    urllib2.urlopen fails on C4D for Mac
    32 Posts 8 Posters 27.5k Views 2 Watching
      Hi @merkvilson, I indeed overlooked the issue, since in all topic it's only Python 3.6, I didn't tried.
      But in MacOs, certifi is not installed (which cause the issue), but you can directly get the certificate file to make it works as expected. Here the code which works on mac and windows.
      import os
      import ssl
      import urllib
      f = os.path.join(os.path.dirname(c4d.storage.GeGetStartupApplication()), "resource", "ssl", "cacert.pem")
      context = ssl.create_default_context(cafile=f)
      urllib.urlopen("https://google.com",context=context)
      Or with urllib2
      import urllib2
      import os
      urllib2.urlopen("https://google.com", cafile=f)
      merkvilsonM 1 Reply Last reply Reply Quote 3
      • merkvilsonM Offline
        merkvilson @m_adam
        @m_adam
        Thanks, Maxime! I'll check it as soon as one of the beta testers will be available online to test it out.
          merkvilson
          I'm getting this error message on windows pc. I guess this is expected behavior on windows, right?
          urllib2.HTTPError: HTTP Error 405: METHOD NOT ALLOWED
            @merkvilson said in C4D's python implementation on Mac and PC:
            Does it happen on all websites? Or only a specific one? Could you try to open https://google.com
            Here it's working nicely on windows/mac
              merkvilson
              I tried again and it worked perfectly.
              I'm not sure what caused the previous problem. I probably did something wrong.
              I'm still testing it on my windows pc, and I'm not getting any errors.
              I guess this thread will be marked as solved in a few minutes 😂
                merkvilson
                Code worked on all of my beta testers' mac and windows devices. 😁 👌
                Thanks, Maxime!
                • lasselauchL Offline
                  lasselauch
                  Hey everyone,
                  i am having this problem where I want to download an assets (zipfile) from a private repo on GitHub.
                  I've started to develop it with requests from there everything worked fine... now I am trying to port it to urllib2 for C4D but it doesn't work anymore...
                  'Accept': 'application/octet-stream' will always result in: HTTP Error 415: Unsupported Media Type
                  If I get rid of 'Accept': 'application/octet-stream' it will give me the application/json
                          headers = {
                              'Authorization': 'token %s' % (MYTOKEN),
                              'Accept': 'application/octet-stream',
                          url = 'https://api.github.com/repos/USER/REPO/releases/ID'
                          request = urllib2.Request(url, headers=headers)
                          response = urllib2.urlopen(request)
                          print response.read()
                          #GIVES ME:
                          #urllib2.HTTPError: HTTP Error 415: Unsupported Media Type
                  Any idea how to avoid the HTTP Error 415 and download the zip to disk?
                  Really hard to find something about this anywhere...
                  Any help is appreciated.
                  Lasse
                    mp5gosu
                    Hi Lasse,
                    you're probably having some issues with authorization.
                    You're getting a JSON response which may indicate that your requested URL cannot be delivered.
                    What's the content of the reponse if you print it?
                    Does it happen with a public repo as well?
                    Best,
                    Robert
                    lasselauchL 1 Reply Last reply Reply Quote 0
                      lasselauch @mp5gosu
                      @mp5gosu
                      Hi Robert!
                      Haven't tested it with a public repo yet, but I'll bet its going to work ... the print of the response gives me:
                      which I can't find much info for ...
                        mp5gosu
                        By the way, the URL you provided doesn't reflect GitHubs scheme. It is actually https://api.github.com/USER/REPO/releases/ID
                          lasselauch @mp5gosu
                          @mp5gosu Yep, the link is coming from the provided JSON data. Also removing the repo from the link gives me the same error!
                          Is it possible that this has something to do with 'Accept': 'application/octet-stream'? Isn't it possible to stream with urllib2?
                            mp5gosu
                            Hey Lasse,
                            sorry - removing "repos" is actually wrong when using api access, my bad.
                            I can now also comprehend your problem. I'm going to dig a little deeper. 😉
                              mp5gosu
                              Hey again. Managed to download it when using the zipball or tarball URLs. Weird though, that it responds with 415 when using the asset id directly.
                                lasselauch @mp5gosu
                                @mp5gosu interesting... i guess shipping and importing the requests module with the plugin, is too much of a hassle... really hard to find any further informations on this... strange...
                                  mp5gosu
                                  I dare to say that urllib2 is the culprit here. I don't have any problems using other libs or tool in the exact same way. curl works out of the box for example.
                                    lasselauch
                                    yeah, had no luck either... okay, so I'm probably back to importing requests as 3rd party module. 🙂
                                    Thanks for the quick help, Robert!
                                      mp5gosu
                                      Using requests package would be the solution I guess. Even the docs state that they are auperior on high level access.
                                      The web says that urllib2 is broken in so many ways due to its age.
                                        Hi @lasselauch as @mp5gosu this is a urrlib2 issue and we can't provide support on this topic.
                                        Moreover, if you have more questions (while I think everything is said), please open a new thread since while the overall topic is related, the question and issue are different.
                                        • fwilleke80F Offline
                                          fwilleke80
                                          The issue with the certificates still persists in R21.022 on macOS 10.13.6.
                                          Frank
                                          www.frankwilleke.de
                                            @fwilleke80 thanks for bumping it, I will bump this topic when the issue will be resolved.
                                            For the time being, my workaround provided previously still work.
