GeUserArea keyboard focus
On 23/08/2015 at 01:52, xxxxxxxx wrote:
Cinema 4D Version: 15+
Platform: Windows ;
Language(s) : C++ ;---------
I can't get focus properly on keyboard, somehow to get focus I need to do a click first with mouse, then it can read keyboard ONCE!!, I need it to get the keyboard keys anytime "not just once, or by a refreshing mouse click"Bool SNodeUserArea::InputEvent(const BaseContainer& msg) { Int32 dev = msg.GetInt32(BFM_INPUT_DEVICE); Int32 chn = msg.GetInt32(BFM_INPUT_CHANNEL); if (dev == BFM_INPUT_KEYBOARD) { GePrint("key pressed");//prints only if I press mouse before keyboard... if(chn == KEY_DELETE) { BaseContainer actionk(BFM_ACTION); actionk.SetInt32(BFM_ACTION_ID, GetId()); actionk.SetInt32(BFM_ACTION_VALUE, 0); actionk.SetInt32(BFM_ACTION_UPDATE, true); removeSelectedNodes(); removeSelectedWires(); InvokeCommandCall(GetDialog(), COMMANDMSG_VALUECHANGED); SendParentMessage(actionk); return true; } } else if (dev == BFM_INPUT_MOUSE) { ... } return false; }
On 24/08/2015 at 01:59, xxxxxxxx wrote:
what exactly are you doing in InvokeCommandCall() and what consequences does SendParentMessage() have? Do you also loose the focus if you don't call InvokeCommandCall()?
Sebastian -
On 24/08/2015 at 02:27, xxxxxxxx wrote:
here is what I do:
static Bool InvokeCommandCall(GeDialog* dialog, Int32 id) { BaseContainer actionmsg(BFM_ACTION), actionresult; actionmsg.SetInt32(BFM_ACTION_ID, id); return dialog->Message(actionmsg, actionresult); }
in iCustomGui subclass:
virtual Bool Command(Int32 id, const BaseContainer& msg) { if (id == COMMANDMSG_VALUECHANGED) { SendValueChanged(this, msg); } return TRUE; }
static Bool SendValueChanged(iCustomGui* dlg, BaseContainer msg) { msg.SetInt32(BFM_ACTION_ID, dlg->GetId()); msg.RemoveData(BFM_ACTION_VALUE); msg.SetData(BFM_ACTION_VALUE, dlg->GetData().GetValue()); //GePrint("just msg " + String::IntToString((static_cast<iSnodeDataType*> (msg.GetData(BFM_ACTION_VALUE).GetCustomDataType(SEVENPHOTONS_NODE_CUSTOMDATATYPE)))->count)); return dlg->SendParentMessage(msg); }
which is simply updating my CustomDataType members, so if user interacts with GeUserArea, InvokeCommandCall() is the update function.
if I remove InvokeCommandCall() , there is a delay, but it works without a problem, what should I do?
On 24/08/2015 at 09:13, xxxxxxxx wrote:
why are you sending a message in InvokeCommandCall() and then again with SendParentMessage()? Typically one uses SendParentMessage() to inform the parent dialog that something changed. See the example on GitHub.
Sebastian -
On 24/08/2015 at 10:39, xxxxxxxx wrote:
I see, but the problem remains "I removed all calls to SendParentMessage(), all calls now are InvokeCommandCall()"
On 25/08/2015 at 00:07, xxxxxxxx wrote:
actually I would have suggested to remove that InvokeCommandCall() stuff and just send the SendParentMessage() to react accordingly when you catch that message.
Sebastian -
On 25/08/2015 at 04:18, xxxxxxxx wrote:
I will try, will reply soon with an update if it worked or not, thanks Sebastian.
On 28/12/2015 at 18:39, xxxxxxxx wrote:
Hi Sebastian,
I know that was a little old, but I reworked the code and did many tests to see where the problem is.
now what I can confirm: (attached a piece of the code..)Bool SNodeUserArea::InputEvent(const BaseContainer& msg) { Int32 dev = msg.GetInt32(BFM_INPUT_DEVICE); Int32 chn = msg.GetInt32(BFM_INPUT_CHANNEL); GePrint("any event!!"); if (dev == BFM_INPUT_KEYBOARD) { GePrint("any key is pressed"); if(chn == KEY_DELETE) { if (!selection) return true; BaseContainer actionk(BFM_ACTION); actionk.SetInt32(BFM_ACTION_ID, GetId()); actionk.SetInt32(BFM_ACTION_VALUE, 0); actionk.SetInt32(BFM_ACTION_UPDATE, true); removeSelectedNodes(); removeSelectedWires(); //InvokeCommandCall(GetDialog(), COMMANDMSG_VALUECHANGED, actionk); SendParentMessage(actionk); return true; } } ......
the problem is:
after a mouse click "for example selecting a node in my userarea" , this changes the data of my CustomDataType, once this is done, the focus is gone!so next keyboard hit is missing "the whole InputEvent() is not called at all!" , so I have to click again.
I also tested it with your example, your example works fine!, the only difference that I see is: in many cases I may send multiple parent messages... "is this a problem?"though I hacked around it, not sure if this is fine or not "you may tell " , I set:
action.SetInt32(BFM_ACTION_UPDATE, true);this forced it to work! , so if this is fine you can consider this solved or suggest a better alternative
On 30/12/2015 at 14:33, xxxxxxxx wrote:
ok I found a pitfall!!, action.SetInt32(BFM_ACTION_UPDATE, true); actually updates immediatly BUT ignores the data change update "so the GeUserArea updates, but the internal data doesn't get a refresh "as this user area can be seen in multiple object managers, I see it only updating in 1 location when action.SetInt32(BFM_ACTION_UPDATE, true); is active!"
on the other hand without this line, it got the keyboard delay focus, ideas?
On 31/12/2015 at 04:55, xxxxxxxx wrote:
Hi Mohamed,
Sorry for my late reply.
Sebastian will be back next week and I'm sure he'll be able to give you feedback and ideas for your problem. -
On 04/01/2016 at 02:07, xxxxxxxx wrote:
Hello Mohamed,
your last posts are a little bit confusing. Can you post your current code of all relevant classes and functions?
Sebastian -
On 04/01/2016 at 04:44, xxxxxxxx wrote:
Hi Sebastian,
I guess the functions are getting delayed due to heavy processing "when the MatPreview is rendering the this problem happens!".
so I guess it is a wait for event loop that get ignored due to thread being busy in rendering.
but the problem as I posted, and the code is quite complex!! "more than 7k lines../+ I can't strip it ". -
On 04/01/2016 at 09:10, xxxxxxxx wrote:
I do not understand how material preview rendering is related to this thread. Without more specific information I don't think it is possible to give more help.
Sebastian -
On 05/01/2016 at 05:05, xxxxxxxx wrote:
He Sebastian,
it is a long story "this GeUserArea is a custom gui for a custom data type inside my MaterialData plugin".
but I tested when rendering is off too, it didn't work for unknown reason, I guess I will accept the result anyway.you can consider this solved/closed.
