    Plugin OnFloor Final 1.2.4RC1
    14 Posts 5 Posters 6.6k Views 4 Watching
    • S Offline
      s_bach
      thank you for sharing your work!
      • Passion3DP Offline
        Passion3D
        Thank you Sebastian 😉
        And thanks to those who helped me on this forum, and who allowed me to finalize this plugin 🙂
        I would probably have a lot more questions, because I started a plugin for the creation of a road network (a little like House Builder)
          Passion3D
          This post is deleted!
            Passion3D
            Thanks to all the testers,
            this plugin is therefore Cinema4D compatible:
            R14, R15, R16, R17, R18, R19, R20
            There is also a version compatible with R13
            Enjoy 😉
            • mikeudinM Offline
              mikeudin
              How to use this tool with objects grouped in a single null?
              Not working with Figure primitive 🤔 :
              Traceback (most recent call last):
                File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 108, in MouseInput
                File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 47, in CenterAxe
                    File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 24, in MoveAxe
                  ValueError: Invalid object length.
              Just in case. Using my Target4D plugin you can drop your object to any surface 🙃
              alt text
              https://mikeudin.net
                Passion3D
                Thanks for report @mikeudin
                Bug fixed, links updated
                  Passion3D
                  Plugin updated.
                  minor bugfix
                    Passion3D
                    Update 1.1.0
                      Passion3D
                      Hi all
                      Update 1.2.3b
                      Only one version for C4D R13 to R20 😉
                      The above-ground level can be specified in a different unit of measurement from that configured in the C4D preferences.
                      Parametric, Polygonal, Nurbs, Generator (array, atomarray etc...) objects can be moved.
                      I'm debugging for Null and Spline;)
                        Passion3D
                        Final version 1.2.4RC1.
                        • a_blockA Offline
                          a_block
                          @Kargall expressed his gratitude in this thread.
                            Passion3D
                            Thanks Andreas 😉
                            • J Offline
                              JP71
                              Grand merci pour ce Plugin tellement simple et facile d'utilisation. Grand merci...
                              Many thanks for this Plugin so simple and easy to use. Big thanks
