    urllib2.urlopen fails on C4D for Mac
    32 Posts 8 Posters 27.5k Views 2 Watching
      Yes the SSL error is only a mac issue
      • merkvilsonM Offline
        merkvilson
        It seems like there are two ways of solving this problem.
        • Via PIP: pip install --upgrade certifi
        • Via Cerificates.command open /Applications/Python\ 3.6/Install\ Certificates.command (Yes. I know C4D works only with python 2.7 😅 )
        Is it possible to execute these codes directly from python plugin?
          merkvilson
          As I remember, there is a pip module which can be imported via import pip command in python code and then install the desired modules but will it work with C4D's python implementation?
            Hi @merkvilson, I indeed overlooked the issue, since in all topic it's only Python 3.6, I didn't tried.
            But in MacOs, certifi is not installed (which cause the issue), but you can directly get the certificate file to make it works as expected. Here the code which works on mac and windows.
            import os
            import ssl
            import urllib
            f = os.path.join(os.path.dirname(c4d.storage.GeGetStartupApplication()), "resource", "ssl", "cacert.pem")
            context = ssl.create_default_context(cafile=f)
            urllib.urlopen("https://google.com",context=context)
            Or with urllib2
            import urllib2
            import os
            urllib2.urlopen("https://google.com", cafile=f)
            merkvilsonM 1 Reply Last reply Reply Quote 3
              merkvilson @m_adam
              @m_adam
              Thanks, Maxime! I'll check it as soon as one of the beta testers will be available online to test it out.
                merkvilson
                I'm getting this error message on windows pc. I guess this is expected behavior on windows, right?
                urllib2.HTTPError: HTTP Error 405: METHOD NOT ALLOWED
                  @merkvilson said in C4D's python implementation on Mac and PC:
                  Does it happen on all websites? Or only a specific one? Could you try to open https://google.com
                  Here it's working nicely on windows/mac
                    merkvilson
                    I tried again and it worked perfectly.
                    I'm not sure what caused the previous problem. I probably did something wrong.
                    I'm still testing it on my windows pc, and I'm not getting any errors.
                    I guess this thread will be marked as solved in a few minutes 😂
                      merkvilson
                      Code worked on all of my beta testers' mac and windows devices. 😁 👌
                      Thanks, Maxime!
                      • lasselauchL Offline
                        lasselauch
                        Hey everyone,
                        i am having this problem where I want to download an assets (zipfile) from a private repo on GitHub.
                        I've started to develop it with requests from there everything worked fine... now I am trying to port it to urllib2 for C4D but it doesn't work anymore...
                        'Accept': 'application/octet-stream' will always result in: HTTP Error 415: Unsupported Media Type
                        If I get rid of 'Accept': 'application/octet-stream' it will give me the application/json
                                headers = {
                                    'Authorization': 'token %s' % (MYTOKEN),
                                    'Accept': 'application/octet-stream',
                                url = 'https://api.github.com/repos/USER/REPO/releases/ID'
                                request = urllib2.Request(url, headers=headers)
                                response = urllib2.urlopen(request)
                                print response.read()
                                #GIVES ME:
                                #urllib2.HTTPError: HTTP Error 415: Unsupported Media Type
                        Any idea how to avoid the HTTP Error 415 and download the zip to disk?
                        Really hard to find something about this anywhere...
                        Any help is appreciated.
                        Lasse
                          mp5gosu
                          Hi Lasse,
                          you're probably having some issues with authorization.
                          You're getting a JSON response which may indicate that your requested URL cannot be delivered.
                          What's the content of the reponse if you print it?
                          Does it happen with a public repo as well?
                          Best,
                          Robert
                          lasselauchL 1 Reply Last reply Reply Quote 0
                            lasselauch @mp5gosu
                            @mp5gosu
                            Hi Robert!
                            Haven't tested it with a public repo yet, but I'll bet its going to work ... the print of the response gives me:
                            which I can't find much info for ...
                              mp5gosu
                              By the way, the URL you provided doesn't reflect GitHubs scheme. It is actually https://api.github.com/USER/REPO/releases/ID
                                lasselauch @mp5gosu
                                @mp5gosu Yep, the link is coming from the provided JSON data. Also removing the repo from the link gives me the same error!
                                Is it possible that this has something to do with 'Accept': 'application/octet-stream'? Isn't it possible to stream with urllib2?
                                  mp5gosu
                                  Hey Lasse,
                                  sorry - removing "repos" is actually wrong when using api access, my bad.
                                  I can now also comprehend your problem. I'm going to dig a little deeper. 😉
                                    mp5gosu
                                    Hey again. Managed to download it when using the zipball or tarball URLs. Weird though, that it responds with 415 when using the asset id directly.
                                      lasselauch @mp5gosu
                                      @mp5gosu interesting... i guess shipping and importing the requests module with the plugin, is too much of a hassle... really hard to find any further informations on this... strange...
                                        mp5gosu
                                        I dare to say that urllib2 is the culprit here. I don't have any problems using other libs or tool in the exact same way. curl works out of the box for example.
                                          lasselauch
                                          yeah, had no luck either... okay, so I'm probably back to importing requests as 3rd party module. 🙂
                                          Thanks for the quick help, Robert!
                                            mp5gosu
                                            Using requests package would be the solution I guess. Even the docs state that they are auperior on high level access.
                                            The web says that urllib2 is broken in so many ways due to its age.
