    Plugin OnFloor Final 1.2.4RC1
    14 Posts 5 Posters 6.4k Views 4 Watching
    • Passion3DP Offline
      Passion3D
      This post is deleted!
        Passion3D
        Thanks to all the testers,
        this plugin is therefore Cinema4D compatible:
        R14, R15, R16, R17, R18, R19, R20
        There is also a version compatible with R13
        Enjoy 😉
        • mikeudinM Offline
          mikeudin
          How to use this tool with objects grouped in a single null?
          Not working with Figure primitive 🤔 :
          Traceback (most recent call last):
            File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 108, in MouseInput
            File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 47, in CenterAxe
                File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 24, in MoveAxe
              ValueError: Invalid object length.
          Just in case. Using my Target4D plugin you can drop your object to any surface 🙃
          alt text
          https://mikeudin.net
            Passion3D
            Thanks for report @mikeudin
            Bug fixed, links updated
              Passion3D
              Plugin updated.
              minor bugfix
                Passion3D
                Update 1.1.0
                  Passion3D
                  Hi all
                  Update 1.2.3b
                  Only one version for C4D R13 to R20 😉
                  The above-ground level can be specified in a different unit of measurement from that configured in the C4D preferences.
                  Parametric, Polygonal, Nurbs, Generator (array, atomarray etc...) objects can be moved.
                  I'm debugging for Null and Spline;)
                    Passion3D
                    Final version 1.2.4RC1.
                    • a_blockA Offline
                      a_block
                      @Kargall expressed his gratitude in this thread.
                        Passion3D
                        Thanks Andreas 😉
                        • J Offline
                          JP71
                          Grand merci pour ce Plugin tellement simple et facile d'utilisation. Grand merci...
                          Many thanks for this Plugin so simple and easy to use. Big thanks
