    Plugin OnFloor Final 1.2.4RC1
    14 Posts 5 Posters 5.9k Views 4 Watching
    • Passion3DP Offline
      Passion3D
      Hello
      This plugin is a tool that allows you to place one or more objects on the floor.
      The use is very simple:
      Select the tool, then click on each object you want to put on the floor.
      You can specify the level (and Unit) at which you want to place the object
      Parametric, Polygonal, Null object, Nurbs, Generator, MoTexte, Cloner, Spline objects can be moved
      If this tool is useful for you, or if you find a bug 😉 Let me know.
      For Cinema4D R13, R14, R15, R16, R17, R18, R19, R20:
      OnFloor
      1 Reply Last reply Reply Quote 4
      • S Offline
        s_bach
        thank you for sharing your work!
          Passion3D
          Thank you Sebastian 😉
          And thanks to those who helped me on this forum, and who allowed me to finalize this plugin 🙂
          I would probably have a lot more questions, because I started a plugin for the creation of a road network (a little like House Builder)
            Passion3D
            This post is deleted!
              Passion3D
              Thanks to all the testers,
              this plugin is therefore Cinema4D compatible:
              There is also a version compatible with R13
              Enjoy 😉
              • mikeudinM Offline
                mikeudin
                How to use this tool with objects grouped in a single null?
                Not working with Figure primitive 🤔 :
                Traceback (most recent call last):
                  File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 108, in MouseInput
                  File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 47, in CenterAxe
                      File "C:\Users\user\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\plugins\OnFloor_1.0.0\OnFloor\OnFloor.pypv", line 24, in MoveAxe
                    ValueError: Invalid object length.
                Just in case. Using my Target4D plugin you can drop your object to any surface 🙃
                alt text
                https://mikeudin.net
                  Passion3D
                  Thanks for report @mikeudin
                  Bug fixed, links updated
                    Passion3D
                    Plugin updated.
                    minor bugfix
                      Passion3D
                      Update 1.1.0
                        Passion3D
                        Hi all
                        Update 1.2.3b
                        Only one version for C4D R13 to R20 😉
                        The above-ground level can be specified in a different unit of measurement from that configured in the C4D preferences.
                        Parametric, Polygonal, Nurbs, Generator (array, atomarray etc...) objects can be moved.
                        I'm debugging for Null and Spline;)
                          Passion3D
                          Final version 1.2.4RC1.
                          • a_blockA Offline
                            a_block
                            @Kargall expressed his gratitude in this thread.
                              Passion3D
                              Thanks Andreas 😉
                              • J Offline
                                JP71
                                Grand merci pour ce Plugin tellement simple et facile d'utilisation. Grand merci...
                                Many thanks for this Plugin so simple and easy to use. Big thanks
