    [SOLVED]Start Drag from GeUserArea
    19 Posts 0 Posters 4.5k Views
      On 08/06/2017 at 09:38, xxxxxxxx wrote:
      Thanks you. Tested and solved ! 🙂
        On 09/06/2017 at 00:54, xxxxxxxx wrote:
        Sorry to bump this thread but is there a way for start drag from a GeUserArea and recieve drop message from TreeViewCustomGui? Or at least is it possible to send message to this TreeViewCustomGui? Or a timer?
        Just tell me yes or no 😉
        Cause I think I must do the following thing but I prefer ask if there is no other way before ^^
        Make my timer function into my GeDialog who call a custom timer function inside my TreeView 🙂
          On 09/06/2017 at 02:29, xxxxxxxx wrote:
          GeUserArea.HandleMouseDrag() is missing in the Python API so it would be really difficult and hacky to send drag and drop data to other gadgets.
            On 09/06/2017 at 02:46, xxxxxxxx wrote:
            Ok thanks for confirming ! 🙂
              On 09/06/2017 at 13:53, xxxxxxxx wrote:
              Sorry again to bump this thread, but I don't udnerstand the output code while the mouse is not moving, delta y is always -22 while it should be 0
                  def InputEvent(self, msg) :
                      mousex = msg[c4d.BFM_INPUT_X]
                      mousey = msg[c4d.BFM_INPUT_Y]
                      self.MouseDragStart(c4d.KEY_MLEFT, mousex, mousey, c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE | c4d.MOUSEDRAGFLAGS_NOMOVE)
                      start_x = mousex
                      start_y = mousey
                      mx = mousex
                      my = mousey
                      state = c4d.BaseContainer()
                      while True:
                          result, dx, dy, channels = self.MouseDrag()
                          if result == c4d.MOUSEDRAGRESULT_ESCAPE:
                              break
                          if not self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, state) :
                              break
                          if state[c4d.BFM_INPUT_VALUE] == 0:
                              print "Released Left Mouse"
                              break
                          if dx == 0 and dy == 0: #dy != 0 while not moving
                              continue
                          mx += dx
                          my += dy
                         #Should not be display if not moving
                         print 'drag'
                      print start_x - mx
                      print start_y - my #-22 if not moving
                On 12/06/2017 at 07:06, xxxxxxxx wrote:
                Sorry again to bump this thread, but I don't understand the output code while the mouse is not moving, delta y is always -22 while it should be 0
                If the mouse doesn't move dx and dy are 0. The final mouse delta X and Y values depends on how you calculate the current mouse position.
                It's better to subtract the mouse drag delta values:
                mx -= dx
                my -= dy
                Then the final delta value can be calculated:
                print mx - mousex
                print my - mousey
                If you don't want MouseDrag() to return when the mouse doesn't move, don't pass MOUSEDRAGFLAGS_NOMOVE to MouseDragStart().
                  On 13/06/2017 at 04:52, xxxxxxxx wrote:
                  Ok I get why it's wrong... The corect loop initialization is:
                          while self.MouseDrag()[0] == c4d.MOUSEDRAGRESULT_CONTINUE:
                              if msg[c4d.BFM_INPUT_VALUE] == 0:
                                  break
                              print "dx {} - dy {}".format(dx, dy)
                  While in the documention of https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/EditorWindow/index.html#EditorWindow.MouseDragStart the main drag loop is done with While true, which give you a wrong value for dx/dy for the first packet of the drag input.
                  So doing it like in the C++ exemple
                      win->MouseDragStart(button, mouseX, mouseY, MOUSEDRAGFLAGS_DONTHIDEMOUSE | MOUSEDRAGFLAGS_NOMOVE);
                      while (win->MouseDrag(&dx, &dy, &device) == MOUSEDRAGRESULT_CONTINUE)
                  give us in python
                  Anyway thanks for your support ! 🙂
                    On 13/06/2017 at 08:18, xxxxxxxx wrote:
                    I can't confirm that because the delta values returned from the call to MouseDrag()[0] aren't processed for each while loop:
                    while self.MouseDrag()[0] == c4d.MOUSEDRAGRESULT_CONTINUE: # dx, dy and channels not retrieved and processed
                    There should be only one MouseDrag() call for each while loop.
                      On 13/06/2017 at 08:28, xxxxxxxx wrote:
                      Juste copy paste thoses two codes and do a normal click without dragging. Just a simple click (no move, nothing just a click), So result should be 0 and 0 for dx/dy in all case (in all packet of the drag pool)
                      The first one give correct result for dx , dy
                      class Area(c4d.gui.GeUserArea) :
                              while self.MouseDrag()[0]:
                                      break
                                  if result!=c4d.MOUSEDRAGRESULT_CONTINUE: break
                      class MyDialog(c4d.gui.GeDialog) :
                          def CreateLayout(self) :
                              self.area = Area()
                              self.AddUserArea(1000, c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT)
                              self.AttachUserArea(self.area, 1000)
                          dialog = MyDialog()
                          dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=500, defaulth=500)
                      While the sdk code(using While True) give wrong result for dx, dy in the first packet (dx 4 and dy 4)
                              while True:
                                      break
                              self.area = Area()
                          dialog = MyDialog()
                        On 14/06/2017 at 03:17, xxxxxxxx wrote:
                        You're not retrieving and printing the delta values dx and dy from the self.MouseDrag()[0] calls in the first script. The delta values are 4.0 for the first mouse drag there too.
                        The limitation with MouseDrag() in Python is the language doesn't support assignments in expressions.
