    GeUserArea keyboard focus
    14 Posts 0 Posters 1.5k Views
      On 24/08/2015 at 02:27, xxxxxxxx wrote:
      here is what I do:
      static Bool InvokeCommandCall(GeDialog* dialog, Int32 id) {
          BaseContainer actionmsg(BFM_ACTION), actionresult;
          actionmsg.SetInt32(BFM_ACTION_ID, id);
          return dialog->Message(actionmsg, actionresult);
      in iCustomGui subclass:
          virtual Bool Command(Int32 id, const BaseContainer& msg) {
              if (id == COMMANDMSG_VALUECHANGED) {
                  SendValueChanged(this, msg);
      static Bool SendValueChanged(iCustomGui* dlg, BaseContainer msg) {
          msg.SetInt32(BFM_ACTION_ID, dlg->GetId());
          msg.RemoveData(BFM_ACTION_VALUE);
          msg.SetData(BFM_ACTION_VALUE, dlg->GetData().GetValue());
          //GePrint("just msg " + String::IntToString((static_cast<iSnodeDataType*> (msg.GetData(BFM_ACTION_VALUE).GetCustomDataType(SEVENPHOTONS_NODE_CUSTOMDATATYPE)))->count));
      	return dlg->SendParentMessage(msg);
      which is simply updating my CustomDataType members, so if user interacts with GeUserArea,  InvokeCommandCall()  is the update function.
      if I remove  InvokeCommandCall()  , there is a delay, but it works without a problem, what should I do?
        On 24/08/2015 at 09:13, xxxxxxxx wrote:
        why are you sending a message in InvokeCommandCall() and then again with SendParentMessage()? Typically one uses SendParentMessage() to inform the parent dialog that something changed.  See the example on GitHub.
          On 24/08/2015 at 10:39, xxxxxxxx wrote:
          I see, but the problem remains "I removed all calls to SendParentMessage(), all calls now are InvokeCommandCall()"
            On 25/08/2015 at 00:07, xxxxxxxx wrote:
            actually I would have suggested to remove that InvokeCommandCall() stuff and just send the SendParentMessage() to react accordingly when you catch that message.
              On 25/08/2015 at 04:18, xxxxxxxx wrote:
              I will try, will reply soon with an update if it worked or not, thanks Sebastian.
                On 28/12/2015 at 18:39, xxxxxxxx wrote:
                Hi Sebastian,
                I know that was a little old, but I reworked the code and did many tests to see where the problem is.
                now what I can confirm: (attached a piece of the code..)
                Bool SNodeUserArea::InputEvent(const BaseContainer& msg)
                	Int32 dev = msg.GetInt32(BFM_INPUT_DEVICE);
                	Int32 chn = msg.GetInt32(BFM_INPUT_CHANNEL);
                	GePrint("any event!!");
                	if (dev == BFM_INPUT_KEYBOARD)
                		GePrint("any key is pressed");
                		if(chn == KEY_DELETE)
                			if (!selection)
                				return true;
                			BaseContainer actionk(BFM_ACTION);
                			actionk.SetInt32(BFM_ACTION_ID, GetId());
                			actionk.SetInt32(BFM_ACTION_VALUE, 0);
                			actionk.SetInt32(BFM_ACTION_UPDATE, true);
                			removeSelectedNodes();
                			removeSelectedWires();
                			//InvokeCommandCall(GetDialog(), COMMANDMSG_VALUECHANGED, actionk);
                			SendParentMessage(actionk);
                			return true;
                the problem is:
                after a mouse click "for example selecting a node in my userarea" , this changes the data of my CustomDataType, once this is done, the focus is gone!
                so next keyboard hit is missing "the whole InputEvent() is not called at all!" , so I have to click again.
                I also tested it with your example, your example works fine!, the only difference that I see is: in many cases I may send multiple parent messages... "is this a problem?"
                though I hacked around it, not sure if this is fine or not "you may tell " , I set:
                action.SetInt32(BFM_ACTION_UPDATE, true);
                this forced it to work! , so if this is fine you can consider this solved or suggest a better alternative
                  On 30/12/2015 at 14:33, xxxxxxxx wrote:
                  ok I found a pitfall!!, action.SetInt32(BFM_ACTION_UPDATE, true); actually updates immediatly BUT ignores the data change update "so the GeUserArea updates, but the internal data doesn't get a refresh "as this user area can be seen in multiple object managers, I see it only updating in 1 location when  action.SetInt32(BFM_ACTION_UPDATE, true); is active!"
                  on the other hand without this line, it got the keyboard delay focus, ideas?
                    On 31/12/2015 at 04:55, xxxxxxxx wrote:
                    Hi Mohamed,
                    Sorry for my late reply.
                    Sebastian will be back next week and I'm sure he'll be able to give you feedback and ideas for your problem.
                      On 04/01/2016 at 02:07, xxxxxxxx wrote:
                      Hello Mohamed,
                      your last posts are a little bit confusing. Can you post your current code of all relevant classes and functions?
                        On 04/01/2016 at 04:44, xxxxxxxx wrote:
                        Hi Sebastian,
                        I guess the functions are getting delayed due to heavy processing "when the MatPreview is rendering the this problem happens!".
                        so I guess it is a wait for event loop that get ignored due to thread being busy in rendering.
                        but the problem as I posted, and the code is quite complex!! "more than 7k lines../+ I can't strip it ".
                          On 04/01/2016 at 09:10, xxxxxxxx wrote:
                          I do not understand how material preview rendering is related to this thread. Without more specific information I don't think it is possible to give more help.
                            On 05/01/2016 at 05:05, xxxxxxxx wrote:
                            He Sebastian,
                            it is a long story "this GeUserArea is a custom gui for a custom data type inside my MaterialData plugin".
                            but I tested when rendering is off too, it didn't work for unknown reason, I guess I will accept the result anyway.
                            you can consider this solved/closed.
