvilson
            Does this apply only to Mac devices?
              merkvilson
              Ok. It seems like this problem occurs only on Mac devices.
                Yes the SSL error is only a mac issue
                  merkvilson
                  It seems like there are two ways of solving this problem.
                  • Via PIP: pip install --upgrade certifi
                  • Via Cerificates.command open /Applications/Python\ 3.6/Install\ Certificates.command (Yes. I know C4D works only with python 2.7 😅 )
                  Is it possible to execute these codes directly from python plugin?
                    merkvilson
                    As I remember, there is a pip module which can be imported via import pip command in python code and then install the desired modules but will it work with C4D's python implementation?
                      Hi @merkvilson, I indeed overlooked the issue, since in all topic it's only Python 3.6, I didn't tried.
                      But in MacOs, certifi is not installed (which cause the issue), but you can directly get the certificate file to make it works as expected. Here the code which works on mac and windows.
                      import os
                      import ssl
                      import urllib
                      context = ssl.create_default_context(cafile=f)
                      urllib.urlopen("https://google.com",context=context)
                      Or with urllib2
                      import urllib2
                      import os
                      merkvilsonM 1 Reply Last reply Reply Quote 3
                        merkvilson @m_adam
                        @m_adam
                        Thanks, Maxime! I'll check it as soon as one of the beta testers will be available online to test it out.
                          merkvilson
                          I'm getting this error message on windows pc. I guess this is expected behavior on windows, right?
                          urllib2.HTTPError: HTTP Error 405: METHOD NOT ALLOWED
                            @merkvilson said in C4D's python implementation on Mac and PC:
                            Does it happen on all websites? Or only a specific one? Could you try to open https://google.com
                            Here it's working nicely on windows/mac
                              merkvilson
                              I tried again and it worked perfectly.
                              I'm not sure what caused the previous problem. I probably did something wrong.
                              I'm still testing it on my windows pc, and I'm not getting any errors.
                              I guess this thread will be marked as solved in a few minutes 😂
                                merkvilson
                                Code worked on all of my beta testers' mac and windows devices. 😁 👌
                                Thanks, Maxime!
                                • lasselauchL Offline
                                  lasselauch
                                  Hey everyone,
                                  i am having this problem where I want to download an assets (zipfile) from a private repo on GitHub.
                                  I've started to develop it with requests from there everything worked fine... now I am trying to port it to urllib2 for C4D but it doesn't work anymore...
                                  'Accept': 'application/octet-stream' will always result in: HTTP Error 415: Unsupported Media Type
                                  If I get rid of 'Accept': 'application/octet-stream' it will give me the application/json
                                          headers = {
                                              'Authorization': 'token %s' % (MYTOKEN),
                                              'Accept': 'application/octet-stream',
                                          url = 'https://api.github.com/repos/USER/REPO/releases/ID'
                                          request = urllib2.Request(url, headers=headers)
                                          response = urllib2.urlopen(request)
                                          print response.read()
                                          #GIVES ME:
                                          #urllib2.HTTPError: HTTP Error 415: Unsupported Media Type
                                  Any idea how to avoid the HTTP Error 415 and download the zip to disk?
                                  Really hard to find something about this anywhere...
                                  Any help is appreciated.
                                  Lasse
                                    mp5gosu
                                    Hi Lasse,
                                    you're probably having some issues with authorization.
                                    You're getting a JSON response which may indicate that your requested URL cannot be delivered.
                                    What's the content of the reponse if you print it?
                                    Does it happen with a public repo as well?
                                    Best,
                                    Robert
                                    lasselauchL 1 Reply Last reply Reply Quote 0
                                      lasselauch @mp5gosu
                                      @mp5gosu
                                      Hi Robert!
                                      Haven't tested it with a public repo yet, but I'll bet its going to work ... the print of the response gives me:
                                      which I can't find much info for ...
                                        mp5gosu
                                        By the way, the URL you provided doesn't reflect GitHubs scheme. It is actually https://api.github.com/USER/REPO/releases/ID
                                          lasselauch @mp5gosu
                                          @mp5gosu Yep, the link is coming from the provided JSON data. Also removing the repo from the link gives me the same error!
                                          Is it possible that this has something to do with 'Accept': 'application/octet-stream'? Isn't it possible to stream with urllib2?
                                            mp5gosu
                                            Hey Lasse,
                                            sorry - removing "repos" is actually wrong when using api access, my bad.
                                            I can now also comprehend your problem. I'm going to dig a little deeper. 😉
