    [SOLVED]Start Drag from GeUserArea
    19 Posts 0 Posters 4.3k Views
      On 07/06/2017 at 13:57, xxxxxxxx wrote:
      I don't success to get it to work properly. The main issue is I don't know when to start drag event. Same for end it. So for exemple it didn't make the difference beetween a simple click and a drag event.
      Moreover kills event doesn't seem to work.
      Here is an exemple
      class Area(c4d.gui.GeUserArea) :
          xValue = 0
          yValue = 0
          def DrawMsg(self, x1, y1, x2, y2, msg) :
              self.DrawSetPen(c4d.Vector(.2))
          def drag_message(self, msg, result) :
              bc_click = c4d.BaseContainer()
              self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc_click)
              mousex = bc_click.GetLong(c4d.BFM_INPUT_X)
              mousey = bc_click.GetLong(c4d.BFM_INPUT_X)
              self.MouseDragStart(c4d.KEY_MLEFT, mousex, mousey, c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE | c4d.MOUSEDRAGFLAGS_NOMOVE)
              mx = mousex
              my = mousey
              drag_result, dx, dy, channels = self.MouseDrag()
              first = True
              drag = False
              while drag_result == c4d.MOUSEDRAGRESULT_CONTINUE:
                  drag = True
                  if first:
                      print 'Start'
                      first = False
                  mx += dx
                  my += dy
                  if dx==0.0 and dy==0.0:
                      continue
                  self.KillEvents() #Don't work
                  drag_result, dx, dy, channel = self.MouseDrag()
                  print "Mouse Dragging at position [%f,%f]" % (mx, my)
              if self.MouseDragEnd() == c4d.MOUSEDRAGRESULT_FINISHED and drag:
                  print "Mouse Dragging Ended: ", self.MouseDragEnd()
          def Message(self, msg, result) :
              self.drag_message(msg, result)
              if msg.GetId() == c4d.BFM_INPUT:
                  print 'clicked'
              return c4d.gui.GeUserArea.Message(self, msg, result)
      class MyDialog(c4d.gui.GeDialog) :
          def __init__(self, area) :
              self.area = area
          def CreateLayout(self) :
              self.SetTitle("My UserArea")
              self.AddUserArea(1000, c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT)
              self.AttachUserArea(self.area, 1000)
              self.GroupEnd()
          area = Area()
          dialog = None
          dialog = MyDialog(area)
          dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=500, defaulth=500)
      As you could see if you click its also print you drag. Hope you understand my problem ^^'. Who is Get the start of a drag event and get the end of a drag event. Like that in the Message function I can do if START_OF_DRAG : self.drag_message, and if END_OF_DRAG : print 'end'
        On 08/06/2017 at 03:25, xxxxxxxx wrote:
        To check for a drag event the solution is to simply use MouseDragStart()/MouseDrag()/MouseDragEnd().
        Instead of Message(), move the mouse dragging into InputEvent().
        Then to check if the started drag processing was just a click add this condition at the beginning of the while dragging loop:
        if bc_click[c4d.BFM_INPUT_VALUE] == 0:
            break
        This condition exits the loop whenever the mouse left button is released. Then check if the mouse was really moved or if it was just a mouse click.
        Finally, I don't think KillEvents() is useful here if it's called inside the while dragging loop.
          On 08/06/2017 at 04:40, xxxxxxxx wrote:
          Thanks you sadly I didnt succes to get the click evaluated properly.
              def InputEvent(self, msg) :
                  mousex = msg[c4d.BFM_INPUT_X]
                  mousey = msg[c4d.BFM_INPUT_Y]
                  mx = mousex
                  my = mousey
                  while True:
                      if msg[c4d.BFM_INPUT_VALUE] == 0:
                          break
                      if result!=c4d.MOUSEDRAGRESULT_CONTINUE: break
                      #If we don't move that mean we clicked'
                      if not dx or not dy:
                          print 'clicked'
                          mx += dx
                          my += dy
                  end_state = self.MouseDragEnd()
                  if end_state == c4d.MOUSEDRAGRESULT_ESCAPE:
                      print "Escaped"
                  elif end_state == c4d.MOUSEDRAGRESULT_FINISHED:
                      print 'Mouse Drag End'
                  self.area = Area()
              dialog = MyDialog()
          As you could see, the first tick is always drag (dx and dy are not equal to 0) even if you don't move the mouse.
          Moreover I would like to ask is there a way for changing mouse icon? For exemple I would like to change it when she is outside of my GeUserArea.
            On 08/06/2017 at 08:14, xxxxxxxx wrote:
            Sorry my first post was missing information.
            MouseDrag() has to be called first in the loop for each drag event. Then the current input state for the mouse left button has to be retrieved before checking c4d.BFM_INPUT_VALUE.
            So the dragging loop would be:
            mx = mousex
            my = mousey
            state = c4d.BaseContainer()
            while True:
                if result == c4d.MOUSEDRAGRESULT_ESCAPE:
                  break
                if not self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, state) :
                    break
                if state[c4d.BFM_INPUT_VALUE] == 0:
                    print "Released Left Mouse"
                    break
                if dx == 0 and dy == 0:
                    continue
                mx += dx
                my += dy
            state[c4d.BFM_INPUT_VALUE] gives the mouse left button clicked state. So this allows to check when the mouse button has been released.
            If the mouse position hasn't changed then no dragging should be processed.
            You can change the mouse icon with gui.SetMousePointer().
              On 08/06/2017 at 09:38, xxxxxxxx wrote:
              Thanks you. Tested and solved ! 🙂
                On 09/06/2017 at 00:54, xxxxxxxx wrote:
                Sorry to bump this thread but is there a way for start drag from a GeUserArea and recieve drop message from TreeViewCustomGui? Or at least is it possible to send message to this TreeViewCustomGui? Or a timer?
                Just tell me yes or no 😉
                Cause I think I must do the following thing but I prefer ask if there is no other way before ^^
                Make my timer function into my GeDialog who call a custom timer function inside my TreeView 🙂
                  On 09/06/2017 at 02:29, xxxxxxxx wrote:
                  GeUserArea.HandleMouseDrag() is missing in the Python API so it would be really difficult and hacky to send drag and drop data to other gadgets.
                    On 09/06/2017 at 02:46, xxxxxxxx wrote:
                    Ok thanks for confirming ! 🙂
                      On 09/06/2017 at 13:53, xxxxxxxx wrote:
                      Sorry again to bump this thread, but I don't udnerstand the output code while the mouse is not moving, delta y is always -22 while it should be 0
                              start_x = mousex
                              start_y = mousey
                              mx = mousex
                              my = mousey
                              while True:
                                      break
                                      break
                                      break
                                  if dx == 0 and dy == 0: #dy != 0 while not moving
                                      continue
                                  mx += dx
                                  my += dy
                                 #Should not be display if not moving
                                 print 'drag'
                              print start_x - mx
                              print start_y - my #-22 if not moving
                        On 12/06/2017 at 07:06, xxxxxxxx wrote:
                        Sorry again to bump this thread, but I don't understand the output code while the mouse is not moving, delta y is always -22 while it should be 0
                        If the mouse doesn't move dx and dy are 0. The final mouse delta X and Y values depends on how you calculate the current mouse position.
                        It's better to subtract the mouse drag delta values:
                        mx -= dx
                        my -= dy
                        Then the final delta value can be calculated:
                        print mx - mousex
                        print my - mousey
                        If you don't want MouseDrag() to return when the mouse doesn't move, don't pass MOUSEDRAGFLAGS_NOMOVE to MouseDragStart().
                          On 13/06/2017 at 04:52, xxxxxxxx wrote:
                          Ok I get why it's wrong... The corect loop initialization is:
                                  while self.MouseDrag()[0] == c4d.MOUSEDRAGRESULT_CONTINUE:
                                          break
                                      print "dx {} - dy {}".format(dx, dy)
                          While in the documention of https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/EditorWindow/index.html#EditorWindow.MouseDragStart the main drag loop is done with While true, which give you a wrong value for dx/dy for the first packet of the drag input.
                          So doing it like in the C++ exemple
                              win->MouseDragStart(button, mouseX, mouseY, MOUSEDRAGFLAGS_DONTHIDEMOUSE | MOUSEDRAGFLAGS_NOMOVE);
                              while (win->MouseDrag(&dx, &dy, &device) == MOUSEDRAGRESULT_CONTINUE)
                          give us in python
                          Anyway thanks for your support ! 🙂
                            On 13/06/2017 at 08:18, xxxxxxxx wrote:
                            I can't confirm that because the delta values returned from the call to MouseDrag()[0] aren't processed for each while loop:
                            while self.MouseDrag()[0] == c4d.MOUSEDRAGRESULT_CONTINUE: # dx, dy and channels not retrieved and processed
                            There should be only one MouseDrag() call for each while loop.
                              On 13/06/2017 at 08:28, xxxxxxxx wrote:
                              Juste copy paste thoses two codes and do a normal click without dragging. Just a simple click (no move, nothing just a click), So result should be 0 and 0 for dx/dy in all case (in all packet of the drag pool)
                              The first one give correct result for dx , dy
                                      while self.MouseDrag()[0]:
                                              break
                                      self.area = Area()
                                  dialog = MyDialog()
                              While the sdk code(using While True) give wrong result for dx, dy in the first packet (dx 4 and dy 4)
                                      while True:
                                              break
                                      self.area = Area()
                                  dialog = MyDialog()
                                On 14/06/2017 at 03:17, xxxxxxxx wrote:
                                You're not retrieving and printing the delta values dx and dy from the self.MouseDrag()[0] calls in the first script. The delta values are 4.0 for the first mouse drag there too.
                                The limitation with MouseDrag() in Python is the language doesn't support assignments in expressions.
